Question about Weber Q Grill
Electronic spark will not ignite - Weber Q Grill
    Genius:
  • 1,114 Answers
What you have is a faulty ignitor, they can be replaced. You can try a hardware store, but you may have to go through Webber to get one.
Posted on Mar 27, 2011
B&S coil (electronic ignition) has spark on ground terminal but not on spark plug cable.???
Hi, Robert and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting, leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or electronic control module.
7. Faulty CKP, CMP, or BAS sensor.
8. Faulty ignition switch.
9. Tilt sensor needs a reset.
10. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Impact of spark plug number of ground electrodes on engine stability
How to diagnose no spark situation on motorcycle
No Spark Whats Wrong
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 05, 2017 | Motorcycles
I have an electronic ignition furnace that won't spark. The blower turns on after about 30 seconds from hearing the ignition clicking but no spark. I noticed when I completed the lighting proced
On that unit the induced draft motor must close the pressure switch, and all safeties are proven closed, then that signal is powered to the ignition control board. Then the board sends a spark. Lots of times all that happens and the electrode that makes the spark needs cleaning, or the ground for that electrode needs to be cleaned/tightened. Takes some process of elimination for that one.
Oct 29, 2017 | Heating & Cooling
Not getting spark
need more info (need to know what type of ignition system your vehicle has: (1) traditional ignition coil /distributor system, or (2) electronic ignition, but lack of spark problems are usually a faulty coil
on traditional vehicles, and on the newer electronic ignition cars, total lack of spark would be
a faulty ECM (electronic control module) - partial lack of spark (diagnosed with a HEI (high energy ignition) spark tester kit), would be caused by a faulty coil pack (in the waste spark system), where
there's 1 coil pack for every 2 spark plugs.
I bought my HEI igntion testere kit for $20, but Harbor Freight sells a similar unit for $10.
Hope this helps.
Dec 27, 2010 | Ford F-250 Cars & Trucks
According to the obd code i am getting a misfire in the number one cyln and it kind of sputters what is causing it
1. Bad or fouled Spark Plug at #1 Cylinder.
2. Bad or misfiring Wire going from the #1 on the Distributor/Electronic Ignition Coil to the #1 Cylinder.
3. Misfiring at the #1 on the Distributor/Electronic Iginition Coil.
a. Unplug the #1 Wire at the #1 on the Distributor/Electronic Ignition Coil.
b. Using an Auto electrical testing: Probe, wire and ground clip electrical, stick the Probe into the opening at the #1 Distributor/Electronic Ignition Coil. Use the grounding clip - clipped to a portion on the engine.
c. Start the Vehicle and check for rhythmic spark.
d. If there is NOT rhythmic spark, the Distributor/Electronic Ignition Coil needs to be replaced.
e. Turn off the engine.
f. If there is rhythmic spark: Reconnect the #1 Wire at #1 on the Distrubutor/Electronic Igntion Coil.
g. Disconnect the #1 Wire from the #1 Spark Plug.
h. Again using an Auto electrical testing: Probe, wire and ground clip. Insert the Probe into the end of the #1 Wire and clip the ground clip onto the engine.
i. Start the engine again.
j. Again Check for rhythmic spark.
k. If there is NOT rhythmic spark the #1 Wire needs to be replaced. (Replace all Wires as a Set).
l. If there is rhythmic spark then the #1 Wire is fine.
m. Turn off the engine,
n. Remove and Inspect the #1 Spark Plug. Clean if necessary and Regap.
o. Reinstall the Spark Plug and reconnect the #1 Wire.
p. Restart the engine.
q, If the code reappears:
r. Replace all the Spark Plugs.
Let me know if this helped or if you have additional information or questions. Feel free to contact me at FixYa.Com.
Feb 09, 2010 | 2000 Lincoln Town Car
No spark from spark plug
New Saw? Warranty time
Electronic ignition? Replace entire module. Pinched wire to metal case part for ignition switch. Permanently shorted ignition switch--replace.
Jun 27, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Timing the cams and crank with a belt
  1. Note: Electronic Ignition engine timing is entirely controlled by the PCM. Electronic Ignition engine timing is NOT adjustable. Do not attempt to check base timing. You will receive false readings.
The CKP sensor is used to indicate crankshaft position and speed by sensing a missing tooth on a pulse wheel mounted to the crankshaft. The CMP sensor is used by the COP Integrated EI System to identify top dead center of compression of cylinder 1 to synchronize the firing of the individual coils.
  1. The PCM uses the CKP signal to calculate a spark target and then fires the coil pack(s) to that target shown in Figure 51. The PCM uses the CMP sensor not shown in Figure 51 on COP Integrated EI Systems to identify top dead center of compression of cylinder 1 to synchronize the firing of the individual coils.
  1. The coils and coil packs receive their signal from the PCM to fire at a calculated spark target. Each coil within the pack fires two spark plugs at the same time. The plugs are paired so that as one fires during the compression stroke the other fires during the exhaust stroke. The next time the coil is fired the situation is reversed. The COP system fires only one spark plug per coil and only on the compression stroke.
    The PCM acts as an electronic switch to ground in the coil primary circuit. When the switch is closed, battery positive voltage (B+) applied to the coil primary circuit builds a magnetic field around the primary coil. When the switch opens, the power is interrupted and the primary field collapses inducing the high voltage in the secondary coil windings and the spark plug is fired. A kickback voltage spike occurs when the primary field collapses. The PCM uses this voltage spike to generate an Ignition Diagnostic Monitor (IDM) signal. IDM communicates information by pulsewidth modulation in the PCM.
