Question about Refrigerators
Freezer coil freezes up the fan is spinning above the coil but the coil is frozen solid is it the defrost timmer, roper model rtbkxkqoo
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 27, 2011
Freezer fan runs not freezing . seems to be locked in defrost mode
read the manual book of the freezer ,,,and see if ice is not blocking the way......
Nov 20, 2015 | Amana Refrigerators
Coils ice up
My best guess is that the drain has some debris in it and the defrosted water from the coil is being picked up and being re-frozen against the coil and freezing up the drain pan. The defrost timer may have failed, the defrost termination button fastened to the coil may have failed, the defrost heater on the coil itself may have separated from the coil or just outright failed. Hope this helps and good luck.
Sep 22, 2014 | True 49 cu. ft. / 1388 liter Commercial...
Freezer doesn't cool to 0 even though it's set at -5
There is a fan that blows air past the coils in the freezer. Either the fan is not working or the coils are blocked with ice. Sometime ice stops the fan from turning. listen for the fan spinning by turning the thermostat down. Defrost the coils and fan and see if the frig returns to normal. Sometimes the drain tube is clogged causing ice buildup.
Feb 13, 2014 | Whirlpool GB2SHKXL Bottom Freezer...
Coil freezing up
Hello if you have to defrost your evaporator coils every month then you problems are (1)defrost timer(2)defrost heater (3) blocked freezer drain or many;(1) check the defrost timmer so see if it is working the defrost time is from 15-25 min depending,And durning this defrost time you may hear the sound of ice melting on the heater a sine that the heater is working .(2) Blocked freezer drain,The water from the defrost cycle sitting in the drain pan,Is being picked up by the fan pulling it with the air back through the evaporator coil a second time freezing quickly ...
Jul 08, 2012 | Samsung RS2578BB Side by Side Refrigerator
I have a GE GTS 221C fridge/freezer. The fridge is working fine. All of a sudden, the freezer is not freezing. Just cold, but not enough to keep food frozen. The fan on the freezer is working.
remove the rear cover inside the freezer if it has a lot of frost on it,then the evaporator coil is frozen up and you cant blow cold air over or thru a solid block of ice,defrost it,then check the defrost heating element,defrost thermostat and timer or defrost circuitry for no power or defective components,you can use a hand held hair dryer to defrost it quicker
Jan 08, 2011 | GE Freezers
Fan in freezer side runs almost all the time,coils are freezing up,timmer is working, allready changed defrost timmer still freezing over.freezer side is working fine. need help........
There is a problem with the defroster circuit. You already mentioned the timer was replaced. You need to consult your manual for a diagram ( or search at applianceparts.com) to see where the defroster thermostat, thermal fuse, and defroster heater itself are located at, or where the wiring is run.
I suspect your thermal fuse / defroster thermostat has failed.
Jun 26, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
I left my freezer door open by accident on a beko cda540w fridge freezer freezer defrosted now when i turn the fridge back on it does not seem to freeze and the fridge stays warm i can here the fridge...
you may need to manually defrost the evaporator coil. If condensation built up from the door being left open, it may have frozen the coil solid. At that point even the evaporator defrost bar won't be able to remove the ice. Remove the cover, if it is frozen solid, unplug the unit and use a hair dryer to defrost the ice.
Nov 13, 2009 | Refrigerators
Freezer coils freezing, fridge warm
You might want to check and make sure the interior fan is working above the evaporator coils. If the fan isn't working the air won't circulate over the evaporator and it will frost over very quickly, and also cold air won't be pushed into the fridge side.
The fan might turn off when the door is open, hold the door switch shut while you check it.
Apr 27, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Refrigerator won't get cold
You likely have a defrost cycle failure. The freezer's cooling coils need to be frosty and cold so the air that the fan pulls over them can cool the fridge section. If the defrost cycle fails, the coils freeze up to a block of ice and air flow suffers (fridge is about 55 degrees F). The freezer stays cold only because there's a block of ice in there now... sometimes that cold "sinks" to the bottom and only the food at the bottom stays frozen (and can even freeze food at the bottom of the fridge compartment while the rest is warm). To be sure, you'll need to take the rear interior panel off the freezer back wall and check the coils to see if they are frozen solid. If they are then there's a defrost cycle failure. If they are showing a nice white frosty pattern evenly all over the coils then that's normal and maybe the evap fan (right above the coils) is not blowing air up properly or is not working at all. That fan should run if the compressor is running, etc. the only time it doesn't run is during an actual defrost cycle. Once you find out what condition the coils are in it should be simple to direct you further on the problem.
Jan 05, 2007 | Maytag 22.6 cu. ft. Side-By-Side...
Refrigerators Logo
73 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
