Question about PfaFF Creative 7570
Pfaff 7570. This is the 3rd time timing has gone out. Getting expensive. Any solutions?
  • 980 Answers
If you email me I will attach instructions for you to retime it, can't find any way to attach instructions on here kendourof@yahoo.com
Posted on Mar 27, 2011
Pfaff 3.5 was working fine,suddenly thread is bunching/getting caught under plate.Thread goes around the bobbin ok,when gets near to needle gets stuck on hook on right side.Any idea how to fix please?
Just guessing. You might try :
Installing a brand new needle
tightening the top tension a bit
If it continues to be a problem, most likely the machine is out of time and requires adjustment. Search for sewing machine timing or take it for service.
Apr 24, 2017 | PfaFF Sewing Machines
Needle keeps falling out of Pfaff Creativ 2170
change ur needle bar and also check needle size before insert in it.
Sep 14, 2008 | PfaFF Sewing Machines
Skipped stitches
lower your needle. If up to high can't catch the bobbin thread.
Aug 31, 2017 | PfaFF Tiptronic 2040
I have a Pfaff 230. I am told by a repair shop that the Hook & base are broken. They said parts are not available, and it would be too time consuming to replace if parts were found. I found the
Hi ow old is machine, call company l. Your machine is popular but really not common. They are expensive and he doesn't see many. He really may not know how to fix. If he touch and it don't work you going to expect a lot of money. Call company and let them tell you where to go. But Pfaff is a high end company expect to pay more like when you purchased. Pfaff, Viking, Bernina, are mire expensive all you need to go yo certified dealer not just any repair. Even Singer and Brother or it void your warranty. So he did you a favor. Call dealer that sold it too.
Nov 14, 2017 | Sewing Machines
Timing out on pfaff 955
check on
youtube
fixsewingmachines.com
Apr 09, 2012 | Sewing Machines
Connect PfaFF Creative 7570 to a PC
The software you need to connect the Pfaff 7570 to the PC and to create your designs is called PC-Designer version 2.2 from Pfaff. You may be able to find a used copy. The software should come with a dongle (special cable) for connecting the machine to the PC. Make sure you have this piece because it will not work with an ordinary cable. Depending on what type of port you have on the PC to connect to, you may also need an adapter since the dongle has an old style connector on the end going to the PC. If you are going to create your own designs, you will also need a storage card which inserts into the machine that you send the designs to. Pfaff makes one, called the creative card. I have also used a generic card meant for the pfaff; the generic card is less expensive and has a greater capacity. You can find many designs online either free or for sale to send from PC to Pfaff as well.
Nov 27, 2009 | PfaFF Creative 7570
Jamed Pfaff CD 7570:
Your machine probably has a thread lock which is a piece of thread caught in the hook. If this is the problem then here is the solution.
Grasp the hand wheel and turn it back and forth,increasing the amount of force used each time. It should break free after about 4-6 tries
sewman7
May 08, 2009 | PfaFF Creative 7570
Pfaff 360 automatic slows and stops after only minutes of use
Pfaff 360's don't like to sit, they like to drink. . .. oil.
Set top knob "C" to 0
Right top (zig-zag knob) set to 4, lever below but on the same dial points straight down. Set stitch length to 4. Run 5 minutes medium speed.
After that lift off the top cover and spray inside with "Tri-flow", then run a hairdryer on it for 20 minutes to warm up or set near a warm lamp overnight. Run daily 5-10 minutes and exercise the right knob between 0 and 4 (zig-zag). It should come back to working with oil, time, and heat.
Apr 13, 2009 | PfaFF Creative 7570
Pfaff Creative 1371
Did the machine get dropped, or otherwise roughly handled? Or have a rough, bumpy ride back home, etc? That could explain why it's not working correctly.
Feb 25, 2007 | PfaFF Creative 7570
Sewing Machines Logo
99 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
