Question about Cobra Radio Communications
I have programmed my Cobra SR900 scanner using frequencies obtained from the Internet. I have reviewed the codes I programmed and they show up as I entered them. The unit seems to scan but no calls come through. Volume and squelch are set as directed in manual. Antenna is also extended.
4 Suggested Answers
SOURCE: NO SQUELCH
I have a Radio Shack Pro 97 Scanner that I received as a present 1-1/2 years ago. It was working just fine and then suddenly there was no squelch or volume. The keys make noise when pushed, but there is no sound for the squelch or volume. The scanner scans the frequencies but does not stop and play. I went on line and found that other people were having the same problems. I went back to the store that the unit was purchased from and received no help what so ever, they said it’ s off warranty and I was out of luck, nice way to do business??. I think that something that cost as much as this should not be junk after a short period of time. I hope you can help me with this problem I do like radio shack, but I can’t afford to buy items that don’t stand up.
Sincerely
Greg Stevens
e-mail
fooyun@sbcglobal.net
Posted on Aug 28, 2008
radiorob1
  • 17 Answers
SOURCE: Radio Shack PRO-49 handheld scanner. Turns on,
The "hot" pin inside the BNC antenna connector is probably broken or disconnected internally.
Posted on Oct 10, 2009
  • 5603 Answers
SOURCE: I HAVE A RADIO SHACK PRO 97 SCANNER WAS WORKING
Check if one of the batteries MIGHT be in backwards.
NEXT check EACH cell as occassionally you get a bad one brand new.
Posted on Nov 14, 2009
How do I program a realistic 2029pro
These steps were listed on their website:
PROGRAMMING CHANNELS
1. Turn on your scanner by turning the volume clockwise.
2. The scanner might start scanning. If so, press MANUAL to stop the scanning.
3. Enter the channel number that you want to program and press MANUAL.
4. Enter a frequency including the decimal point. The decimal point shows up on the display as a -- (dash).
5. Press Enter to store the frequency.
6. To confirm the proper entry, press REVIEW. The programmed frequency appears on the display one digit at a time.
7. To program more channels repeat steps 3-4. (IR-07/29/96)
Nov 11, 2014 | Radio Communications
WHERE TO FIND CODE MANUEL
Hi.
To program the scanner do the following:
  • Press "MANUAL" button. The display will show the channel.
  • Keep holding the "MANUAL" button until the display indicates the desired channel.
  • Press the "E" button.
  • Enter the channel frequency.
  • Press the "E" button again. The frequency is now programmed for the channel you selected.Verify that your entry is correct by pressing the "REVIEW" button.
Here the reference guide: Reference Guide
Jan 14, 2010 | Uniden BC248CLT Base Scanner
How do you program a bearcat bc55xlrt scanner with a code?
There are no codes, only frequencies. For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
To program your BC55XLT:
Turn on radio.
It will be in scan mode. Press Manual (orange button) to stop scanning.
Press Manual button to step through channels to get to the one you want.
(Or press channel number and then manual button)
If "LockOut" is displayed it means this channel isn't being "Scanned."
You will want to lock out constant "broadcast" services such as NOAA or airport weather. Pressing Lockout will toggle the feature on and off.
Select a channel to program. Use the keypad to enter frequency. Use "E" for Enter
key. If the radio displays an E this means Error. Usually, the
frequency you typed in is outside of the capabilities of the scanner.
Once you hit the E you will immediately start hearing anything that's
out there on the frequency you entered.
Push the "Review" button and the scanner will display the frequency
that is programmed for the channel. A "-" will be displayed for the
decimal point.
Jan 12, 2010 | Radio Communications
PROGRAM FREQ IN BC142XL
Its so easy to use you really don't need a manual for the Uniden BC
142XL scanner.
Turn it on. Push the MANUAL button to stop it from scanning.
Push number 1, then push MANUAL again. This should leave you on
channel one.
Using the keypad enter the frequency you want to monitor, then push
E. Press REVIEW at anytime to see what frequency is programmed
there. If the review button flashes 000.0000 on the display, you might be entering an invalid frequency. Refer to the frequency coverage list below.
Push MANUAL to step to channel number two. Enter the frequency. Push E. Push MANUAL to step to channel three. Repeat this process until all ten channels are programmed, or you've run out of frequencies to enter.
Push "SCAN" to start automatically scanning the frequencies. The
radio will stop when it hears someone talking, and resume scanning two
seconds after the conversation has stopped.
Frequency Coverage:
20 to 29.7 MHz (10 Meter "Ham" Band)
29.7 to 50 MHz (VHF Low Band)
50 to 54 MHz (6 Meter Amateur Band)
136 to 144 MHz (Military Land Mobile)
144 to 148 MHz (2 Meter "Ham" Band)
406 to 420 MHz (Federal Government Land Mobile)
420 to 450 MHz (70cm "Ham" Band)
450 to 470 MHz (UHF Standard Band)
470 to 512 MHz (UHF "T" Band)
Nov 07, 2009 | Uniden BC248CLT Base Scanner
Can i program my cobra cxt400 two way radeos to get the police scanner frequencys?
No, these radios are programmed for FRS and GMRS frequencies only. Their programming cannot be changed.
Oct 14, 2009 | Cobra Electronics CXT400 Two Way Radio
Cannot for the life of me figure out how to program this!
You need to obtain local frequency numbers for your area.
google search, "radio frequencies" and you county, city name...it'll give you lists of frequencies to enter into your scanner..
Your user manual should show you the step by step with which buttons to push... are you having difficulty entering the frequency numbers?
k
Jul 06, 2009 | Uniden BC60XLT Handheld Scanner
How do i program my realistic pro-2025 scanner
scanning.
Jun 03, 2009 | Radio Communications
Cobra Police Scanner won't accept my frequency codes
when entering your codes make sure you put in the . or it will not take the number, most times the . is after first 3 # then hit enter then prg. I hope this helps.
k.ditterline@yahoo.com
Mar 09, 2009 | Uniden BC80XLT Handheld Scanner
Cobra-sr900 reception
Press E after the Channel # instead of manuel.
May 27, 2008 | Audio Players & Recorders
How do you program a bc560xlt scanner
Hello sir,
Check out this link for the programming...
http://www.grove-ent.com/SCANNERPROGRAMMING.htm
http://www.icehouse.net/no7up/bc560xlt.html
bye
Good Luck
Don't forget to rate the solution
Mar 11, 2008 | Audio Players & Recorders
Radio Communications Logo
94 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
