Question about Fisher and Paykel Ovens
Hi there I have a F&P RA610 FW oven and I need to remove one of the elements on top of the oven. Can you please let me know how I do this as it is not obvious & not in the manual. Thanks. Karen
  • Justin Burnett
    Justin Burnett Mar 27, 2011
    Hello Karen,
    The model number you have given does not cross reference with F&P. To locate the model number there should be a plate on the inside wall or face of the oven that will give you the model and serial of the oven in question. Please post back to this thread and I will be happy to assit you in removing the element in question.
    Justin
  • karenp303 Mar 27, 2011
    Hi - Serial # is RFD154368 & Model is RA610FW. Apparently it is an oven made by F&P specifically for Farmers. Hope this helps. Thanks.
    Sergeant:
  • Fisher and P... Expert
  • 415 Answers
This is a tricky job and not for and needs an experienced technican to do it
Posted on Apr 20, 2018
4 Suggested Answers
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    • 18 Answers
    SOURCE: Stoves 720EF Top Oven Failed
    there is a safety stat/fuse on top of the oven exterior i think you will find that it also has blown. Make sure you have isolated the appliance at the fuse board first though, Good Luck
    Posted on Jan 23, 2009
    TheMazz
    • 78 Answers
    SOURCE: MY BOTTOM ELEMENT & MY TOP ELEMENT WILL NOT
    It would be very unlikely that both elements went out at the same time. Is it possible that one element went out a long time again and went unnoticed?
    Do this: Turn your oven on BROIL and the temperature up all the way and see if the top element begins heating.
    Then turn it on COOK and see if the bottom element comes on.
    If both elements fail to work then your problem may be in the selector or thermostat control. You may also have a wire that has come loose (or burned loose).
    If you are comfortable working with electricity, you can turn the circuit breaker off and remove the controls for testing. Also, verify that all the wires are properly attached.
    If you are not comfortable, have a service technician check it out immediately. It scares me that there may be a loose wire behind the control panel!
    If one of the elements worked and one did not then the problem is "most likely" a bad element. Turn off the circuit breaker to your oven and make sure all the knobs are off on the oven and you can remove the element and take it to a parts store for replacement.
    It is easy to remove. Take out the wire shelves and unscrew the screws where the element goes into the back of the cooking cabinet. There will be some wires attached which should pull off.
    Good Luck!
    Posted on Oct 28, 2009
    Fisher & paykel b1602cte oven fan in element at back of oven not working
    FIRST YOU NEED TO KNOW JUST HOW THE FAN WORKS, DOES IT WORK OFF OF ELECTRICITY OR IS THERE A COMPUTER CHIP IT WORKS OFF OF. DOSE IT WORK OFF OF JUST A SWITCH. LOOK UP ON LINE TO FIND A MANUAL FOR A FISSER & PAYKEL B1602CTE IT MAY TELL YOU WHY IT IS NOT WORKING.
    Jan 29, 2015 | Fisher Ovens
    Ra610 thermostat
    is easy the probe inside the oven is helt there by two clips,remove back off oven after turning off the power to it pull off knob undo nut with long nose pliers and remove change wires over one by one so they are connected right pull out old probe push new probe in though the back to the inside of oven and clip into place
    Nov 07, 2013 | Fisher and Paykel Ovens
    Hello, We have a bosch hbn7052gb oven. The lower oven flashed and now the bottom oven doesn't heat up, everything else works ok the fan, the top oven etc. Can you advise what needs...
    Bottom element has failed. Probably 2 screws at rear to remove & replace. Disconnect fast-ons from rear - extract element - replace. best to get electrician to do this - simple job & element should be inexensive. - Rick
    Jun 11, 2011 | Bosch Ovens
    I have a Diplomat 600 fan assisted oven. When switched on, the fan can be heard running, but the oven does not heat at all. Any ideas please? Is this likely to be expensive to rectify?
    Hi.
    It is going to be a faulty oven element.
    Remove the cover at the rear of the oven compartment, and see if there is a round heater element there, if there is, then it will be the element that needs to be replaced.
    If no element there, then it will be either the top element of the oven , or rhe base element which is not visible, that is faulty.
    If there is base element, then it can only be accessed from outside of the main oven by removing the outer panels, and is located at the bottom of the main oven.
    Hope this helps.
    Mar 11, 2011 | Ovens
    Thermador SC301T heating elements not working (top and bottom). elements look fine, oven turns on but elements stay cold.... any help would be appreciated. thanks, Tony
    Its the thermal safety switch. When it trips - it cuts any power from reaching BOTH elements. Open the oven door - at the top wehere the oven latch is - remove the long black panel. In the middle - on the right is a small cylindrical switch...push down on the top - in the very center...it will rest the switch (like a circuit breaker) and then reassemble. Just did it on mine (2nd time) and it fired right up. Good luck
    Jul 09, 2009 | Thermador SC302T Electric Double Oven
    Oven does not work, but the range top will?
    Hi, Are both the bake and broil elements out?You will need to test the bake element first. Sometimes the element will have bubbles in it where it went bad. UNPLUG the range and remove the 2 screws holding the element in. With an OHM meter, check the element to see if it has continuity. If the test shows an open circuit, replace the element. If the test shows a closed circuit, there could be a bad wire connection, or a problem with the thermostat/clock assembly.
    The clock assembly cost is around $100.00.
    It might be a good idea to call a repaiarman out to be sure.
    I hope this helps you. Please let me know if I can assist you further.
    Vic
    Jul 09, 2009 | Ovens
    My oven doesn't work but the broil and top section does. I remove the cover from the oven burner section and saw a glow.
    Hi, Sounds like it might be the element. If you shut off the power to the oven and rmove the element some that you can test it. Check and see if the element has any bubbles formed on it like it has burned through. If it lookes ok, test continuity to make sure that it has not breaks in it. If I can help further, please let me know.
    Thanks,Vic
    May 10, 2009 | Frigidaire 27 in. Electric Double...
    Bottom oven element will not heat up, 15 amp on top panel looks ok
    The bottom element is probably burned out and needs to be replaced. If you have a continuity tester you can remove the bottom element and do a continuity test on it to be sure.
    Apr 02, 2009 | Ovens
    AEG U7101-4 Top Oven tripping the fuse after a few minutes
    It is more than likely the oven element, as it gets
    hotter the insulation in the element is breaking down and causing the trip to operate..
    Remove the panel at the rear of the oven and you will see the element there, undo the screws and pull the element towards you, carefully, detach the 2 wires and remove the element.
    Be careful not to lose the 2 wires behind the oven rear.
    Replace with new element.
    Cannot give you a part number, you will have to go to aeg web site.
    Dec 12, 2008 | AEG U7101-4 Electric Double Oven
    Whirlpool oven heating element
    Are you trying to replace the stove top element, or oven element? For the stove top element, just lift up the side opposite where it plugs in and pull straight out.
    The oven element usually have one or two screws holding a plate in near where the elements go into the back of the oven. Remove the screws and pull straight out. Reverse the procedure to install a new element. The top broil element will be secured in with a couple brackets to hold it up, these must be unscrewed, removed, and then pull the broil element out.
    Remember to turn off power to the range before replacing any of the elements.
    Aug 27, 2008 | Whirlpool RBS305PD Electric Single Oven
    Ovens Logo
    132 people viewed this question
    Top Fisher and Paykel Ovens Experts
    Dan Webster
    Dan Webster
    Joseph Hoffmann
    Oloyede Monsuru
    Are you a Fisher and Paykel Oven Expert? Answer questions, earn points and help others
