Scanner installed but getting message can not communicate with pc
    Novelist:
  • 158 Answers
Have you loaded the scanner driver software on your PC? Is the printer connected to the PC using a known good cable plugged into the proper receptacles? Is the scanner plugged into a known good power source? Is the scanner turned on? If you use one of the USB ports, your PC should automatically display NEW HARDWARE FOUND on your screen, and willl then ask if you want to install it using the SCANNER AND CAMERA INSTALLATION WIZARD.. You can also left click mouse on WINDOWS START, left click on CONTROL PANEL, and left click on the SCANNERS AND CAMERAS ICON. A new window should appear. Follow the instructions on this SCANNERS AND CAMERAS window, and you should be able to get your scanner working.
Posted on Aug 04, 2008
HP scanner is missing. Unable to scan slide.
The ArcSoft PhotoImaging suite is just to process and scan images, but the printer hardware itself needs hardware drivers, which contain coded instructions to communicate with your CPU.
This is the HP scanning software.
Printer/Scanner hardware should have a driver setup disk that came with it.
If you have this disk:
shut down PC
unplug printer
boot PC
uninstall the current version, if in start>control panel>programs
restart PC
install driver from disk or downloaded driver file for your model.
Regards, Clive.
Nov 21, 2017 | VuPoint Office Equipment & Supplies
Neat scanner not working since upgraded to Mavericks.
I'm using a software called VueScan, which works with lots of scanners without original driver installations. Maybe try it?
Jan 02, 2014 | Apple Mac OS X Snow Leopard (10.6.8)
My Epson CX3900 prints fine. It's when I try to open Epson scan that I get an error message "Cannot properly communicate with scanner"
if the unit is directly connected via USB, another program or prev installed scanner software is using "the path" to communicate with the scanner. Can only use one scanner at a time with windows.
Nov 25, 2009 | Epson STYLUS CX3900 All-In-One InkJet...
Hi, I have brand new Canon MP140 3 in 1. I am getting the error message &cannot communicate with scanner. Cable may be disconnected or scanner may be turned off. Check status. scanner driver will be...
1. If you are connected correctly (via a USB cable), first be certain that the cable is snug on both sides (PC and Canon MP140).
2. If still a problem, remove the Canon MP140 icon from Printers and Faxes.
3. Then, disconnect the USB cable.
4. Restart your PC and log into Windows.
5. Connect the USB cable.
6. The PC should recognize the Canon MP130 and ask for a driver.
7. Install the driver.
If #6 does not happen, your USB cable could be faulty or may be a problem with USB port or your Canon. Move USB cable to a different USB port on the PC. Replace the USB cable. Try to install the Canon on a different PC to test.
Hope this helps.
Aug 11, 2009 | Panda ANTIVIRUS ED PLT 7.0 1YR 26-50...
Scanning error - cannot scan error code 2,155,0 ???
i found this while i had the same error msg... apparently its actully the USB cable where its does not suffice
here is the link : http://www.fixyourownprinter.com/forums/printer/49111
Thanks
Sanjieev
Jan 13, 2009 | Office Equipment & Supplies
Canon mp610 scanning problem
The readme says that some USB hubs have an issue.
I was having problems and was connected via a hub. I removed the hub and connected the printer directly to the back of the PC and voila scanning is all good.
ALex.
Apr 20, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Epson 3490 Scanner not communicating properly with PC
The new PC was Vista and the CD that came with the scanner completed loading a driver without complaint. However, a new driver was needed for Vista. After downloading the new driver from Epson, uninstalling the old driver and installing the new driver, it worked.
Mar 05, 2008 | Epson Perfection 3490 PHOTO Flatbed...
SuperPen (Wizcom) does not Communicate with PC
Just bought the pen and I've got the same problem. I've tried 2 PCs, one with XP SP2 and the other Vista (using Vista driver from Wizcom). Both give me the same "cannot communicate with Pen" error message. I've double checked every recommendation I could find on Wizcom's website and the internet, but looks like either the cable or pen is faulty. Would be good to know if the new cable they're sending you fixes the problem.
Jan 11, 2008 | Office Equipment & Supplies
Scanner won't communicate with my Mac
Uninstall the software with scanner unplug from your MAC. Install the software with the scanner disconnected, then connect it b4 the first use of the software.
Mar 28, 2007 | Canon CanoScan LiDE 30 Flatbed Scanner
108 people viewed this question
jasbo
jasbo
