My LG 26l2cr-zj has no picture on screen when turned on, when u turn set on screen will go blue for second and then picture drops off. you can just about see picture on screen if you look hard enough.
doin12volt
  • 233 Answers
SOURCE: I loose picture on my big screen
bad voltage regulator - BA09FP requires a bit of tech experience to replace, but its relatively easy. It took me about 1 hour to replace mine. If you need clarification on this, email me at Doin12volt at yahoo
Posted on Oct 09, 2008
duramaxster
SOURCE: Normal pictures fades to blue screen within 30 seconds
The fix for this is here somewhere, as I had the same problem last January and the solution was posted here in March last year. I'll try to find it and post the link to it for you, later.
Posted on Nov 07, 2008
SOURCE: Cloudy Blue Color Covering Whole Screen
I think its time for sony to face a claas action, they do not supply parts in less than 7 years, and the unit should not have been sold so $high, they should buy them back, that is the best solution
Posted on Mar 12, 2009
SD Tech
  • 14553 Answers
SOURCE: screen turns blue
You may have a bad blue picture tube but there is a way to deal with this first---This is a 2001 model and does not have a light engine---I did one of these with the same problem a week ago---the set has a black plastic block with six controls---three are Focus(red,green,blue) the other 3 controls are Screen controls(red, green, blue) Someone has to remove the entire piece on the front of the set below the screen(usually a plastic part) most of the time it is secured with 3 screws on either side of the set in the back; once you remove the screws the entire piece should pull out(pull from right to left(it will not fall off or come out easy--it is held in with several large plastic pegs) With it removed there is an inspection plate with 4 screws-----the screen/focus block is behind it.
You need to look very closely at the block to identify the focus versus screen controls----one row left to right will be marked Focus and the other row left to right will be marked screen------YOU need to locate the Blue Screen control(they are black like the block) With the set on(be careful) go to a video input with nothing connected---if you see a blue screen as well as the input number turn the BLUE SCREEN CONTROL SLOWLY TO THE LEFT UNTIL THE BLUE is gone.
If this cures the problem you may only be buying yourself some time----if the blue picture tube is bad sooner or later this trouble may return----I have seen sets where this was adjusted and the set worked for a year or more with no repeat of the trouble----replacing the blue tube would likely cost you 400 - 500 parts and labor.
I do this here for free so if this has helped you take a moment and give me a vote here.
SD TECH
Posted on Sep 03, 2009
Testimonial: "It seems to have made the difference. Don't know how long it will last... but, thanks!! Awesome... "
  • 556 Answers
SOURCE: kp-fs57 blue screen then turns off
Could be one of three things the yokes, the flyback transformer or the picture tubes, all will be a costly repair. If it was mine I would invest the money in a new one.
Posted on Sep 10, 2009
Testimonial: "Not the news I was hoping for, but thank you for the advice. At least now I know what to do with my TV...a garden feature or maybe a boat anchor??? "
LG 60FG30FC-UA. Suspect p/s board EAY41391501 rev B for no screen display.
Sounds like power board. You cannot tell if capacitors are bad just by looking An ESR meter is required to test them
May 27, 2016 | Televison & Video
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - CCM.net
ccm.net > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from ccm.net
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
Dec 20, 2015 | LG Televison & Video
Set comes on with a blue screen with retrace lines,then shuts down. Turned down screen control on flyback, set stays on cannot control brill
The set is shutting down because the picture tube is been over driven, it is most likely the picture tube has a short in the blue gun, turning down the screen control drops the voltage to a safer level. The only other possibility is a short video driver and open feed resistor usually located on the video board on the back of the picture tube.
Feb 23, 2011 | Sony KV-32S40 32" TV
LG 710s monitor problem screen turns green
Your AUTO settings button is stuck in! Try tapping on it a few times. Otherwise you may have to take the frame apart so you can get at the button.
Dec 28, 2008 | Amptron AMV 17V5 17" LCD Flat Panel...
Picture loses all normal color & changes to snowy blues & greens
Not sure what causes it but it can be fixxed by your local repair guy, I just had mine fixxed for under a hundred bucks, he takes the back off and with a tiny screw driver adjust a few screws to near brand new perfect picture.. and it has been good ever since
Dec 01, 2008 | LG RU-52SZ30 52" Rear Projection...
Sony KP-51WS500
does it have blue video image?
Sep 29, 2007 | Sony KP-51WS500 51" Rear Projection...
Mono setting?
What channel is it and when they tune in that channel, is the picture nice and clear or is it grainy and snowy before the screen goes blue? On some sets, if the signal is weak, the picture will go blue. This is called Blue Screen and is there so you do not see very poor, grainy and snowy pictures. Some sets will have an option in the menu to turn the blue screen off.
Aug 27, 2007 | RCA 24F512T 24" TV
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
