Question about Gateway CX2724 Laptop Charger (1300742LMD0017960)
I need to purchase a new charger for my Gateway CX2724 laptop. Will any charger for a Gateway laptop do, or do I need to look for one for my model specifically?
  • 63 Answers
There are different voltage outputs and amperage ratings on different chargers. as long as the plug fits, and the numbers are the same, you'll be fine. I would try to get a charger meant for your unit though.
Posted on Mar 27, 2011
Keyboard removal from a gateway cx2724
You can find instructions in this manual, pages 5 and 6.
Sep 05, 2011 | Gateway CX2724 Notebook
I need to change the SATA on the BIOS of my gateway CX2724, but when I go into the System Setup (F2), I cannot go down to the SATA section. What can I do to change this? Right now, this PC is trashed, as...
Do you have a new drive installed in the system right now. If not you need to change the drive and it should detect it automatically. If you have it install and it is still not detecting it you need to go into the bios and select auto detect or auto for it to find the drive on its own. The reason that you may not be able to access this setting is that auto detect is already activated. Hope this helps with your issue.
Mar 15, 2011 | Gateway CX2724 Notebook
Glass on screen broke gateway cx2724
you can buy something that works for windschreen on cars (rocks come sometimes on), maybe it will work for you to,
Jun 14, 2010 | Gateway CX2724 Notebook
The screen color is off on a gateway cx2724
It's probably hard ware related but we should try updating the video adapter driver to double check.
You can get them HERE.
Download, install, reboot. If the problem persists or if it occurs in the boot up bios screen it is for sure hardware related. In most cases the lcd needs to be swapped.
May 22, 2010 | Gateway CX2724 Notebook
GATEWAY CX2724 SCREEN IS BLACK BUT COMPUTER WORKS. hOW DO YOU FIX THE SCREEN OR IS IT TO EXPENSIVE
Generally when this happens it means either two things, either the inverter or the backlight has died. The cost for the screen is $160 and can be bought here: http://www.blisscomputers.net/search.aspx?find=Gateway+CX2724. Getting someone to do it for you may be a problem if you feel you are not savy enough to do it yourself. Here is a basic tutorial http://www.screentekinc.com/lcd-removal-instructions.shtml. Before you do so be sure your computer is definitely working by connecting it to a basic desktop monitor via the vga connector from the monitor and using the Fn & I believe F5 to activate the other screen>
Mar 23, 2010 | Gateway CX2724 Notebook
Gateway CX2724 PC Notebook Windows 7
try download to this link below
http://www.drivershq.com/Drivers/Gateway/Notebook-Computer/Gateway-CX2724/9771/23769/25262/Drivers.aspx
Feb 17, 2010 | Gateway CX2724 Notebook
My Gateway CX2724 will not install a fresh copy of XP on new Harddrive. HDD is a newly formatted, and the BIOS is set to recognize CDROM, HDD, and so on. The SETUP is still stating that it can not see the...
You need to go into the BIOS and change the SATA type to IDE and not AHCI. I had this same problem on my laptop. Once I switched it to IDE it installed XP no problem. I don't know if Vista or 7 work with it set to IDE mode.
Nov 28, 2009 | Gateway CX2724 Notebook
I have installed a new hard drive in my laptop gateway cx2724 and put in the os xp . it tell me i have no hard drive installed.
the BIOS needs to recognize the new drive. Check with gateway web site under support for note on upgrading the HD.
Sep 13, 2009 | Gateway CX2724 Notebook
Touchpad not working
You should be able to see the touch pad connector with the keyboard off. Also, make sure the touch pad, sometimes referred to as the synaptic pointing device, drivers are istalled and working.Try this link it should help, it has breakdown diagrams for most models.
http://repair4laptop.org/notebook.html
Jun 28, 2008 | Gateway CX2724 Notebook
Gateway CX2724 PC Notebook Problem
operating system of your pc is damaged so reinstall the os again or recover from the recovery CD
Jun 17, 2008 | Gateway CX2724 Notebook
Open Questions:
Cloud storage and file storage - DataAlign In vanilla terms, a backup or the process of backing up, refers to the copying and archiving of computer data so it may be used to restore the original after a data loss event. Backups have two distinct purposes. The primary purpose is to recover data after its loss, be it by data deletion or corruption. The simplest definition of a computer backup is an exact copy. In the case of computer files, we are referring to copies of the original files that you have on your laptop, desktop, or external drive. Creating a backup of original content means having that data saved in two places, but it's also important to make sure that those two places aren't on the same type of device. For example, if you have 3 copies of a working document on your computer, if your computer crashes, you will still lose all three. This makes the backup method and medium, an important thing to consider for your backup strategy. With the kind of Online Cloud Backup technology being used these days, it is extremely important to back up your files. Ideally, we store data files, movies, music, photos and our official documents on the computer. With the ever-changing technology, desktops and laptops have reduced in cost, and the quantum of storage inside them has surged considerably over the last few years. Unfortunately, storing all your data in only one place is risky. Accidental deletion, theft, computer loss, natural disaster is just some of the reasons that could cost you heavily as you stand out the chance to lose the data you've spent so long generating and collecting. Having an excellent backup strategy Computer Data Backup is the only way to battle the unexpected loss of data. There is more than one way to back up your computers, and using multiple forms of backup will minimize the risk of losing your valuable files. This is where, the PC Backup solution from DataAlign stands out of the rest and gives a one stop solution for Business Server Data Backup up your computer's data on the secure cloud servers. Our innovative platform has been designed while keeping you in mind. To provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly.
Jul 20, 2018 | Quantum Computers & Internet
See all Gateway CX2724 Laptop Charger (1300742LMD0017960) Questions
Gateway CX2724 Laptop Charger (1300742LMD0017960) Logo
43 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
