Question about Cameras
I have bought framework DPFMate Manual Versions 1.0.0 and after connection to the laptop it doesn't work. Simply black screen, doesn't join. You connect to the personal computer, the personal computer defines as unknown connection, and the framework doesn't react. How it is possible to correct it????? What it is necessary to make that she has again earned???????
SOURCE: Blank LCD works but wont display
I have a Canon powershot A85 camera, and it works fine, but I get no picture in the LCD screen. It does take pictures and I can look at the pictures after I have taken them. I don't know if you live in Australia, if you do ring Canon on 131383. A lot of Canon camera's and also a lot of other digital camera's all have a problem with the CCD Chip. My brother has a Canon A75, he has had is for many years, and they fixed it free of charge, because it is a problem the camera has, so not something we done. Look on the internet and you will find a lot of info on it, also that it will be fixed free of charge. I also found the same information on a lot of other digital camera's, so ring Canon and find out, I hope this helps you. Kind Regards Marion
Posted on Oct 31, 2006
t00nz
  • 4738 Answers
Know this is old, but additional cameras have been added to the lists since. Canon should fix these cameras for you for free, including free shipping both ways. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
Posted on Nov 15, 2007
daemonguy
  • 118 Answers
SOURCE: help please....printer name does NOT appear
File and print sharing works over NETBIOS protocol , Make sure that NETBIOS over TCP/IP is enabled , some times NETBIOS forwarding is blocked by router firewall.
Follow these steps
1) make sure that both personal computer and laptop is on the same subnet for example
* Personal Computer IP : 192.168.1.2 Mask : 255.255.255.0
GateWay 192.168.1.1 (router)
* Laptop IP : 192.168.1.3 Mask : 255.255.255.0 Gw : 192.168.1.1(router)
* Wireless Router IP : 192.168.1.1 255.255.255.0
2) Enable File and Print Sharing on Personal Computer and share the printer as required
3) Enable Forward NETBIOS in the router , Check your firewalls manual for this step
4) In the laptop open printers and say add printer, and select network printer if you dont see shared printer in the list we have an alternative way
open Start --> Run and type \\192.168.1.2 if it ask username and password give username and password that you use in personal computer , In the opened window you can see the printer which is shared , Just double click it . It will install itself in the Laptop
Hope this would help solving the problem
Good Luck
Posted on Jan 27, 2008
SOURCE: USB device not detected
Mine does the same thing, and i have done everything to try and maake it work, but it doesnt, and it is geting me so fustrated all the time.
Posted on May 27, 2008
  • 135 Answers
SOURCE: Screen is showing computer, usb
The F20 Desktop Software and Service pack on the CD's from navman do not work, as you have seen. The solution is to go to the navman website and download this Service Pack
Be sure your f20 is connected to the USB cable and turned on displaying the USB Connection screen. Leave it on during the entire process.
Once downloaded, run this self extracting file and let it install automatically. After it is installed and ran.....you will see the same error again of failure to connect.
At this point you must reinstall the driver manually. Right click on your "My Computer icon, Select Devices, then properties on the navman. You should see a yellow "?" next to a statement "Unknown Device" in the USB devices. Click on the "Reinstall Driver" and select a specific location or the Have Disk button. The USB driver is now located in C:\program files\Navman\f20servicepack\USB directory.
You should get a button that now says Okay at the bottom, click onto it and allow the MS program to update the drivers. You should see the device screen change and say "This device is operating properly". You can then close the windows and run the F20 desktop program. It should connect then.
Posted on Jul 06, 2008
Everytime that I export to the ipf6100 plugin in cs6 it generates a crash report and will not print.
Process: GARO IOS Application [2876]
Path: /Library/Printers/Canon/GARO/Utilities/GARO IOS Application.app/Contents/MacOS/GARO IOS Application
Identifier: jp.co.canon.GARO.IOSApplication
Version: 1.01 (1.01)
Code Type: X86 (Native)
Parent Process: launchd [201]
Date/Time: 2013-11-12 17:05:56.407 +0100
OS Version: Mac OS X 10.7.5 (11G63)
Report Version: 9
Interval Since Last Report: 82539 sec
Crashes Since Last Report: 74
Per-App Interval Since Last Report: 497 sec
Per-App Crashes Since Last Report: 26
Anonymous UUID: C5192828-9918-4F37-8DAF-4C78AFC9A28F
Crashed Thread: 5
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
VM Regions Near 0:
--> __PAGEZERO 0000000000000000-0000000000001000 [ 4K] ---/--- SM=NUL /Library/Printers/Canon/GARO/Utilities/GARO IOS Application.app/Contents/MacOS/GARO IOS Application
__TEXT 0000000000001000-0000000000007000 [ 24K] r-x/rwx SM=COW /Library/Printers/Canon/GARO/Utilities/GARO IOS Application.app/Contents/MacOS/GARO IOS Application
Feb 25, 2013 | Canon IMAGEPROGRAF IPF6100 InkJet Plotter...
