Question about Samsung Audio Players & Recorders
The sound on my surround works for all of 10mins then fades out to no sound we've taken it back once to be fixed on our warrenty but now its doing the same thing again and its out of warrenty.was wondering how much it would cost to repair it or can i do something my self????
    President:
  • 1,489 Answers
Not likely something you can fix yourself. Sounds like a power supply issue. Cost to have repaired would be a wild guess at around $200 + / - .
Charlie
Posted on Mar 27, 2011
Sony TA-AV521 I have had this stereo system with surround sound for years. Recently I am finding that the surround sound mode is not working right. There is a lot of fading in and out whether it is on...
CD's and FM radio are created in 2 stereo channels. To listen to them in Surround, artificial processing has to take place in your receiver, so artifacts and fading are quite common when you do this. When you turn the surround off, your stereo is processing the information properly and it will sound right.
Mar 02, 2011 | Audio Players & Recorders
Stereo Amplifier fades out. My Sansui dolby pro
No that's how to describe a problem, folks - with details. Using internal FM as the source is always the preferred way of troubleshooting system-wide receiver audio problems (no cables or setting in the way).
Does the sound come on immediately with power and then fade or is there a small delay while the electronics stabilize, a click and then sound that fades?
The fizzle probably means something is rapidly overheating or a capacitor is malfunctioning. If both channels do it, I'd suspect a common power supply problem. Can't help much more than that.
Dec 12, 2009 | Audio Players & Recorders
RCA 5.1 Surround Sound Receiver Sounds fade in and out
chk how you are hooking up the speaker polarity minus to minus and plus to plus.
Oct 17, 2009 | RCA RT2250 System
Music was plating from ipod through speakercraft
Hello
If your amp is still undr warrenty, send it back, do not void warrenty. If it is already out of the warrenty period you can open the amp up untill you see the cicuit board. Now you trace the board to the sound channels, once here have a look at the capasitors, you will easily see if it has overheated. You can replace this yourself or take it to a repair shop where they will fix it for cheap.
But before you try this. Once the amp is opened up, locate the fuse and see if the fuse is still working properly.
If all else fail, take it to a repair shop and first get a qoute on how much it will cost you to fix and then decide if it is worth the money to fix. Please rate this.
Best regrds
Sep 26, 2009 | SpeakerCraft MZC-66 Amplifier
The picture fades out and then comes back on in about an hour.
witch sentence is corocet .I' ll come back to toronto on 10 march.I'll back to toronto on 10 march
Jul 06, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sound will go to loud static noise, but picture is fine
it sounds like you need someone to look at it for you so fix it under warrenty if you can. Maybe buy a set top box and source your sound from there. also buy 5.1 surround (if you like as its a excuse to upgrade) for your speakers.
Jun 01, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Asus A6R -No power at all
yes repairing laptops is tricky, not like a desktop pc, so that sounds about right, and yes the port on the back where the power plugs in will wear out and break. thus not charging your battery no matter what power adaptor you use. so yes ask them if they offer a no fix no fee policy on that repair. and when they do fix it. check what warrenty the repair comes with. other than that it sounds fine to me.
Apr 12, 2009 | ASUS A6U Notebook
VIEWSONIC VPW425 42' PLASMA SOUND FADES ALL THE WAY OFF
I have a brand new Panasonic 42" tv, once in a while the sound fades out and then fades back in right away. I have it hooked up to a high def cable box with high def cable.
Jan 16, 2009 | ViewSonic VPW425 42 in. Plasma HDTV
Hooking up video
I am assuming that you are using a surround sound system?If so on the back of the satellite receiver you will have RCA cables labled yellow ,red,white uuse an rca cable to run from the output on the back of the sat box to an rca input on the surround sound unit.the inputs should be labled on the back of the surround sound unit.once you have the sat box plugged in look for the output on the surround sound (rca cables) run one set of rca cables to the rca cable input of the Tv.on the original tv remote select the tv input that is the cable from the surround sound is plugged in to . make sure the surround sound unit input is selected to the input that the sat box is plugged into.this will give you surround sound from your satellite receiver,repeat with your DVD player plugging the DVD rca cable output to another empty input on the surround sound.to switch between the sat box (satellite TV) to DvD select another input on the surround sound unit.Try to correspond the units you are plugging into the surround sound to the correct name of the component on the back of the surround sound unit to avoid confussion.any questions,Im here to help.If this works rate me FIXYA! if it helps.GOOD LUCK!
Nov 18, 2007 | Panasonic SC-HT40 System
Audio fade
if there is no problem with the surround sound, you have a problem with the volume regulation circuit or with the main amp of this TV set, But to say the least is you have a backup to fix your problem, with the sound system, you said it works fine. this could run ya about 250 to 400 to repair. Good luck.
Mar 29, 2007 | Mitsubishi WS-55315 55" Rear Projection...
137 people viewed this question
Top Samsung Audio Players & Recorders Experts
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
