Question about Kenmore 600 6965 Electric Dryer
Our kenmore gas dryer is starting but after 1 minute the heat shuts off what could it be
  • Kenmore Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101/,./'
Posted on Aug 13, 2011
Ignites on start up ,but after initial heat cycle will not ignite again until I shut down for a few minutes then restart.
heatman101
Sep 07, 2011 | Kenmore 75944 Gas Dryer
My model 400 series Kenmore gas dryer has a heating issue. At first start I can hear the gas heater ignite and heat the dryer. After the dryer has ran for a few minutes the burner shuts off and fails to...
heatman101';
Jul 05, 2011 | Kenmore Dryers
Dyer heats up for about 1 minute then, no more heat.
Check the timer , the unit is shutting off when the timer is malfunctioning. If so replace the timer after trying to bypass to confirm that the gas supply is not cut off.
Aug 26, 2010 | Kenmore 74642 Gas Dryer
Turns off after a few minutes
sounds like your motor is overheating or going bad. sometimes lint built up around the motor can cause it to overheat. or the motor is dying.
Aug 31, 2009 | Kenmore 73952 Gas Dryer
Kenmore dryer heats at first but then stays cool.
Check that the air entry and exit passages to and from the burner are clear of lint or a stray sock.
Aug 23, 2009 | LG DLG5932W Gas Dryer
Kenmore Gas Dryer Gets Hot, Shuts Off Early in Cycle
Sounds like a faulty high limit or cycling thermostat. The thermostat tells the dryer to heat until the interior of the dryer reaches a certain temp. It should be mounted on the exhause duct inside the back of the dryer. It should look something like the one in the picture:
Hope this helped and best wishes.
Jul 27, 2009 | Dryers
Heat runs ten minutes than heat shuts off continues to run
I'm thinking the thermostat has failed, it get's too hot and the emergency over temp sensor kills the flame before a fire is started.
Apr 07, 2009 | Kenmore 63942 Dryer
Start gas dryer heat will ignite after a couple minutes no heat
That is usually a sign that the gas solenoids are weakening. Sometimes for some dryers you can buy a pair. Don't know your complete model number.Thanks, Sea Breeze (Visit my site)
http://servicepartstec.blogspot.com/
Mar 23, 2009 | Kenmore Dryers
Dryer shuts off after a few minutes
THE KENMORE DRYER I HAVE... IF REN IN THE COTTON CYCLE IT WILL RUN FOR 50 MINUTES AND SHUT OFF. ITS BOLWING HOT AIR AND THE OTHER CYCLES SEEM TO WORK FINE WITH OUT SHUTING DOWN SO ID APPRECIATE A TIP ON WHAT THIS PROBLEM COULD BE
May 17, 2008 | Dryers
Kenmore 600 6965 Electric Dryer Logo
106 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
