Question about Blaupunkt Car Audio & Video
I need to know what the orange wire at the back of the Acapulco MP54 is for. It is in the same loom as the audio input cables, not the main loom.
  • 752 Answers
They don't list colors, but the manual does show locations, so this should help:
Posted on Aug 04, 2008
Need to know how the two yellow and two orange wires hook to
The yellow and yellow/black wire (left) and orange and orange/black (right) are high input speaker feeds to power the amplifier. You either connect high input feeds or the low level phono inputs! Not both!
Sep 05, 2015 | Car Audio & Video
Problem with car radio (noisy preouts and aux in)
You have to ground properly the additional device (eg. the amp) That is normally cause for this problem.
Mar 07, 2008 | Audio Players & Recorders
How do I get my aftermarket radio to shut off with the ignition
You should have a cable marked ign + on the wiring loom of your aftermarket unit this needs to be connected to the 12 volt ign cable on the cars wiring loom , easiest way to identify this cable is with a multimeter you should have one permanent 12 volt DC and 1 x 12 volt DC that comes on and off with your ignition key. So 1 permanent 12v and ign 12v make sure they are the right way if your cables are not marked on the radios wiring loom get a manual to check which colour is the ign wire it's usually yellow or orange but check the schematic first before connecting any wiring.
Apr 29, 2014 | Car Audio & Video
Problems with bosal towbar wiring kit....
bosal kits
claim to be plug and play to your vehicle
no wires meant to be cut
the wiring instructions might be generic and not truly specific to your C-Max
save time
wire in indicators old school
pick up the left and right indicator wires at the back of the car
make sure there is a good earth on the 7 pin plug
Mar 07, 2017 | Cars & Trucks
Bosal towbar wiring problems....
Did you ever solve the problem with the location for the orange wire as I have exactly the same problem, thanks
Apr 22, 2013 | Cars & Trucks
Where does the orange and pink wire go to dpx303
You have only provided us with details on your Kenwood Receiver, but not the vehicle make or model.
Therefore, I can only answer based on the Kenwood receiver wiring.
The Kenwood receiver loom has an ORANGE (White stripe) wire - this connects to your vehicle's "Dimmer" control wire.
Kenwood receiver loom does not have a Pink wire.
Hope this helps.
Dec 18, 2012 | Kenwood DPX303 CD receiver
Need to know what wire colours r what on the harness of a Clarion DXZ635MP CD player lost manual
Clarion uses the industry standard wiring colors. Not every unit will have all of the listed wires
White = Left Front +
White/Black = Left Front –
Gray = Right Front +
Gray/Black = Right Front –
Green = Left Rear +
Green/Black = Left Rear-
Violet = Right Rear +
Violet/Black = Right Rear –
Yellow 14ga = Battery Main/Memory
Yellow 18ga = Battery CeNET Power/Memory
Red = Accessory (ignition on)
Black = Ground
Blue = Antenna Turn On +
Blue/White = Remote Turn On (amps) +
Orange/White = Dimmer
Brown = Phone Mute
Orange or Mint Green= Parking Brake Video Lockout
White/Red = CCD (camera) input instant on +
RCA Cables:
Gray = Front Output
Black = Rear Output
Purple = Non-Fade or Subwoofer Output
May 27, 2010 | Clarion DXZ545MP CD Player
Have a Sony CDX-RA700 and I need to know where the orange and white illumination wire should hook to.
That is the wire that hooks into your headlights there should be a wire in your car loom that gets 12v dc only when the headlights are on this is the the wire that you need
Hope this helps
Jan 12, 2010 | Sony CDX-RA700 CD Player
Sounds is lower than it should be, possible short.
Having read the problem report two or three times, it appears that you're running ~three~ cables from your cable receiver to the home theater system - orange, and red&white.
Often, when you can hear a low-level signal on an input, it's due to 'leakage' from another input, and it's my hunch that the cable receiver is sending audio through the red and white (analogue) connections, which you've plugged to the main sat/cable receiver inputs.
To confirm this, I'd be interested to know if, when you unplug the red and white connectors from the back of the Onkyo, the quiet signal completely disappears.
If that's the case, I would suggest either going into the cable receiver's cofiguration to see if 'digital audio out' is set (if such is possible) or switching the input to 'cable/satellite'...
Hope this brings you closer to the root of the problem!
Feb 07, 2009 | Onkyo HT-S5100 Theater System
Car Audio & Video Logo
57 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
