Question about Brother HL 2140 Laser Printer
My printer won't print all pages of an article. Especially, with emails, it only prints the first page, and no more. With articles, I want to print, it will print usually the first 3 to 4 pages, and quit. Often, the first page comes out of the printer, then a couple seconds go by, and another page or two come out, and it stops printing the rest. I am not technically-minded, so please explain answer as simply as possible. Thanks!
leethedeuce
  • 4472 Answers
SOURCE: Printing black pages
That is a bad primary corona in laser printers would require professional service.
Thanks,
Lee
Posted on Sep 26, 2008
SOURCE: brother mfc 465cn printer
If you remove the empty cartridge, you will see a small window on the egde that plugs into the printer, in the center. This is where the printer optically scans for ink levels. On the empty color cart, you can try covering that raised spline with electrical tape or by coloring it with a black permanent marker. That should fool the sensor into thinking your ink is full.
Posted on Jan 03, 2009
jtuminaro
  • 56 Answers
SOURCE: ghost printing
This machine needs a new fuser. That is a common issue.
Posted on Jan 15, 2009
sodeep
  • 3267 Answers
SOURCE: I attempted to print a
It seems the printer buffer memory has overflowed. Cancel the print from the print Que and switch off the printer. Give your PC a reboot too. Now switch on the printer and make sure that there is no document in the print Que. If its still there, disconnect the printer and delete the pending job, i.e. print Que. After the printer shows it ready for printing do not release the entire document for printing at one go. Breakup the print job in 3 parts and for each part manually enter the page numbers and then give the print command. Repeat this till the entire lot is over..........................sodeep
Posted on Apr 14, 2009
  • 742 Answers
SOURCE: No ink on printed pages
Try to pull out the ink cartridges. Then after 1 minute put the cartridges on. Then it will initiate head cleaning. Just perform the head cleaning to clean clogged nozzles. Then try to print a test page.
Posted on May 10, 2010
Where is the ip adress located for pixma mp495 printer
see the link
Print out the network settings - MP495 / MP499
Description
This article explains how to print a Network Configuration Page for the PIXMA MP495 and MP499. An example of this page is attached to this article.
Solution
Printing Out Network Setting Information
You can print out the network settings of the machine such as its IP address and SSID.
https://support.usa.canon.com/kb/index?page=content&id=ART110996&actp=search&viewlocale=en_US&searchid=1511620536514
Mar 17, 2018 | Canon PIXMA Office Equipment & Supplies
CX5000 All in One. It only prints half of the page and keeps printing only half a page until article is finished. This is with emails and some others but seems to print OK from Word documents.
Check the paper settings in the printer and the program which you are printing with. Try to reset the paper settings.
Goodluck,
Please don't forget to rate the solution
May 02, 2008 | Office Equipment & Supplies
Why does my printer sudenly print the wrong way across the page?
Sounds like someone changed the page orientation from portrait to landscape. Go to print preview before you print your next article and then go to printer properties and see how the page orientation is set.
Jun 08, 2015 | Epson Workforce 645 4x Ink MFC
Why does HP Deskjet 940c only print left side of a selection from a web page?
A printer prints almost anything that is shown in a computer screen and it depend on what you're trying to print. If you want to print contents from a webpage, you have two options to chose from. The first is of course the contents in the webpage that you want printed and the second option is to print the whole webpage. If you want to print only the contents in a web page, e.g. an article or photo, you have to highlight the article or photo first then right-click and select 'Print...'. It should print the article or photo only. But if you want to print the whole webpage, chances are that it only prints the 'skeleton' of the webpage and not the contents, hence the reason you have only the left part of the webpage printed. However, if you highlight the whole webpage and then right-click and select 'Print...' I am sure you will have the whole webpage printed. Cheers.
Mar 08, 2015 | HP DeskJet 940c InkJet Printer
When printing more than 1 page, it does not print ALL of the info.
Have you tried to un install your printer drivers, they can become corrupt over a period of time.
Completely un install them then reboot the pc and make sure they are gone, then download the latest version for your operating system and install them, see if that cures it for you.
Jan 16, 2014 | Epson Stylus Photo R320 InkJet Printer
I'm trying to print an article from the computer and blank pages keep running through the printer non-stop.
Try canceling the print job, unplug the printer and plug it back in. Copy the article to a Word Doc. and print it from there.
Dec 07, 2010 | HP DeskJet 932c InkJet Printer
Started printing 20-30 pages of article, realized not enough paper in printer, but not being my machine didnt know where to find more paper, for some minutes now machine wont print at all
You have to go to Control Panel or TaskBar where you can see your PRINTERS folder. If ther are many printers listed, select your printer.
You have to delete the printing job from the queue.
When there is nothing more in the queue,
Print again, this time go through the menu, and instead printing the whole article specify pages like Pages 22- 40 ( Omit the first pages you have already printed.
Hope this will work for you, have a good day
luciana44
Sep 22, 2009 | Epson Office Equipment & Supplies
Printing just a few pages of an article
Go to printer preferences and click on print page then there should be a window to type in the page #'s you want to print.
Feb 09, 2009 | HP Computers & Internet
Number of pages
If you use ALL small type, it will be 20 pages. Seems like the thing to do, but if you must use 21 pages, you can use 17 pages of small print (40,800), and 4 pages of large print (7,200) for a total of 48,000.
Oct 17, 2008 | The Learning Company Achieve! Math &...
When I cancel the printer does not print other items that have been scanned. it gets hung up.
when you print an article on-line. it goes into your printers memory. 10 pages for instance. if you cancel after 5 pages. the printers RAM ( memory ) stores the remaining pages to be printed. the only way to do this, is to cancel printing. then go into printer program. and delete the queue, or pending items, before exiting windows.
hope this explains your dillema.
mike @ Compurepair.
Feb 20, 2008 | HP DeskJet F380 All-In-One Printer
Brother HL 2140 Laser Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
