Question about ION Audio Turntable Cartridge Replacement
Looking to upgrade the cartridge/styli in my ion audio profile pro turntable. What products/company/style should I be looking for?
    New Friend:
I have the same turntable, and sadly the cartridge is proprietary and unable to be changed. However, you can still upgrade the sound quality by replacing the stylus to a higher quality needle. I did that for about $25 and feel better about playing my precious vinyl. The biggest problem to this turntable is the lack of anti-skate. That's very bad...
Posted on Mar 05, 2013
Looking for circuit diagram of behringer power amp
Here is a google link. I don't know which one you need.
https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=circuit%20diagram%20of%20behringer%20power%20amp
Apr 23, 2016 | Behringer Pmp3000 16 Channel Audio Mixer
We bought this upright piano for our daughter to learn on but I can't seem to find any info on it. Serial number 23930. Any info would be fabulous. Thank you.
Remove the front of the piano. Remove the middle C key complete from it mounting pin. You may find the production date and its full service history written in pencil on the side of that key. A piano tuner told me this after I told him that I had removed all the keys to clean them and I was surprised to see the whole history. It said it was standard practice.
Here is some other information.
Concord Mission Style Upright Piano ' The Antique Piano ...
antiquepianoshop.com/product/192/concord-mission-style-upright-piano/ The Concord Piano Company was controlled and manufactured by the famous George P. Bent Piano Company of Chicago, and they built pianos for several ...
Concord ' The Antique Piano Shop
antiquepianoshop.com/online-museum/concord/ (SEE ALSO: CROWN, GEORGE P. BENT) The Concord Piano Company was ... and manufactured by the famous George P. Bent Piano Company of Chicago.
Upright Piano Value ' key-notes
www.key-notes.com/upright-piano-value.html Jun 16, 2014 - Question: I have a Concord upright cabinet grand piano, serial ... Albert's reply: Piano values are based on information such as manufacturer, ...
Piano Manufacturers in Illinois between 1842 and 1908
https://sweeneypiano.com/.../manufacturers/il_piano_manufacturers.cfm The names of Piano Manufacturers and the date year the company was established in the state of Illinois between 1789 and 1911. ... Company, Chicago. Foley & Williams Piano Manfacturing Company, Chicago ... Concord Company, Chicago.
Jan 19, 2016 | Music
How to change needle on record player
The "needle" should be connected to the record player in a simple fashion, just inserted into a slot. First see if you can remove the existing "cartridge" (the entire part that includesd the needle) and then look online for a replacement that looks the same, or search according to the turntable model number. There are many different types of cartridges, so you need to know what to buy. Here is a link to show man of the possibilities: https://www.google.com/search?q=turntable+cartridges&source=lnms&tbm=isch&sa=X&ei=aoHfVPXhN8PZoATI3YIY&ved=0CAkQ_AUoAg&biw=1920&bih=952
Search google with the model number of your turntable, and then the word "cartridge"
Feb 11, 2015 | Crosley CR711-BK AutoRama Retro Turntable...
How to operate the virtualizer pro dsp1024p
I could write a book before I could answer this question for you. The best thing I would recommend doing is to look on Youtube or the company's website to see if there are any user made videos for this.
The unit ships with a pretty good size manual that does describe in detail each section of the piece. I would recommend looking up the main thing you are trying to do with (equalize a room for example) and follow the details about that section. Once that is complete, move to another (compression for example) . If you do not have a manual , again, check the company's site for a PDF file you could download. Good Luck.
Feb 25, 2011 | Behringer Music
Hello my AT turn table was distorting when trying to play a record, so I changed the stylus, but it still distorts. Any suggestions? Thanks!
I am assuming that you have used the turntable in the past (with the same set-up) without problem.
If so I would suspect that you need to replace the whole cartridge rather than just the stylus.
If this is a new turntable or you have connected it to a different hi-fi system (or a different input on your existing system) the problem is likely to be an impedance mis-match. In that case you may need to turn off any built in pre-amplifier in the turntable.
Feb 10, 2011 | Audio Technica 211d6t Atn3600 Atn3601
I cannot listen to a song through my speakers and a different song with my headphones at the same time.Either I hear one song or the other but never the two at the same time..any ideas why?
I believe that only ONE audio system can be active at once so what you are observing MAY be normal. The pro DJ units have two seperate CD players and are set up to cue with headphones. See if you have a "cue" control on your system... Often the clue to these problems is in the manual which one needs to know the name of the function to search for. Learning the language is the key as indexes are useless without the "word".
Jan 03, 2011 | ION Audio Ion Discover Dj Computer Dj...
How to connect my turntables to my mpc 1000
If your turntables use ceramic cartridges, you'll need to use a passive interface box that converts the unbalanced ( RCA ) plugs from the turntable to balanced ( 1/4" T-R-S ) plugs to connect to your MPC1000's stereo line inputs. If your turntables have magnetic cartridges, you will need an active phone preamp, check the music retailers catalogs or on-line there are many makes and models.
If you want to mix the two turntables ( sequeing from one to the other and back continuously as in a DJ setup ), you'll need a small DJ mixer.
Hope this helps.
May 03, 2009 | Akai Mpc1000 Sampling Music Production...
AC POWER PACK BLOWN
David,   I dont like to be the bearer of bad news, but Behringer dissolved its service/repair center years ago.  In my opinion, this indicates little faith in the profitability of servicing Behringer products.  If the manufacturer wont even repair their own products, I wouldn't buy or use that brand if I had a choice.  Their products are good, WHEN THEY WORK.  They keep their prices low by using inexpensive, disposable quality components.  Most of their products aren't worth repairing.      Here are a few options to find your power supply.  Try Rogue music in New York, NY.  Here is the web address.
www.roguemusic.com
Here is another resource.  DBM pro Audio is an authorized Behringer Repair Center.  They are also in New York.  They will be able to tell you if your part is available from Behringer.  I'm very sorry to inform you of the inferiority of Behringer products.  I think the truth, though it hurts sometimes, is the best teacher.  P.S. if you ever visit DBM... next to the elevator, outside DBM's office is a one yard dumpster, it is always brimming with the carcasses of unrepairable Behringer mixing consoles.      Remember, when buying electronics, you get what you pay for...cheap price = cheap components (and usually headaches down the line) Good luck!  I wish you success on finding your power supply.  Michael Mittelsdorf
www.dbmproaudio.com
See my profile for my qualifications. DBM does all my electronics repair.
Jan 09, 2009 | Behringer Rx 1202fx 12 Channel Line and...
ION Audio Turntable Cartridge Replacement Logo
262 people viewed this question
Top ION Audio Music Experts
Michial Gueffroy
Are you an ION Audio Music Expert? Answer questions, earn points and help others
