Question about D-Link DWA-556 (ASKU58510) Wireless Adapter
When I shut down the computer, the DWA 556 wifi card causes it to reboot. How do I stop this?
    Genius:
  • 1,043 Answers
There are settings in the BIOS setup of most computers that allows the computer to be powered up by the Wake On Lan signal This allows you to remotely power up the computer by sending a signal to your network card. This setting is normally found in the Power Management portion of your BIOS setup.
Most motherboards allow you to access their BIOS settings by pressing the DEL key while your computer is first turned on. The first screen that shows on your monitor will normally have something similar to "Press DEL to run Setup" across the bottom of the screen. Whatever key is displayed is the one that you want to press as soon as you power it up. Once inside your BIOS look for the Power Management menu across the top of your screen. Once you choose that menu item the next screen should have either "Wake On Lan" or a "Power On By PCI Devices" setting. Make sure that this is turned off. You should then save your changes and exit your BIOS. Usually across the bottom of the settings screen, or on the side, you will see the keys you need to press to do so. Once you press the key or keys, your PC will save the changes and then reboot itself. Just to ensure that the change was made go back to the Power Management screen and make sure the setting is still off.
If your computer is still rebooting itself then the next step is to ensure that you have the latest driver for your adapter. Go to the following website:
http://www.dlink.com/products/?pid=549
You should see a black bar with Overview, Works With, and Support Resources labeled in the bar. Choose the Support Resources. When the bar changes you will then want to choose Drivers. Download the latest drivers for whatever version of your Operating System that you are using. Install them, then reboot your computer. Your computer should then recognize your adapter and install the new driver files.
If after all of this you are still getting reboots the problem might be the PCI slot you are using. Power down the computer, and remove the cover of the case. Remove the screw holding down your adapter and move it to another PCI slot. Re-assemble the case and power up your PC. If you are still getting the reboots then the issue is probably the adapter itself. Try and boot the computer without the adapter installed. If the reboots are gone then the card is defective. If you are still getting the reboots then you have a hardware issue with your motherboard. At this point you should have it looked at by your local repair shop. Due to the price of new motherboards it us usually cheaper to buy a new board rather than try and find someone who will repair it.
One of these processes should resolve your issue.
Posted on Mar 27, 2011
Disconnects immediately and lower signal strength if not close (10feet) of router.
Check the settings and see if there is a way to turn the power up. Do you have another wifi card you can try? If other wireless cards connect from 100 feet with no problem it might be your wireless card.
Jun 12, 2011 | Xtreme N Dual Band Usb Adapter (dwa-160) -...
Computer doesn"t start keep rebooting
Try moving the card to a different slot.
Swap slots with another card if all the slots are full.
If this doesn't work, post a reply / add a comment to this post and I'll dig deeper for more options, but in most cases like this, using a different slot or swapping slots with another card will most often fix the issue.
Jun 04, 2011 | D-Link DWA-552 (ASKU56185) Wireless...
I installed the DWA556 adapter in my new HP6050z computer and used the D-link CD to setup the connection. Worked fine. But then I turned off the computer and when I rebooted, I get the Windows blue screen...
Good day. In regards to your issue, if the d-link support agent told you already that its not compatible with your hp motherboard, you might consider getting a new wireless adapter. Better you can contact d-link again and ask them about a model of wireless adapter that will work fine with your HP computer. Its better to replace your wireless adapter than putting your entire computer in jeopardy. Conflicting hardware might cause instability and might crash your entire system
Hope this help you a bit. Have a great day and thanks for using Fixya. :)
May 19, 2011 | D-Link DWA-556 (ASKU58510) Wireless...
Dwa-552 copatiable with xp ?
Hi there. It should be. If you have plugged it in and it doesn't want to co-operate then go here... http://www.dlink.com/products/default.aspx?pid=DWA-556&tab=3 ... and click on the downloads link.. there you can find the most recent drivers for it.
Apr 05, 2011 | D-Link Xtreme N Pci Express Desktop...
Adapter locks up, have to reboot to get it to run
How often do you reset your computer and your wireless router. (not when it messes up) You should reset your ocmputer at least once a day. This also could depend on you bandwitdh. if your constantly downloading programs music etc, this can cause both your wireless card and your router to freeze which would require a restart. You also might want to check and make sure you have the most updated driver. To check your driver version right click my computer and select "Manage" in the windows goto
Computer management -> system tools -> device manager -> network adapters and right click your device and select properties. Goto the "Device" tab and look at driver version / date. if it is not 1.70 update it at http://www.dlink.com/products/default.aspx?pid=DWA-552&tab=3 and select driver.
Nov 16, 2010 | D-Link DWA-552 (ASKU56185) Wireless...
Speed is g instead of n
The wireless access point or router you are connection to probably does not support n and you wireless card is backward compatable so it will still be able to connect to the wireless access point/router.
Jan 27, 2010 | D-Link DWA-556 (ASKU58510) Wireless...
I have two computers, Computer A that is hard wired to a cable modem and Computer B with a D-Link DWA-556 card in it. I also have a D-Link DIR-655 wireless router connected to the cable modem. My problem...
Does folder sharing work through WiFi?
Might be that the IP ranges are not in the same subclass network if the IP numbers are not coming from the same DHCP server.
Did you check the IP number on Computer B in case of the cabled connection and when it is connected on the WiFi? They should only differ in the last digits, not the first 3 groups.
Dec 19, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Wifi connection
When you're loosing the signal the card is shutting down, rebooting resets the card, and there is no way of resetting the card that is any faster or easier than rebooting. This sounds like you may have a loose connection or a little dirt or corrosion built up on a connection. Remove the wireless card, clean the connections for the card and the two leads, also clean the leads and the card slot. Get everything seated back in good and try it. If you're still loosing the signal and the card shuts down, not letting you reacquire a signal, then the card is most likely malfunctioning, and will need to be replaced.
Jul 18, 2008 | HP Pavilion dv6000z Notebook
D-Link DWA-556 (ASKU58510) Wireless Adapter Logo
494 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
