Question about Sewing Machines
Singer 522. when ever I finish sewing a piece and pull the threads out to cut the bobbin thread always comes out of the case so that when I start up it makes a mess. I have tried tightening the tention but doesn't change the problem. The bobbin is a genaric stating for singer
  • Sewing Machines Master
  • 1,133 Answers
Sounds like the bobbin case spring is failing to hold the thread firmly - especially if you've already tried to adjust the tension and it hasn't fixed the problem.
I'd suggest you replace the bobbin case, preferrably with a Singer genuine part.
Posted on Mar 29, 2011
How to thread the bobbin of a singer 90s
First make sure that the needle is fully up (use the hand-wheel). Move the bobbin cover release button to the right and lift the bobbin cover out of the way. Remove the current bobbin, if needed. Hold the new, full bobbin so that the thread comes off the bobbin counter-clockwise when you pull the thread. Place the bobbin into the bobbin case. Pull the thread through the slot near the bottom of the case and to the left. Place a finger on top of the bobbin. Next bring the thread left further towards the back of the bobbin case until it stops in the second slot (near the 8 o'clock position if you compare the position to a 12-hour analog clock). Pull the thread back through the groove in the cover plate until it is cut by the thread cutter at the top left of the cover plate. (The thread will turn a "corner" to the cutter.) Replace the bobbin cover.
Singer has the manual for most of their sewing machines here: http://www.singerco.com/support/instruction-manuals . The direct link to the manual for the 90S is http://www.singerco.com/uploads/download/26e7243ab52aaed42904377fea7b090541eb0c9b.pdf . See pages 16-17 (page 18 in the PDF for the English description) and pictures that may be better than the verbal description.
I hope this helps.
Dec 23, 2016 | Singer Sewing Machines
Why does my thread keep bunching up?
That is called "thread nesting," and several things can cause it. The upper thread enters the bobbin area during sewing, catches the bobbin thread, and as the needle goes up, pulls the stitch tight. Something is catching the upper thread as it goes around. The most common reasons are the bobbin or bobbin case (or both) is improperly inserted; the bobbin is warped (roll it down a flat surface--if it wobbles, it's warped), either the case or the bobbin is not seated evenly, there is a rough spot on the bobbin case that is catching the thread, or your bobbin is loosely/badly wound. You need to rule out the possibilities step by step until you find the cause. First, review your threading procedures from start to finish, using your user's manual. Then, without fabric, turn the hand wheel by hand (ALWAYS towards you) to see if you can see it start to catch. The top thread should rotate smoothly in the bobbin area. You should be able to pin-point the cause that way.
Sep 24, 2014 | Singer 2517 Mechanical Sewing Machine
Singer 522
Hi . try adjusting the tension screw on the bobbin case on the thread tension leaf . tighten it slightly just enough that the thread needs needs a little bit of nudging to come out . do the same for the thread coming through the needle . this should help .
Sep 12, 2013 | Sewing Machines
How do you adjust the bobbin
Hello
Set the tension on the sewing machine for the weight of the material you want to sew. The tension setting shows in the stitch on the material. Use the chart on the machine that matches types of stitches with suggested material tensions. An example of this is, the stitch to sew jean material is different than the stitch to sew silk.
Take the bobbin and wind the thread around it. Make sure the bobbin is empty and don't fill it too full of thread. A bobbin filled too full won't stay tightly spun.
Thread the string evenly on the bobbin. Move the thread back and forth evenly and in layers that are level. Many Singer sewing machines have a bobbin winder on the top of the sewing machine, and the consistency of how it threads can save you frustration later.
Find the hole on the bobbin that is located near the inside spindle of the bobbin. Take the thread sitting on the sewing machines spool and insert the thread in the hole from inside the bobbin to the outside. Set the threaded bobbin on the spool designated for spinning on the top of the sewing machine for some Singers.
Turn the side drive wheel slowly until the threaded bobbin has a layer or two of thread on it. Push down on the drive peddle and fill the bobbin, but don't thread it to the very edge. If the bobbin is too full the thread will release erratically. Cut the thread from the spool.
Drop the bobbin into the bobbin case under the area where the needle sews the material. Close the case and turn by hand the side wheel drive until the bobbin threads into the sewing machine. You can tell when the bobbin is threaded by the tiny piece of thread that juts out of the bobbin case where the needle goes up and down.
Grab the thread with your fingers and pull it out approximately 4 inches. Your bobbin is now spun and threaded.
Aug 02, 2011 | Singer 1120 Mechanical Sewing Machine
Singer 5430C bobbins thread always loopy
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Feb 15, 2010 | Singer 5050 Mechanical Sewing Machine
Singer futura 250. while sewing the E4 code
Are you using bobbin thread? Is your thead new? Is themachine threaded correctly?
Make sure that when you thread the upper part the thread go under the circle that pull it.
Another thing is that when you hit the start button, pull the upper thread until the machine goes two or three times. It helps the bobbin thread to come up and the machine start sewing.I you leave it along the thread sometimes doesnot comes up and that is why the machine beeps.
I use this technique to make sure it doesnt beep and to cut the thread (the one at the beginning so it doesn't mess my design)
Feb 15, 2010 | Singer CE-200 Quantum Futura Computerized...
The thread and bobbin are nesting up in the bobbin case
Two things I have found that make my singer ce-200 nest. 1st. When I change threads, sometimes I thread it wrong - always nests when I do that. 2nd. When the bobbin runs out of thread it always nests for me, so I have to check the bobbin often. And I remembered a 3rd thing. 3rd. The area for the bobbin & bobbin casing has to be clean, no pieces of threads, and the bobbin casing itself can move, so make sure it's seated correctly.Whenever I get nesting, I take the metal cover off, under the needle, to get in and clean the bobbin area and under the needle good, before I go back to embroidering.
Oct 28, 2009 | Singer CE-200 Quantum Futura Computerized...
Threading bobbin on singer stylist 522
To wind a bobbin put the cotton reel on the top pin, take the thread to the left and round the little wheel and back to the bobbin that should be on the winder, wind the thread round a few times to take a grip, release the stop motion in the balance wheel, turn the winder button so the winder moves to the balance wheel and press on the foot control slowly.
When you put the bobbin in the bobbin case make sure it turns anti clockwise.
Jun 27, 2009 | Brother CS-8072 Computerized Sewing...
Bobbin case and threading singer 6423
This machine has a black plastic bobbin case. You drop the bobbin down into the case with the thread coming off in a clockwise direction. If you look close you will see a slot in the bobbin case where there is the metal pieces. The thread will slide into that and as you pull on it it will work its way through and come out on the other end of the metal. Lay the thread over top of the bobbin case and turn the handwheel to pick up the thread. (make sure you close the slide plate)
Feb 07, 2009 | Singer 6423 Sewing Machine
Singer featherweight bobbin won't pick up needle thread
pull the bobbin case out by pulling tab or flapper forward (outward toward you) and take bobbin out of bobbin case, If bobbin has thread and that it is coming off bobbin free and is not hung up on bobbin case.
let me know if this helps you,
sec_duane@hotmail.com
Nov 10, 2007 | Singer Featherweight 140Q
Sewing Machines Logo
144 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