  1. The PCM processes the CKP signal and uses it to drive the tachometer as the Clean Tach Out (CTO) signal.
2.5L V6
The ignition system consists of an ignition coil, spark plug wires and spark plugs.
The crankshaft position sensor signal is the basis for ignition timing calculations. The alternating voltage signal from the crankshaft position sensor is digitized by a pulse former within the powertrain control module. This digitized signal is then used to position the closing time of the primary circuit of the ignition coil.
Ignition timing is determined by the powertrain control module in response to engine operating conditions based on stored data tables or maps. Once ignition timing has been determined, the powertrain control module interrupts the current to the primary circuit of the ignition coil thus triggering the ignition spark which is supplied to the cylinders through the spark plug wires and spark plugs.
The ignition coils are triggered by the powertrain control module in pairs (cylinders 1 and 5, cylinders 4 and 3 and cylinders 2 and 6) sending one ignition spark to the firing cylinder and one ignition spark to the corresponding cylinder on the exhaust stroke. This ensures that any unburnt fuel residues remaining in the cylinder on the exhaust stroke are re - ignited to provide cleaner exhaust emissions.
2.0L 4 cynder
The crankshaft position sensor signal is the basis for ignition timing calculations. The alternating voltage signal from the crankshaft position sensor is digitized by the powertrain control module. This digitized signal is then used to position the closing time of the primary circuit of the ignition coil.
Ignition angle is determined by the powertrain control module in response to engine operating conditions. Once ignition angle has been determined, the powertrain control module interrupts the current to the primary circuit of the ignition coil thus triggering the ignition spark which is supplied to the cylinders through the spark plug wires and spark plugs.
The ignition coils are triggered by the powertrain control module in pairs (cylinders 1 and 4 and cylinders 3 and 2) sending one ignition spark to the firing cylinder and one ignition spark to the corresponding cylinder on the exhaust stroke. This make sures that any unburnt fuel residues remaining in the cylinder on the exhaust stroke are re - ignited to provide cleaner exhaust emissions.
Integrated Electronic Ignition System The Integrated Electronic Ignition (EI) System consists of a crankshaft position (CKP) sensor, coil pack(s), connecting wiring, and PCM. The Coil On Plug (COP) Integrated EI System uses a separate coil for each spark plug and each coil is mounted directly onto the plug. The COP Integrated EI System eliminates the need for spark plug wires but does require input from the camshaft position (CMP) sensor.
Apr 05, 2009 | 1998 Ford Contour
Electronic ignition system failed
electric ignition. Electric goes to ignition button, then to a spark generator, where upon a spark is produced. If any part of this sustem is wet, then it is shorted to earth. No spark.
Feb 11, 2009 | Bosch HBN 131560B / 131520 hot-air...
Oven will not light
Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too. spark-anim1.90x11.gif
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system
Nov 20, 2008 | Frigidaire Ovens
SPARK
Connect your tester to the big thick spark plug lead and crank the engine. You should see a nice big fat blue spark. If you don't disconnect the engine kill button. If there still is no spark you will need to determine if the engine has points or electronic ignition. Most (but not all !) bikes built before 1980 have points ignition. Most bikes built after 1980 (but not all !) have some sort of electronic ignition system. If in doubt pull one of the crank end covers (Usually 2-3 screws) and look ! If you have a battery and coil points system see the points page If you have a points magneto system see the Magneto page. If you have an electronic ignition system see the electronic ignition page. ,,,
Nov 10, 2008 | 2000 Alfer VR 2000 Supermoto
1990 Subaru Legacy shorted out the ignition coil. I replaced it and in less than 1 mile,it shorted out the new one.
Subaru engines (including Legacy and engines of many other automobiles, GM, etc.) have returned to so-called wasted spark ignition systems since advent of the electronic distributor-less ignition (having been used historically in early engines with magneto ignitions). With this approach, the ignition systems are less expensive and usually quite reliable. At the same time, however, a shorted spark plug (cracked or carbon clogged, etc.) (or bad ignition spark plug wire) grounds both the ignition spark and the false spark being used. This means that it also grounds the corresponding respective ignition spark of the other 180 degree out of phase cylinder (that uses the same the same coil because the spark current is connected to the spark plugs of two cylinders). Since such a defect allows more current to flow in the spark coil to two plugs when the resistance of the spark plug gap disappears due to a cracked plug, etc, it seems likely to hasten coil burn out if the spark plug/plug wire defect is not corrected before installing the new spark coil.
To explain further, wasted spark means that when a cylinder is ready to fire, it gets a spark to its spark plug while part of the spark (from the same coil and current) as a sort of copy is also sent to another cyclinder at the same time but when the piston in that cylinder is exhausting its ignited gases 180 degrees out of phase from when its spark is needed. When the second cylinder is ready to fire and receives its "spark, the first cyclinder the also receivesa "wasted" spark "copy" of the one needed by the second cylinder. Economy is achieved in manufacture because otherwise electronics would have to turn on and off four different spark coils to distribute four different sparks as needed to the four cylinders. With wasted sparks (which are cheap), because the spark current of one coil is connected (internally in the ignition coil unit) to two cylinders that are in the same position but 180 degrees out of phase in firing, the system can turn on and off two spark coils twice as fast with half the electronics and fire two cylinders that are 180 degrees out of phase. A four cylinder engine thus uses only two coils, a six cylinder engine, three coils, etc., in a wasted spark system.
Jul 27, 2008 | Subaru Legacy Cars & Trucks
Weber Q Grill Logo
368 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Are you a Weber Grilling Expert? Answer questions, earn points and help others
