I have a cooler ereader. It screen has frozen in a scrambled display. Pushing the reset button does not help. It appears the battery is charged. I can sync the files from my computer.
  • 6 Answers
SOURCE: remote appears frozen
I got the same issue with mine, and hooking to the computer and upgrading the firmware worked for me. I first had to take the bateries out and let it sit for 24 hours so it would loose the codes inside. No problems after that.
Posted on Jan 31, 2008
SOURCE: C150 frozen!
ok well i downloaded that http://www.sendspace.com/file/7ge9cr And it seems liek its working, For thos who failed it, You have to let go of the circle button befor you start the updat! =P
Posted on Sep 23, 2008
  • 3 Answers
SOURCE: screen frozen white
Try turning it off with the power button on the screen, then closing it, then plugging it in... (?) That's what I would do if you havent already.
Posted on Nov 09, 2008
renx
  • 71 Answers
SOURCE: Frozen and stuck on screen disconnected
Hold the power off button continuously for 15 seconds. This should force a shutdown and reboot.
Posted on Apr 21, 2009
  • 846 Answers
SOURCE: non responsive (battery is fully charged). Screen has frozen up.
There is a reset button at the bottom (insert paper clip in pinhole). If all attempts trying to unfreeze it fail, you may have a logic board issue. Are you sure the Kindle powers up? Try to power up your Kindle with a different battery. If that fails, you can get the part at Kindle Repair and there is a guide that shows you how to open a kindle and install parts at Kindle Repair Guide.
Posted on Jun 08, 2010
Won't let me sign in : screen appears to have frozen. Turning it on and off does not help!
Perform a hard reset by pressing and holding the power and volume up buttons until the unit resets.
Mar 18, 2015 | Nokia Lumia 2520
My kobo is frozen on starting sync won't turn on or off
Note: If your Kobo device has been physically damaged, it is no longer covered by Kobo's limited warranty. On a Kobo eReader, a physically damaged screen will look like it's been shattered, or you may see vertical or horizontal lines on the screen with a frozen image. If you haven't dropped or damaged your Kobo eReader, but are experiencing issues, try the steps below in the order suggested.
  • Turn your eReader off and then on again.
  • If your screen is frozen, slide the power button to the right and hold it for 10 seconds. Your eReader should turn off.
  • Turn your eReader off and charge it for at least four hours. Note: Your computer should be turned on while you are charging your Kobo eReader.
  • If your eReader isn't charging, try using a different Micro USB cable or a different USB port on your computer. Note: If your eReader's battery is completely drained it can take up to 15 minutes before it reacts to being plugged into power.
  • If you're having trouble while reading a book on your Kobo Aura H2O, Kobo Aura, Kobo Aura HD, Kobo Glo, or Kobo Mini: tap the centre of the screen to bring up the Reading Menu, tap the > Home icon to return to your Home screen, then open your book again.
  • If you're having trouble while reading a book on your Kobo Touch: press the Home button and open your book again.
  • Try a basic reset.
  • If you're still having issues, consider a factory reset.
  • If you're unable to reset your device, please contact Kobo Customer Care
Mar 14, 2015 | Kobo 6" eReader Touch Edition
Frozen screen and will not charge
look along either side for a small hole . that might reset the device by pushing a paper clip end in gently
Feb 09, 2015 | Amazon Kindle Model D00901 Tablet Reader...
My ipad is broken
Hi Bob
First thing you can do is to reset it by pushing the Power Button and the Main Button at the same time you have to do this for at least 30 seconds. This will perform a hard reset on the ipad and it should turn off.
Once its off use the power button to turn the ipad on again. This should resolve this issue.
Have a great day
Philipp
Mar 23, 2014 | Apple iPad (16 GB) WiFi Tablet PC
How do i reset. the screeen is frozen
Try pushing the reset button in the TINY hole in the back of the tablet.
Dec 12, 2013 | Kocaso SX9701 Android 4.0 9.7" Tablet PC -...
Screen frozen
You can try doing a hard reset by holding the power button and the home button down simultanously until the device completely shuts off and the Apple logo appears.
Hope that helps!
Nov 29, 2013 | Apple iPad (16 GB) WiFi Tablet PC
Non responsive (battery is fully charged). Screen has frozen up.
May 29, 2010 | Amazon Kindle Wireless Reading Device
Frozen. Yellow light on, Buttons appear to do nothing.
Holding down the Enter key on the keypad for 30 seconds forces the scanner to reset. It is called a forced power down.
May 26, 2009 | Symbol P470-SR1211100FB Handheld
Palm m130 display screen will not display after replacing battery
have you fully charged the battery?
Have you tried a reset and a hard reset?
hard reset, push the power button and the reset button at the same time. (All data will be cleared)
Hope this helps.
Ed
Jan 10, 2009 | Palm m130 Handheld
The screen is frozen
Have you tried a reset? Use a paper clip to push the reset button in the back.
There is also a Hard reset that will wipe out the memory on your Palm. Just hold down the power button while pushing the reset button. Hold the power button until the Palm logo appears on the screen.
Here's a link to more reset information:
http://kb.palmone.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=PalmSupportKB,ts=Palm_External2001,case=obj(887)#hard
Jun 17, 2007 | Palm Tungsten E Handheld
159 people viewed this question
k24674
jasbo
jasbo
