Question about Mixvibes U-Mix 44 4-in 4-out USB Audio Interface
Hi, I couldn't find my answer anywhere so I'm going to ask. I am using a stanton scs3 system. I also hooked up the mixvibes u-mix44. My problem is that I have the headphones hooked into the mixvibes headphone jack and the master sound comes through them. I can not monitor individual decks in the scs3 system. if I switch the monitor buttons on the midi controller nothing happens it just plays the master sound. Any help??? Thanks Jimmy
Where do i take my stanton c324 to get repaired
I repair them. Email me for more assistance. Fennellcody@gmail.com
Jul 24, 2014 | Stanton C.324- Cdj C 324 C324cdj C324...
Is there a reset button or a fuse on the stanton m 203 mixers ive lost power
Officially, there is no user servicable fuse, However- there is usually one in the wall wart, which you can check simply by using a voltmeter and sometimes there is one internally. soldered to a small powe buss type of board such as was the case wth an older version of that basic mixer I repaired a number of years ago..
If warranty is not an issue, open it up and check. Just make sure to get all the screws out as nothing needs to be forced apart to open it up- just lots of screws.
Dec 17, 2012 | Stanton M.303 3 Channel 10 Inch Dj Mixer
My C314 turns on but none of the bottons work.
Hi, I have the same problem if you decide to ask her to tell how?
Aug 06, 2012 | Stanton C314 Tabletop CD and Mp3 Player
Mixvibes U-Mix 44
Hi Faze,
Here's the manual in pdf.Also,learn more about your U-mix mixvibes.
Hope this helps.Thanks!
Dec 18, 2011 | Mixvibes U-Mix 44 4-in 4-out USB Audio...
STANTON C324 NO DISK \r\nTHIS FIX THE PROBLEM AND COST YOU $25 NO LIKE IN STANTON $320 ;) http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=290406538324&ssPageName=STRK:MEWNX:IT
You need a new laser or laser mechanism. You can order one online no problem. The part number is: Sony KSS 213Q. make sure there is a Q at the end of it because sony makes a lot of different laser types and the one inside the Stanton C.324 is the Q. Yes the C.324 has Sony guts. You might also want to look into ordering a RF Signal Processor Chip. the part number is: CXA 2581N. Once again make sure the part number ends with a N. This part you might have a little more trouble finding online but it is possible. The laser mechanism you can find on Ebay for about 20$ to 30$ and if you order it from stanton magnetics it will run you about 200$. The signal processor I bought the other day from a Sony parts Dealer in my home town for 20$. Im having an Electronics Repair place do it for very cheap. If you send your stanton c.324 to stanton magnetics you will end up paying more than the turntable is worth brand new unless you have valid warranty still on it.
Hope I could help you with the problem. Cheers.
Jun 15, 2010 | Stanton C314 Tabletop CD and Mp3 Player
500V3 Twin Cartridge: Hi Is the colour coding on the rear of the cart ...
Yes, coding is fairly standard... do refer to the sheet that came with your cartridge for pinout on the cartridge.
May 18, 2010 | Stanton 500V3 Twin Cartridge
My stanton c324 after i put a dics in it reads "no disc" what happend to it and how can i get it fixed?
Had same issue with mine, talking with retailer it seems to be a common problem. I am in New Zealand and have been waiting 2 months for parts to arrive. Something wrong with laser and servo. Good luck getting yours fixed.
Oct 28, 2009 | Stanton C314 Tabletop CD and Mp3 Player
NO Disc
The first step is to clean the lens of the player using a cotton swab and alcohol. If that failes to resolve the problem, it is likely that the optics are starting to fail and need to be replaced.
Please clean the lens and update this with the results.
Thanks,
Dan
Aug 11, 2009 | Stanton C314 Tabletop CD and Mp3 Player
Mixvibes U-Mix 44 4-in 4-out USB Audio Interface Logo
Top Mixvibes Music Experts
Michial Gueffroy
Marvin
Marvin
Are you a Mixvibes Music Expert? Answer questions, earn points and help others