Does DPFMate work with Windows 7
Under Windows Vista and 7 , frames are displayed as a CD drive. If you click on it twice, immediately opens the image management program DPFMate.
I hope helps
Dec 08, 2011 | Toshiba Satellite A300-ST6511 Notebook
Im having trouble with poker on facebook i can get into the lobby but when i click join table or play now my screen jus goes blank pitch black and nothing appears.
First thing you may want to try if you haven't already is update flash there was a update for it about 2 days ago you can download the update here http://get.adobe.com/flashplayer/ if that doesn't work for you make sure you clear your browsers history files.Let me know if that doesn't work for you.
Jun 11, 2011 | Computers & Internet
Error problem while downloading updates
1. Before doing anything else, write down the .NET Framework versions which
are already installed:
How to determine which versions of the .NET Framework are installed and
whether service packs have been applied
http://support.microsoft.com/kb/318785
2. Now see Resolution Method 2 in http://support.microsoft.com/kb/923100
(ignore the title). After running the appropriate/needed tool, (re)install
all .NET Framework versions manually using the download links on the page.
May 28, 2010 | Microsoft Windows Vista Ultimate Edition
Black screen
Usually when you see a reddish hue then black.....is indicative of an inverter or backlight failure. Hold the laptop up after it is started and look from the bottom toward the top. Try to shine a flasklight at the bottom of the screen upwards...see if you can see the windows startup screen or anything that gives an indication that the laptop is running and booted to where you can faintly see something on the screen. If you can barely make out an image, then 9 times out of 10 you need another inverter. There are rare occasions that a backlight bulb will fail, but this is rare and most backlight bulb failures are from shock damage. The inverter can be changed by simply removing the screen bezel, unplugging the inverter and changing it. If the bulb has been broken or burned out, it is more cost efficient to simply change out the lcd panel. The bulb sits in a channel under the lcd panels inside the aluminum framework. The panel has to be disassembled to remove it.
May 23, 2010 | Toshiba Satellite Notebook l505dls5005
Windows up date will not install error code 663
This is an error having to do with the .NET framework. You probably have version 2.0.
2. Now see Resolution Method 2 in...
When you try to install an update for the .NET Framework 1.0, 1.1, 2.0, 3.0,
or 3.5, you may receive Windows Update error code "0x643" or Windows
Installer error code "1603" (ignore the title, if need be)
After running the appropriate/needed tool, (re)install all .NET Framework
versions manually using the download links on the page then run Windows
Update manually to install security updates for same.
NB: KB923100 references this page:
http://blogs.msdn.com/astebner/archive/2006/05/30/611355.aspx. Please read
ALL of it as well as the related page
http://blogs.msdn.com/astebner/pages/8904493.aspx before using the .NET
Framework Cleanup Tool.
Or see the "How to obtain help" section of
http://support.microsoft.com/kb/953297
Nov 04, 2009 | Office Equipment & Supplies
HP colour laserjet 1600 not recognised by USB port
I believe the problem is related to microsoft .NET Framework. I have researched and there are many posts of incompatibility between .NET Framework and many printers not just 1600. My 1600 stopped working and I traced the problem to upgrade to .NET Framework 3.5 I uninstalled 1600, then uninstalled .NET Framework 3.5 (and 3.0 as well for good measure), reinstalled 1600 and it is working fine now again. You can uninstall .NET versions using Add/Remove programs on the Control Panel. To avoid re-updating, I also turned off Windows automatic updates. I left .NET Framework 2.0. No problems with other programs but the computer did have trouble rebooting the very first time after I uninstalled .NET Framework 3.5 and 3.0. Unknown if that was related to the uninstall or a completely unrelated problem. Anyway if you want to try something less drastic than removing .NET versions, check out this Microsoft link:
http://support.microsoft.com/kb/961118
refers to a printer fix related to .NET. In my experience, the Microsoft fixes never work but you are welcome to try before uninstalling .NET Framework versions.
Jan 16, 2009 | Office Equipment & Supplies
Change or remove BIOS password on ACER ASPIRE 5100 notebook
Just a heads up that this has a possibility of not working since it is normally the procedure of desktops.
If you are confident with opening the laptop on the bottom there should be compartments. As you go opening them one of them should have what looks like a black covered CR2032 Flat Cell Battery.
You will need to remove the laptops battery and unplug the AC Adapter. After this let it sit out for 2 minutes. Once the time is up put the clock battery back in, then the battery and finally the ac adapter once you have put the laptop compartments back together.
Note: This works because the Black Covered CR2032 battery lookalike's purpose is to keep power to maintain the system settings. Once it loses power the chips no longer retain the information causing the BIOS to go back to default settings.
Also Note: This may not work if the BIOS has another method of keeping the settings stored.
Dec 16, 2008 | Acer Aspire 5100 Notebook
Cameras Logo
396 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
