Question about Canon Office Equipment & Supplies
How do I change the ink cartridge in a Canon MX320 printer?
  • 734 Answers
Hi There,
Go to the link below and you can download your printer's Manual with instructions for the cartridge replacement.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx320#BrochuresAndManuals
Regards,
Selk
Posted on Mar 27, 2011
solofixya
  • 34 Answers
SOURCE: how to change ink cartridge in canon mp390
With the machine powered on. Just lift up on the entire top portion on the platen unit, lower the front verticle cover and the printhead should come to the correct position to change out the ink tanks, just tilt tanks towards the front of the unit and lift out.
Posted on Nov 11, 2008
efs_perpends
  • 1996 Answers
SOURCE: how to change ink jet cartridge canon 'pixma' printer mp160
Please go to this Canon link (click here) and enter the term "ink cartridge replacement" in the search window for a set of detailed instructions (with pictures) on how to replace your ink cartridges.
As you face the printer, with the scan cover open,in position to remove them, the black cartridge goes on your left and the color on the right.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Apr 09, 2009
cene765
  • 787 Answers
SOURCE: canon mpc190s imageclass printer error wrong cartridge
Try to remove all ink cartridges, then remove the print head, clean the contacts on carriage with piece of cotton and little alcohol then put all back again.If this not help replace the print head.It's part number is QY6-0037-000.
Posted on Oct 05, 2009
mace1mace
  • 1138 Answers
SOURCE: where is the ink cartridge in the pixma mx320...
To find the cartridges..you have to open the 2 top covers so you can access the location.
You see, the first top cover when you open you will see the glass of the xerox...right? Now return the cover..
Now try to hold the glass body of the xerox and the top cover.. Grip them together and slowly lift it up while the printer is on
Wait for a few seconds and the cartridges of the black and color will position at the middle..
Hope that satisfy what your looking for.
Much appreciated if you could rate my help. Thanks
Posted on May 21, 2010
alpug
  • 1961 Answers
SOURCE: How do I change the ink on my Canon MX320...
Just open the top cover together with the scanner bed.
When the cartridge carrier move in the middle of the printer, that is the time you can replace the catridge. Lift up the top cover for the cartridge carrier and then the cartridges.
When replacing the cartridge. Push the cartridge down the carrier, you will hear a snapping sound. Return the top cover for the carrier and the scanner bed.
Posted on Sep 14, 2010
Where is reset button on MX320
Switching it off, or better, remove the power cable for 30 seconds should be enough to reset the printer. But when even new cartridges are giving trouble you should check the contacts. Not only from the cartridges, but the ones in the printer (cartridge holder)
Jan 28, 2015 | Canon PIXMA MX320 Color USB InkJet Printer
Tip
Canon Pixma MX320 - How To Disable Ink Cartridge Error Detection..
How to fix the printing problem when Canon PIXMA MX320 series detected the errors in your cartridge?
I have a canon Pixma328 and have been refilling ink for black and color cartridges for quite sometime now. The cartridges are close but after I drilled a small hole on the top part of the cartridge using a small screw, there I find a way to refill the ink that I bought from an ink refill store. The procedure needs extra care, not to touch the contact point (copper) because its sensitive and not to damage the inner part of the cartridge when I insert the needles of the syringe used for transferring ink.
After refilling the cartridge, the next thing to do is to reset the cartridge. This will clear your printer from displaying common printer errors like U053, U051 and U052. The importance of the "reset the cartridge" procedure is to avoid the printer from detecting your cartridge as reused one. The steps below is recommended to do after refilling an ink cartridge.
1. Turn off your printer
2. Press and hold the STOP/RESET button
3. Press and hold Power ON button
4. While holding the Power ON button, release the STOP/RESET button
5. While holding still the Power ON button, press twice the STOP/RESET button
6. Release the Power ON button
7. Wait until it display an "idle" message. It will take about a minute.
8. When "idle" appear, open the top cover to expose the cartridges.
9. Lift up the cover for cartridge holder and take out both the black and color cartridges
10. Return the cover of cartridge holder and turn off the printer
11. Return the top cover and turn on the printer again
12. After the printer initialize, return the cartridges.
What happened when ink ran out from a refilled cartridge and the printer detected it?
The printer will display an error U162 or U163. All functions of the all-in-one printer will stop and your printer will not work. The next thing you will know is you are in the front of a computer shop and buy a genuine canon cartridge.
But wait, there is still a way to fix this. Reset it again using a different procedure. Reset the detections of reusable cartridge.
1. Turn off your printer an turn it on again
2. After the printer initialize try to copy or print. The error will appear.
3. When the error is displayed on the display panel of the printer, Press and Hold the STOP/RESET button and wait until it self restart.
4. Release the STOP/RESET button the the printer is restarting.
5. Wait for a few seconds and the pending print jobs will commence.
You can print as long as you want, refill the ink as long as you want and save a lot of money from buying a genuine canon cartridge by just following this simple tips for Canon Pixma MX320 and/or Canon Pixma MX328 all-in-one printer
For those who have replaced their ink cartridge before try to use that again and do follow this tip to make that work again.
on Jun 29, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
I refilled ink cartridges but printer/computer think the ink has run out
This model Canon printer may only let you use genuine Canon/Epson printer cartridges. If you try to refill these ink cartridges it will not work because the Canon cartridges have an embedded chip in the cartridge that detects the empty cartridge even though it has been refilled.
Feb 12, 2013 | Canon PIXMA MX320 Color USB InkJet Printer
How do you fix error message 5100 on my canon mx320 printer. I just went and bought new ink cartridges for it and put them in and now it doesn't work and this error message shows on my laptop
error 5100 means that the printer cartridge carrier can not move freely.
see inside the printer and find the one causing the cartridge carrier to stop. It could be a piece of paper or a dried ink on top of the absorber pads.
Apr 18, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
I cannot find the ink cartridges in my canon pixma mx320 to replace them with new ones now that the ink is out. Anyone knows where they are located?
Lift the top lip cover together with the scanning unit.
Wait until the cartridge carrier position itself to the middle.
Pinch and pull up the carrier cover to expose the two ink cartridges.
Sep 20, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
How do I change the ink on the Cannon MX330? I cant find where the cartridge is
I am writing this to enquire in regards to Canon Pixma MX320. I bought a Canon Pixma MX320 about 3 weeks ago, and I have brought it over to overseas. I am wondering if it is possible to change from the general ink cartridge that this particular printer use, which is PG510 and CL511 to another similar ink cartridge, which is PG810 and CL811. This is because, where I am living right now, doesn't have the particular Canon Pixma MX320, but instead Canon Pixma MX328 and MX338. The Canon Pixma MX328 and MX338 uses the PG810 and CL811. So, is it possible to substitute from PG510 to PG810 and CL511 to CL811 for Canon Pixma MX320? Thank you for your help.
Aug 29, 2010 | Canon PIXMA MX330 Multifunction InkJet...
How do you replace the ink cartridge on my Canon pixma mx320 printer?
Lift up the top lip cover together with the scanning unit cover to expose the cartridge carrier.
Open the ink locking cover. Gently pinch and pull up the cover of the cartridge carrier.
8bc22ce.jpgAfter that replace the ink cartridge...
I hope that instruction will be of help.
Please rate this answer.
Thank you for using Fixya
Jun 07, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
May 20, 2010 | Canon PIXMA MX310 All-In-One Printer
59 people viewed this question
old marine
old marine
