Question about KitchenAid KESC307 Electric Kitchen Range
KitchenAid Model KESC307 has a broken oven heating element. Can you fix this yourself? How? How much is part?
    Guru:
  • 257 Answers
Hello Tgilreath,
I understand that you are having a problem with you KitchenAid range. The oven element is broken and needs replaced and you would like to know the cost of the element.
I can instruct you on how to change the element in your range. However, I do not know if it is the top of bottom element and the change procedure is the same on both of them. However, when looking up the element to tell you where you can purchase and the cost I came across many different KitchenAid models that contained the numbers you gave. There should be more letters and numbers on your tag for the model.
The following is steps are how you change out your element:
1. Disconnect the power to the unit
2. Remove the lower back cover on your range (the one that sits directly behind your oven)
3. Locate the two prongs on the bad element sticking thru the oven wall and remove the wires
4. In the oven remove the racks
5. In the oven remove the two screws holding the element in place
6. Remove the element by pulling in forward
7. Install new element in Reverse
You can locate the element on Sears Parts Direct at the following web-page, however you will need the full model number http://www.searspartsdirect.com/partsdirect/part-model/kesc307?pathTaken=modelSearch&prst=0&shdMod=kesc307 You may also reply to this thread and I will get you a part number and the exact page you need to order the part.
Thank you for choosing FixYa.com
Justin
Posted on Mar 27, 2011
KitchenAid model KESC307HBS8 oven not heating
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jun 10, 2011 | KitchenAid KESC307 Electric Kitchen Range
Our oven won't work. it is a convection oven, and it won't heat at all. the stovetop does work, but when we turn the oven on it says "low" and never heats up. the fan does turn on when we try...
Hi
If the fan is working then most likely it is the heating element gone bad.
You can check this if you have a multimeter or continuity tester.
Replacing the element is not too difficult, you have to get the back off, disconnect 2 wires, undo the fixing screws then fit the new one.
Don't forget to turn the power off first tho'.
Dec 17, 2010 | KitchenAid KESC307 Electric Kitchen Range
Convection stopped working a couple of months ago, now regular oven does not come up to proper temperature, top element is red bottom element is not
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Asker's Testimonial " thanks i will have my husband look into that. " - 2gunsally
Aug 12, 2010 | KitchenAid KESC307 Electric Kitchen Range
KESC307 Electric Kitchen Range: The oven doesn't work, stove works....
heatman101
May 07, 2010 | KitchenAid KESC307 Electric Kitchen Range
Replacing bottom element on kitchenaid kesc207
Yes, you can slide the oven out and get behind it.
remove the screws in the lower back panel. To make it easier on yourself, install the NEW element and secure it so that it cant move while you are "pushing" the wires onto it from behind.
Good Luck!!
Feb 28, 2009 | KitchenAid KESC307 Electric Kitchen Range
HELP! Stovetop elements don't work and oven burner doesn't work
sounds silll but check your circuit breakers make sure both of the 2 breakers fedding this unit ar in the on positoin , itts possible youve tripped half your circuit.
Oct 21, 2008 | KitchenAid KESC307 Electric Kitchen Range
KESC307B Oven Not Heating
contact the manufacturer thru their website and ask for or click on tech support .
Sep 13, 2017 | KitchenAid KESC307 Electric Kitchen Range
Oven does not heat up very fast
The problem in either a bad relay on the control board or a bad bake element. You can use an ohm meter to check for resistance on the bake element. Any resistance means it is ok. Check for 240 volts to bake element. If element checks ok then replace the control board.
Nov 09, 2007 | KitchenAid KESC307 Electric Kitchen Range
Oven not heating to correct temperature
First thing that should be checked is proper voltage.  Low voltage can cause this problem.  Have that checked by a professional first then let me know what you find.
Oct 17, 2007 | KitchenAid KESC307 Electric Kitchen Range
KitchenAid KESC307 Electric Kitchen Range Logo
282 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
