Question about Car Audio & Video
Hi i have a vw cd changer 1J6 035 111 which i took out of the car that i sold so i would like to know which wires are the live and earth so i can release the cartridge
SOURCE: Blaupunkt CD Changer CDC-A08 - Cartridge eject problem
I am waiting for a reply from the Authorised Blaupunkt Service Agent for a solution to this problem &
shall let you know when it is solved. As per my telcon with him it is an alignment problem of the
Cartridge carrier, but he will have to look at the Unit later, when he is free.
Posted on Mar 23, 2009
kenw392
  • 2226 Answers
SOURCE: How do you reset a 6 disc cd changer in 1999 VW Beetle?
1st just try unplugging the changer overnight. also check and see if a cd may be inserted into the cd mech itself.
Posted on May 20, 2009
kenw392
  • 2226 Answers
SOURCE: Disc stuck in cd changer
there is a large gear on the top of the cd mech, turn it counterclockwise to put the cd back in the magazine. the changer will probably work after that.
Posted on May 21, 2009
spencer2302
  • 11 Answers
SOURCE: hi i just got a car with a kenwood 10disc CD
On the botton towards the right is a TINY TINY TINY sliding button.
Posted on Jul 21, 2009
partyd
  • 141 Answers
SOURCE: Need to eject Alpine Renault 6CD changer cartidge- no power?
lok at the 8 pin plug the first pin from the left is the power wire and the round metal part of the plug is the ground
good luck
the last pin on the right is the ignition
Posted on Apr 01, 2010
Anyone have the 2001 VW Golf speaker wire colors?
If your Golf is the premium sound model here is the list:
2001 Volkswagen Golf Car Radio Wiring Schematic for Monsoon Audio
Car Radio Battery Constant 12v+ Wire: Plug #3, Pin #7
Car Radio Accessory Switched 12v+ Wire: Plug #3, Pin #4
Car Radio Ground Wire: Plug #3, Pin #8
Car Radio Illumination Wire: Plug #3, Pin #6
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Plug #2, Pin #5
Left Front Speaker Negative Wire (-): Plug #2, Pin #6
Right Front Speaker Positive Wire (+): Plug #2, Pin #3
Right Front Speaker Negative Wire (-): Plug #2, Pin #4
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Plug #2, Pin #7
Left Rear Speaker Negative Wire (-): Plug #2, Pin #8
Right Rear Speaker Positive Wire (+): Plug #2, Pin #1
Right Rear Speaker Negative Wire (-): Plug #2, Pin #2
Signal for Anti-Theft Alarm System Wire: Plug #3, Pin #1
Data Link Connector (DLC) K-Wire: Plug #3, Pin #3
Battery Supply Constant 12v+ Wire for Anti-Theft System (SAFE): Plug #3, Pin #5
CD Changer Data In Wire: Plug #1, Pin #13
CD Changer Data Out Wire: Plug #1, Pin #14
CD Changer Clock Wire: Plug #1, Pin #15
CD Changer Constant Battery 12v+ Wire: Plug #1, Pin #16
CD Changer Control Signal Wire: Plug #1, Pin #17
CD Changer Ground Wire: Plug #1, Pin #18
CD Changer Left Line Out Wire: Plug #1, Pin #19
CD Changer Right Line Out Wire: Plug #1, Pin #20
May 18, 2010 | Car Audio & Video
I have a clarion fmc100 cd disk changer from like 1993 that came with my silverado when i bought it recently. it's old and the guy just sold it with the truck.... long story short, i know it has power to...
hi red wire is a constant positive , the black wire is your negative earth, and the yellow wire is you ignition live ie when you turn your ignition to the on position it becomes live, then when you turn your ignition off it stops being live.......hope this helps
Feb 21, 2010 | Clarion FMC200
Do you know the radio wiring colors for a 1996 jeep
you need a volt meter and 9v battery. then earth black contact from meter & then
  1. with ign off probe wire to find a live , thats the memory feed goes to yellow on radio
  2. with ign on probe wires that the constent live goes to red on radio
  3. when lights on probe wires thats the illumination feed (if fitted to car, but not used on many new radios
  4. then get 9v battery and with remaining wires pair and connect to battery, when speaker buzz's mark pair as they are ( ie front right rear left etc ) the speaker wires from the new radio are paired by colour ( one with black stripe with is the negative of the pair)
  5. there should be a ground/earth which if you cant find just hook one to the body/chassis
Jan 01, 2010 | Car Audio & Video
Hello - My 2001 VW New Beetle Monsoon radio reads "No Changer". What can I do to fix it?
If it's saying "No Changer" then it's possible that one of the connections between the radio and the changer itself has become disconnected, a possible blown fuse or worse still the changer itself has failed.
First of all check the fuse box, make sure there are not any blown fuses there and if you have to refer to your VW manual if you got the CD multi-changer with the car.
Locate the changer itself and check that any leads has not become disconnected and check behind the radio itself to make sure nothing has become disconnected.
Once you have checked all connections on the radio and changer, and checked the fuses, and you are happy that all seems well then you can try your changer again.
Don't forget to replace any blown fuses you find!!!
If you need anymore help or the changer still is not picked up by the radio please post back.
Good luck.
Aug 03, 2009 | USA Spec SCD-VW44 6-Disc CD Changer
Manual retrieval of a CD from an Alpine S620 CD Changer
Sorry but no. With the units power lead fused, you can hold the red wire to the + terminal of the battery and the black lead to the chassis of the car and power up and eject. good luck
Jul 03, 2009 | Alpine CHM-S620 6-Disc CD Changer
Which wires are live,neutral and earth.
Black=Live
White=Neutral
Green= Earth Ground
May 08, 2009 | Sony CDX-L280 CD Player
Pioneer CDXP1280 12 cd changer. Power to changer, no operation
I Think there are 3 wires to a Pioneer changer??
+12V Battery ( Hot ) on all of the time
Switched +12v ( accessories, or switched by the radio only when it's on,
and Ground (Chassis Earth)
I think there was 2x orange and one black wire
Make sure that there is a good earth to the changer. Use a multimeter on ohms between a good earth point on the car and the cd changer or the black wire.
If you disconnect and reconnect all poer to the changer, you may hear the motors whirr for a short time as the mechanism resets, but cant be sure.
Hope that helps
Dec 08, 2008 | Pioneer CDXP1280 Multi-Disc CD Player...
Alpine and gamma in vw
YOU WILL NEED AN INTERFACE TO CONNECT THESE UNITS WHICH YOU SHOULD BE ABLE TO PURCHASE FROM YOUR CAR AUDIO RETAILER OR SEARCH THE NET
Dec 03, 2007 | Alpine CHM-S620 6-Disc CD Changer
Car Audio & Video Logo
289 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
