Question about Waring CTS1000 Toaster
The motor driven belt does not spin anymore. everything else works fine
I have a simplicity 7350 vacuum. The belt and roller have recently been replaced. It runs fine on floor mode and has no problems with suction. When I put the vacuum in carpet mode, I do not hear the motor...
the motor spins around a steel shaft that sticks out on one end, and the belt is driven by that shaft, belts are easily damaged and broken, meaning roller wont spin. Often a burning smell of rubber is noticed after motor shaft spins on stuck belt. cause is always hair./string/something at the three contact points. motor shaft and belt, roller and vacuum body become clogged. become familiar with taking cover off roller/belt, and cleaning Checking moving parts roller/belt come out easily and simple to clean...keep spare belts.
Mar 10, 2014 | Vacuums
My machine is not spinning what may be the problem
depends on what brand and type of unit... is this a front loader a top loader and what brand.. is it direct drive or belt driven.... if it is belt driven could be a bad belt or pulley...if it is direct drive such as a top load whirlpool ,kenmore,roper, you could have a bad drive coupling which is located between the motor and transmission under unit.... if this is a front loader there are numerous items it could be example a motor controller board, main pcb board.
if everything is working but the spin mode and this is a top loader unit may want to check the lid swich that will cause the unit to not spin.... hope this helps kinda a vague description of your probelm....good luck and give me a vote i need them....
Jan 03, 2011 | Washing Machines
Simpson 700L Top loader washing machine won't spin anymore. It washes fine but when it gets to the spin cycle it wont spin. It drains ok. Any suggestions please?
If this machine is not belt driven, then more than likely is the motor coupler. To give you an idea of this problem follow this link....
http://www.youtube.com/watch?v=WLPGs2UMUJc
Aaron
Jan 24, 2010 | Washing Machines
Roper top load washing machine problem. Please see details...
probibly a coupled drive. motor coupling runs everything, pump,aggitator, spin. if none of these thrree, coupling is two plastic parts with rubber between directly on the shaft of the motor , see if there are two screws at the bottom of front of case., if so remove aathen look for clips at top rrear this should be an easy fix
Mar 27, 2009 | Roper RTW4100SQ Top Load Washer
Brush roll not spinning
http://geeksquad.fixya.com/ThreadView.aspx?prdid=414813&thid=453845
Brushroll not spinning
Posted by vistaloopy on Mar 19, 2008
I have a Eureka Bagless Optima 431 Lightweight Upright that is not working. I took it apart to clean the brushroll and have tried to put it back together several times, but the brushroll will not spin anymore. Maybe I'm putting the belt in the wrong spot? Where can I find a diagram or something?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Eureka 431A Optima Bagless Upright Vacuum. You have only 2 choices, the belt is either side driven belt or the belt is a center driven belt and the brushroll has one side that is for the belt and the side driven brushroll and the motor pulley must be in line in order to work properly, you may want to check the bearing holders, some vacs will mark the ends with words like NEW or USED and both have to be identical in order to fit right. Once you have the brushroll out it should spin if you set it on it’s side and if that happens you are OK, then watch the ends of the brushroll. Align the end with the motor pulley, B4 install the belt place the belt on the pulley side and install the brushroll. Then once the brushroll is in and spins properly, and then you can use a belt puller and stretch the belt onto the motor pulley and then track it in a straight line. If you need further help please feel free to contact your local vac dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept for U.S.
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Mar 19, 2008 | Eureka 431A Optima Bagless Upright Vacuum
Cant get the record to start spinning
The plater is either belt driven or idler wheel driven. You need to remove the plater and check the condition of whichever you have.
Belts would need replaced if bad, sometimes you can clean idler wheels with brake fluid and get them working again. Also if the unit is old, the grease on the plater spindle may be dried up. Clean it off and re-grease. Any light lithium grease is good or go buy some "Luberex" at radio shack.
Geno
Feb 26, 2008 | Philco (R) Classic Turntable CD Shelf...
Glass plate turntable won't spin any more
no microwave 1.5 yrs old has a belt - they're all motor driven
Jan 10, 2008 | GE XL1800 1100 Watts Microwave Oven
TT 02 doesn't spin - Help!
i don't know if these are belt driven or not but i would check to see if the belt fell off, if motor driven then i would suspect a bad motor.
Dec 31, 2007 | Philips gemini TT-02 Turntable
Waring CTS1000 Toaster Logo
50 people viewed this question
Top Waring Kitchen Appliances - Others Experts
jdtech
Robert Weir
Robert Weir
Level 1 Expert
Are you a Waring Kitchen Appliances - Other Expert? Answer questions, earn points and help others
