Question about Magnum 257 CB Radio
I would like to install a rfx75 on my Magnun 257 but I can't find any wiring directions.
    Novelist:
  • Magnum Expert
  • 500 Answers
Basically remove the final rf transistor from radio. the rfx takes its place.. install ground, +power wires.
if you found any documentation on any other export radio then it will be very very similar.. install the heatsink, and any of the capacitors needed.. and adjust then wattage low low so not to overdrive the the rfx75...
Posted on Mar 29, 2011
How do i install rfx75 to trc-447 cb radio
did you buy this in its own packaging or was it given to you.If you bought it there should be a diagram as to how to install it.
Oct 30, 2012 | Radio Shack TRC-447 CB Radio
NEED TO WIRE LESON MICROPHONE TO MAGNUM 257
Notice the black mic plug has the numbers it is solder by numbers. Used rosin core silver solder radio shack sells it.
Mic Wiring
Stock
1-Shield (ground)
2-Yellow (audio)
3-Red (transmit)
4-White (receive)
Astatic
1-Shield & Blue
2-White
3-Red
4-Black
Yellow NC
Turner Roadking 56
1-Shield & Red
2-White
3-Blue
4-Black
Yellow NC
Sadelta the is a BASE mic
1-Shield
2-White
3-Brown
4-Green
Oct 02, 2011 | Magnum 257 CB Radio
I have a dodge magnun and have replaced the front linkage to sway
check the frunt break pads if the pads were ever replaced by aftermarket pads they will make a clunk sound going over bumps
Jul 10, 2010 | 2005 Dodge Magnum
Galaxy 33 hml
This is not a simple answer not knowing if it ever worked or not. I have a rfx75 installed on a DX 88 and it preforms flawlessly. If I were you I would find a reputable CB Shop and ask for their help.
Jul 03, 2010 | Galaxy Radios DX-33HML 40-Channels Base CB...
No power to radio in trk have 13.5 volts to radio 257 magnum
Ensure that the wiring is correct. Also make sure that the CB's AC is still functioning correctly. Charge your truck's batteries and test the CB on a fixed electrical output (indoor outlet). Also check to see if the power cord is the correct wattage output for the radio.
Hope this helps!
Gavin93
Aug 02, 2008 | Magnum 257 CB Radio
Wiring code for opek power mic please help
Hello mingo, did you get it wired ok or do you still need some guidance??? Let me know,, Mechanic
Jul 11, 2008 | Magnum 257 CB Radio
257 af gain control
You might try calling the Company for parts,,1-877-624-6869
or e-mail them from their site https://www.rflimited.com/Site.asp?CID=2
Let me know how this helps you, sorry for the delay,, Mechanic
Jun 24, 2008 | Magnum 257 CB Radio
Magnum 257 No Audio Being Transmitted
Hello.I have a similar situation on a Magnum 257 HP operating on SSB (AM and FM works fine). If i Transmit it works fine, but when i release the Mic button (after TX), in the bottom side were the RX level should be, it appear somth like a signal level 3 to 5 (constant and continous), but i can't get any reception at all. Only if i turn the TX power level to MAXand i transmit, then it goes back to reception, but not every time. Somtime after TX i need to push the mic button 2-3 times to make it recive somthing, but this wors only if the power level is over 60-70% an i repeat, only on SSB.Can i get some help with this issue?
May 10, 2008 | Magnum 257 CB Radio
Radio Communications Logo
145 people viewed this question
Top Magnum Radio Communications Experts
John Porter
Jim Goldsmith
Jim Goldsmith
Are you a Magnum Radio Communication Expert? Answer questions, earn points and help others
