Question about Sharp Televison & Video
Good evening, I am trying to connect my LC-32G2x to my PC. I had already connect the soun without problem but I cannot see the image of the PC signal on the sharp LCD. Please would you advice what might be the issue here? Regards, Susana
    Sergeant:
    Champion:
  • 221 Answers
DIsconnect your PC from the TV and Shut it Down. Then turn off the TV and reconnect them back and switch on. If this fails to be of Help, contact Service Station.
Posted on Aug 04, 2008
Sharp aquos lc-32le600E connected to PC video is fine, but no audio, any advice? Thank you in advance
Good job---Thank You for letting us know you got it and thanks for using FIXYA.
Mar 15, 2012 | Televison & Video
Slow pc and virus encountered
If you have a good antivirus.., bought with license...try to scan and remove the viruses...but usually after the virus got into the system ..there isn't much you can do ...cause the harm is already done ..and the system is affected ..so ..the right thing and faster to ..is to reinstall the operation system and format the C drive during the operation ..
In short ..you need a disk with the operation system ...you have to get into BIOS to set the boot sequence to boot from optical device first ..and restart and go for the installation ...If you never done this kinda operation ..there are available on the internet tutorials with very clear explaining about how t do it ...Just read one or to ..and the operation itself is not that complicated...Be sure you have all drivers for all devices already saved on a flash stick or on another partition in the computer (or a disk ) ..cause after installing it clean you need to reinstall all the drivers....
Even if it souns like a lot of work ...the reinstalling is usually much faster and 100% efficiency...so ...this is the way I would do it in this case..
Good luck !
Jul 05, 2011 | Compaq Computers & Internet
TURN TV ON JUST PLAIN SCREEN (NO IMAGE), THEN HEAR A CLICK & TV TURNS ITSELF OFF- THEN ON AGAIN... CHANGED BATTERIES IN REMOTE & TRIED TO TURN TV ON DIRECTLY FROM TOP... NOTHING WORK. THIS IS A...
Do you see the backlight ever coming to the screen?
You will want to open the cover, disconnect the backlight inverter and try again to see if it will stay on even without an image.
If it does it's the inverter.
if it still shuts it's most likely (not guaranteed) either the power board itself or the main board.
A good tech should be able to test the power board independantly fairly quickly.
Jun 30, 2011 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
My xperia x8 is saying unable to scan for networks even if iam right next to my router
I had the same problem. I installed the software from the sony erikcon website to my computer, and then followed the process for updating the phone software. That did not work, since I had the latest software already. So then, I tried to REPAIR my phone software, and after that was done, my phone was functional again, and the wifi works without any problems. c:\users\mashhood\appdata\local\temp\msohtmlclip1\01\clip_image001.gif
Requirements:
* A PC connected to the Internet (preferably broadband)
* USB phone-to-PC connection. Please see the accessories compatibility list for your phone.
1. Here is the website to download the Update Service software fromhttp://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice?cc=au&lc=en
and install it on your PC.
2. Run the software on the computer after it is installed.
3. Follow the procedure for UPDATE or REPAIR (if you already have the latest version).
Feb 23, 2011 | Cell Phones
I have Compaq CQ61-319WM. I repaired the AC power adapter and when I power the laptop on with AC adapter or battery, I get the caps lock and num lock leds flash once about every three seconds. I get no...
You have been unlucky in trying to re-assemble a laptop that someone else pulled apart. I find the notion of a technician without a multimeter strange too.. I doubt it is the AC Adaptor in any case
I'm going to assume that you checked all the connections and the condition of the motherboard before you assembled it and noticed no blown capacitors or diodes, burning marks or broken traces. That you checked the CPU and are happy it was working and , more importantly, was the right CPU for that laptop.
This link may help you though
https://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&tmp_task=useCategory&lc=en&dlc=en&cc=uk&product=3380572&lang=en
Dec 31, 2010 | Compaq Presario CQ60-220US PC Laptop
No Audio on Sharp LC-32d43u
If you had sound for before and then lost it (without changing any settings), then try the main resets in the back by the a/v in and out jacks. If this does not work, call Sharp Customer Service (1-800-237-4277) and tell them that you already did the resets. There is a known problem with a heat dissipation pad for the onboard speakers and they will send a repair tech to replace the pad for free, even if you are out of warranty. At least that was the case with my LC-32D6U.
May 26, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Image with no sound
check ur remote control and see if u have muted the sound......if so just push the sound bottom again to activate sound.....
Mar 28, 2009 | Televison & Video
Black screen monitor
souns like the dc-dc convertor board that supplies the backlight gone faulty possible poor soldering on board
Oct 07, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
SHARP aquos 1080p HDTV: VCR image flickers when playback
I have the same model TV and the following worked for me. I am using A/V cables attached to Input1 on back of the TV.
On your Sharp TV remote control:
1. Select the Input (1-5) that is attached to your VCR.
2. Go to the menu and select options.
3. Change your color system to NTSC.
This should stop your picture frome flashing on and off.
You still may have a issue with the screen colors. I don't know of a way to address this, other than to make the picture monochrome.
Hope this helps.
Jun 26, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Televison & Video Logo
53 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
