Question about Homak Rolling Tool Chest
Need to remove drawers in Homak tool cabinet - Homak Rolling Tool Chest
On my On my Homak the drawers have brown plastic stops at the point where the inner slide is stopped by the outer slide when the drawer is extended. These brown plastic stops have brown tails pointing to the front of the drawer. I had to lift the tail on the left while depressing the tail on the right and the drawer slid right out. When you put the drawer back into the slides and shut it, it automatically locks in place/
Posted on Sep 01, 2012
  • 48 Answers
There should be slots in the sides of the drawer slides. Insert a screw driver in the slots and push the tabs in and pull the drawer out that way. To reinstall the drawer just hold the drawer slide and push the drawer past the tabs.
Posted on Mar 28, 2011
How do I remove the slide on my homak tool chest
remove the drawer and you can get to it.
May 07, 2017 | Cars & Trucks
How do you remove the drawers from a model 277xb roller cabinet
If you look on the sides where the slides are, pull out any draw to it's maximum, you should see a small lever on either sides of the slides closest to you. One lever must be pushed up and the other lever must be pushed down and at the same time the drawer can be pulled out.
Jun 30, 2014 | Kennedy Mfg Hardware & Accessories
How do you remove the drawers from 277xb cabinet
Check on the sides of the slides, there should be a small lever on either sides of each drawer. The one lever must be pushed down while the other one on the other side should be pushed the up and at the same time pulling the drawer out towards you. The drawer will be released.
Jun 30, 2014 | Kennedy Mfg Tool Chests and Cabinets 277XB...
How to remove drawers from husky tool chest
There should be two small levers on each side of each drawer. One lever must be pushed down while the other side should be pushed up and at the same time pulling and releasing the drawers.
May 08, 2014 | Husky 27 in. W 9-Drawer All Black Chest...
Need to remove a china cabinet drawer
Instead of trying to remove the drawer, try opening the drawer part way and use a vacuum cleaner hose (with the vacuum turned on) to snare the napkin and extract it. If you have one of those crevice tools (the long flat attachment) you can probably pull the napkin out without it getting sucked into the vacuum. I am assuming this is a cloth napkin?
Nov 28, 2013 | Universal Home
The drawers on my homak tool chest are locked and the lock is jammed.
There should be an exposed piano hinge on the back of the lid. Use a small nail and hammer (or a rock, if your only hammer is locked in the tool box) to push the piano hinge wire out a little bit, until you can get ahold of it from the other side to pull it out. The lid will then come off, exposing the jammed lock which you can then remove and replace.
Aug 20, 2011 | Homak Rolling Tool Chest
GE #WHDVH626 Front Loading Machine - Door gasket Leaks, Need to replace gasket, HOW?
Remove the top panel, the control panel, the toe panel, and the front panel to replace the door gasket. Disconnect power to the washer before servicing to avoid electric shock.
Remove the top panel by removing the top cover and the three 7-mm hex-head screws that attach the rear of the top panel to the cabinet. Remove the top cover by removing the three Phillips-head screws that hold it in place then insert a putty knife blade or similar tool along the top seam between the cover and the control panel. Lightly tap the cover off rearward; slide the top panel rearward then lift it off the cabinet.
Pull the dispenser drawer out until it stops; push down the locking tab, and then pull the dispenser drawer all the way out. Once the drawer is out, remove the Phillips-head screw from the recess of the drawer opening.
Remove the four Phillips-head screws that attach the control panel to the control panel cover. Release the tab on the right side of the control panel from the bracket inside the cabinet.
Lift the top edge of the control panel to release the three tabs that hold its top in place. Push the control panel towards the left, then release the side tab.
Label the wires and mark the connectors matching the wires before disconnecting the wires from the control panel.
Remove the three Phillips-head screws at the bottom of the toe panel holding it to the cabinet, then pull the toe panel down and off the cabinet.
Open the washer door, then remove the three Phillips-head screws holding the door switch and lock assembly to the front panel.
The door gasket is held to the lip of the door opening by a wire and a spring hidden in the fold of gasket. Grasp the wire at the spring location using a pair of needle-nose pliers and stretch the spring to clear the gasket, and then remove the wire and spring assembly. Peel off the door gasket from the lip of the door opening into the drum.
Remove the four Phillips-head screws that secure the front panel on its four corners to the cabinet. Lift up the front panel then remove it from the two hooks and all the way off the cabinet.
Pull down the top of the gasket, and then remove the nozzle from the gasket. Remove the gasket from the water inlet pipe, and then loosen the 7-mm bolt that tightens the wire holding the gasket to the outer tub lip. Take note of the position of the gasket, and then remove it and the wire from the lip of the outer tub.
Install the new gasket into the lip of the outer tub aligning the notch in the gasket with the arrow located on the top of the lip of the outer tub, and then secure it with the wire and the bolt. Do not over tighten the wire with the bolt. Allow a gap of about 1.25 inches between the ends of the wire. Over tightening the wire may tear the gasket.
Insert the nozzle into the gasket ensuring that the washer is placed on the outside and that the nozzle is aligned with the dent on the inside of the gasket. Insert the water inlet pipe into the gasket, and then put the gasket inside the drum.
Reinstall the front panel back into position on the hooks then secure it to the cabinet with the four Phillips-head screws.
Slide the toe panel up into the cabinet then secure it with the three Phillips-head screws.
Reconnect the wires to the control panel. Snap the control panel back into the cabinet, and then secure it with the screw at the recess of the drawer opening.
Slide the top panel back in place then secure its rear with the three 7mm hex-head screws to the cabinet. Reinstall the top cover and secure it the three Phillips-head screws.
Mar 12, 2010 | GE WSXH208A Front Load Washer
Bottom drawer is rubbing and is difficult to close and won't shut with ease
It is possible the bottom drawer has come off the rails or there is a kink in the hoses at the back of the cabinet.
You will need to take the drawer out from the cabinet and check.
The instruction on taking drawer out is on page 7 of Installation Manual which you would have got with the dishwasher. If you do not have it then you can download from
http://www.fisherpaykel.com/admin/pdfs/pdf_installations/526607O_DD_Install_USw.pdf
Hope this helps. You will need nose pliers to remove the side clamps holding the front cover. Be careful not to damage the parts on the front when you remove the cover.
Jan 26, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Homak Rolling Tool Chest Logo
1,548 people viewed this question
Top Homak Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Homak Measuring Tool and Sensor Expert? Answer questions, earn points and help others
