Question about Dirt Devil M084500V Vibe Quick Vac Bagless Upright Vacuum
I dont have a manual for the dirt devil vibe bagless cleaner. It's depositing dirt instead of picking it up. Is there a belt? i don't see one and maybe that's why
    Genius:
  • 1,739 Answers
Information on your Dirt Devil Vibe Bagless Quick Vac M084500V can be found here:
http://www.dirtdevil.com/products/details.aspx?id=M084500V#parts
A link is available to download the manual as well as for replacement parts.
Yes this model has a belt to run the power brush; the manual has replacement instructions.
If dirst is being left behind it could also be a problem with a blockage, overfilled dirt cotnainer, or problem with the filter.
Posted on Apr 18, 2011
The Dirt Devil Featherlite vacuum cleaner throws up the dirt back out. Sometimes the vacuum cleaner doesn't pick up any dirt
You have a blocked vacuum hose take hose off and out side. Push the garden hose from one end to the other, this will push out the blockage
May 01, 2010 | Dirt Devil Featherlite Bagless Vacuum...
Vacuum doesn't pick-up dirt
It's probably not picking up because the belt is worn and stretched. With a new belt it will pick up a lot better. Here is the belts you need:
Dirt Devil FeatherLite Belt
Apr 07, 2010 | Dirt Devil Featherlite Bagless Vacuum...
Dirt devil will not pick up
That means that you need to replace the belt. Here is the belt you need:
Apr 06, 2010 | Dirt Devil Featherlite Bagless Vacuum...
How do I repalce the belt on Dirt Devil Swivel Glide upright vac?
Four screws hold the bottom plate in place. Turn the vac upside down and remove the screws that hold the cover(bottom plate) over the brush roll in place. Remove the plate and you are there.
Oct 22, 2009 | Dirt Devil M088910 Swivel Glide Vision...
Dirt devil vibe 088915v
Are you talking about the beater bar? If so, you probably have a broken belt
Jan 16, 2009 | Dirt Devil Featherlight Bagless Upright...
Dirt Devil Vibe No Suction
Sounds like there is a clog somwhere. Check the hose - you can undo the hose with a screwdriver but because of that bend use a pipe cleaner or a long wire to see if there is anything blocking the tube. Next check the dirt channels from the bottom of the hose on the Dirt Devil Vibe once the hose has been taken off. Check that the bottom part is clear and then tip the machine over, remove the bottom sole plate (4 screws, 2 at the front and 2 at the back near the rear wheels) to check the roller brush - sometimes if there is an obstruction in the dirt channel from the roller brush suction will not get through.
Dont forget however that there are two filters on the Dirt Devil Vibe. The top filter has to be unscrewed and then unlocked. Tap it a couple of times to dislodge any dirt and then lift out the second part filter at the top of the bin.
Dont forget to rate if this advice works. Thanks.
Jul 30, 2008 | Windsor SR12 Sensor Bagged Upright Vacuum
Dirt Devil M084500V Vibe Quick Vac Bagless Upright Vacuum Logo
882 people viewed this question
Top Dirt Devil Vacuums Experts
Jim Parker
Jim Parker
Tim Venetis
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
