When i turn on computer it says the hard drive was not found
    Scholar:
  • 92 Answers
I would start with the simple things like making certain that the hard drive's connections are in fact connected properly. It also can't hurt to disconnect and reconnect both cables that connect to the hard drive on both ends (with the system turned off.) If that does not make the system detect the hard drive, there is a good possibility that there is indeed a hardware failure. The next step would be to try replacing the cable that connects the drive to the motherboard and even trying a different power cable coming from your power supply. If that doesn't get you anywhere you could try to connect the hard drive to a different port on the motherboard (if it's a SATA drive- the kind that uses a thin, usually red or gray cable to connect to the motherboard) to see if the port has gone bad. If none of that solves it, then the culprit will most likely be the hard drive itself and a replacement drive will be required- at which point it may make sense to take it to a local repair shop. Most folks have better luck at smaller shops as opposed to Best Buy, FYI!
Posted on Mar 27, 2011
I got a used. Dell studio 1537. When I turn it on it says. Operating System. Not found ? Can someone please help me.? Thankz
That normally a sign that the Hard Drive is no good (So it fails to read the hard drive, and says "Hard Drive not found")
Apr 03, 2017 | Dell Computers & Internet
How do i fix my laptop when it says no hard disc is found
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.
Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Jul 02, 2012 | Toshiba Computers & Internet
When I turn on my toshiba satellite, it says install windows xp. It doesn't complete because it says "no hard drives found"
This can happen if the drive is corrupted, or the drivers for the drive are not loaded in the BIOS of the machine. The first is much more likely.
Try going to a local computer store and purchasing a new 2.5" hard drive. The amount of space is your choice. There is usually some screws on the bottom of laptops holding down a door that houses the hard drive. Remove the old hard drive, then remove the hard drive caddy. Attach the caddy to the new hard drive and insert it into the computer. Try installing again. If you can't find the hard drive door, consult the user's manual.
There could be a rare chance that the motherboard of the computer is compromised if the new drive is not found either. Consult a local computer shop if that is the case. You may need to replace the motherboard.
Aug 23, 2010 | Toshiba Satellite A45-S1202 Notebook
Coding that no hsrddrive found
Go into the BIOS reset it back to defaults. Then save and exit. The computer will redetect the hardware in the computer. If it still doesn't redetect the hard drive, turn off the computer. Unseat and reseat the data cable and the power cable to the hard drive. Then go ahead and turn it back on. If it still doesn't see the hard drive then thats because the hard drive is bad and would need to be replaced.
Apr 28, 2010 | Dell OptiPlex GX400 (2090246019) PC...
When i put it on, it gives the message operating system not found,
Try this. Turn on the computer. While booting, enter the bios setup and check if your hard drive is detected by the motherboard. If not, turn off the computer and refresh the connections of the cable from hard drive to Motherboard (both ends) and power plug on the hard drive. Then turn on the computer again and check if the hard drive is detected. If detected, check the boot device priority. The OS hard drive should be on the first boot. Save your settings (press f10) and enter. Hope this helps.
Oct 12, 2009 | Foxconn P4M9007MB-8RS2H Motherboard
My computer will not recognize my hard drive when I turn it on
try other usb ports on your computer. if that doesn't work then try it on another computer. i say that because the hard drive could be damaged. if it works on another computer then you need to make sure you have the proper software installed on the computer you want it on. like the drivers. they usually can be found on the products web page by typing in the model number.
Sep 28, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Operating system not found inspiron 1501
Check to make sure the hard drive hasn't come loose. If it hasn't then the hard drive will need to be replaced.
Jun 14, 2009 | Dell Inspiron 1501 Notebook
My WD portable 250 gb hard drive
Had similar issue with my WD passport , it turned out that it didn’t like my USB 2 ext lead, as i am unable to access my PC’S USB socket i was a bit stuck ...... i have now found that a low cost “POWERED” USB hub solved the issue .....good luck
Apr 22, 2009 | Western Digital WD Passport 250GB Portable...
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
