Question about Jandy Laars Lx 400,000 Btu Heater
My LX400 Laars hearter has started to vibrate loudly when running. I suspect its the blower assembly. How does the top rempve from the heater so I can get to the blower and check it? I see no screws or bolting to remove it. Thanks.
  • 31 Answers
Not the blower! It's the Thermal Bypass located where the inlet and outlet pipe enter the heater. There is a thermal sensitive spring assister valve in there. It needs to be replaced. Probably due to bad water chemistry!
Posted on Mar 31, 2011
  • xtultegra Apr 18, 2011
    Before doing anything, make sure your filters are not dirty! inadequate water flow will cause this problem.
Tip
Laars LX400 Manual Download
Laars LX400 Installation & Operation Manual
Models: LX250NL / LX250PL / LX400NL / LX400PL
Models: LT250NL / LT250P / LT400NL / LT400P
Have you lost your Users Manual / Owner's Guide for your Laars LX400 Pool Heater?
Would you like a digital copy of the Installation / Operation Manual for easy searching of terms and quick reference?
Click here to download your pdf version of the Laars LX400 Pool Heater guide.
I hope that helps.
on Apr 19, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Why would water come out of the air blower on my pentair master temp 400
take off top[ and see if coming from heat exchange or pressure switch leaking
Jun 27, 2014 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars lx400 blower does not come on
check filters or pressure switch sounds like safety switch isnt working
Mar 31, 2014 | Pool & Spa
Hearter temp control was blowing too hot, now only blows cold
Clicking sound you hear is the worn brushes in your blower motor. At this point the blower moter may or may not start with the switch. THe blower motor is faulty so I would change that first, then check for vacuum leaks or faulty selector cable for the heat blend door. It could have came off door side or heater control side.
Dec 14, 2013 | 2010 Dodge Nitro
Laars lx 250 not displaying water temp
check the 2 black wires going int the top of the control board if ok need new temp sensor
Oct 02, 2012 | Jandy Laars Lx 250,000 Btu Heater
LX400 low pressure switch
if good water flow through heater make sure if you have a bypass it is closed half way if not check pressure switch to see if 24 volts on both wires if not bad pressure switch or clogged copper line to it
Jan 02, 2012 | Teledyne Laars Laars Lx Pool Heater /...
My control panel/board on the LX400 is always getting fried. When I replace it with a new one, same thing happens - the blower turns on and runs continuously even if the heater isn't running. Any...
Check that your heater isn't wired to the line side of the timer. It should be wired on the load side, NOT the line side. Problematic at best to have your heater powered all the time, at worst deadly to the heater should your various pressure/temp sensors fail and the heater fire up when the pump isn't on.
May 26, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Laars LX400 Air Flo SW Error
is fan coming on if not bad fan motor also check pressure switch if 24 volts both sides that's ok make sure air flow switch hose is ok
Sep 09, 2009 | Teledyne Laars Laars Lx Pool Heater /...
HEATER MAKING LOUD NOISES
Check the draft inducer motor for any partial blockages or dibri.
I've seen sticks, birds nest particles and pieces of deteriorating fan blades (squirrel cage type fans) cause this.
You might also find that the inducer motors bearing are going.
If its a loud vibrating grinding type noise, I'd suspect bearings or missing pieces of the blades. (unbalanced)
If it's a clanking type noise I'd suspect loose items hitting the fan.
The inducer motor will only operate right before and during burner operation, while the blower motor can operate at any time depending on your setting.
Dec 06, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Jandy Laars Lx 400,000 Btu Heater Logo
175 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
