Question about Sharp AR-160 Copier
MODEL: SHARP AR-M160 appears L6 and when i am pressing SATART BUTTOM appears number 10
    New Friend:
  • 170 Answers
You need a service technician to check the machine maybe the laser unit of your machine is not functioning
Posted on Mar 28, 2011
My sharp ar m160 is showing L6 what do i do to clear it
The error L6-10 refers to the laser mirror motor not turning.
The only thing you can do is turn the machine off & then back on. If the error re-occurs then, unfortunately, the laser motor assembly would need to be changed out. This would only be done by an authorised dealer who would be able to source the parts.
Hope this helps.
Good luck.
Dave.
Jan 13, 2017 | Sharp Office Equipment & Supplies
My Sharp Copier Model AR-M160 showing f2 error even I replace the new tonner.
Below are the F2 errors and causes for Sharp AR-M160
"F2-31" Image density sensor fault
"F2-32" Drum mark sensor fault
"F2-33" Grid voltage correction problem
"F2-35" Grid voltage correction problem
"F2-37" Drum mark sensor fault
Cause : CRUM chip defect OR Improper developing unit
Check and remedy : As you have already replaced the tonner, we can suggest Replace the CRUM chip,Replace the developing unit
Regards,
Shrey
Jun 01, 2011 | Sharp AR-M160 Laser Printer
Error code H4 appear on display when voltage low in photo copier machine sharp AR-a61
in order press P * C * or # * C *. the machine will go into diagnostics. Then enter the number 14 as if making 14 copies. Then enter 1 and press start. That should reset your machine.
PLEASE let me know if this fixes it.
Aug 19, 2010 | Sharp AR-M160 Black and White Copier
I have an AR-M160 and have an L error. How can I
this L6 ERROR IS USUALLY TO DO WITH THE POLYGON MOTOR IS IT L6-10
Jun 11, 2009 | Sharp AR-M205 Copier
L6 sub 10
Hello sir; I'm not sure the error code can be reset or not but we can give it a try, the easiest way just turn power on and off if don't work follow following steps;
1, press "#", "interupt" "c" "interupt"
2, enter 14 then press start.
Jan 14, 2009 | Sharp AR-5316 Advanced Digital Imager...
I have a sharp ar-m160
if you press the print switch while the l6 code is in the window you will get a second code. more than likly it will be a 10 that means your laser unit is bad & needs to be replaced.
Nov 12, 2008 | Office Equipment & Supplies
L 6
L6 error on AR-M160 - Polygon motor problem.
I would suggest repairman service for this one as it requires stripping the unit down.
Try reseting the error first though.
"#" "interupt" "clear" "interupt" "1" "4" "start key"
Jul 02, 2008 | Sharp AR-M160 Laser Printer
I HAVE AN ERROR CODE L6 ON A SHARP AR-163 PDIGITAL IMAGER. WHAT IS CAUSING THIS ERROR AND CAN IT BE REPAIRED IN-HOUSE?
Apr 18, 2008 | Sharp AR-M160 Laser Printer
Error report
I think L6 is the fuser unit replace fuser unit as not warming up or the control board.
Thanks J
Sep 18, 2007 | Sharp AR-M160 Laser Printer
Sharp AR-160 Copier Logo
158 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
