Question about Whirlpool GCAM2792LQ Top Load Washer
How do you get spanner nut off shaft? - Whirlpool GCAM2792LQ Top Load Washer
3 Suggested Answers
  • 1122 Answers
SOURCE: how do you get the
they make a wrench for that,your local appliance parts store should have one-mike
Posted on May 08, 2009
Maytag317
  • 1136 Answers
SOURCE: Spanner nut removel
Hi, The proper tool is P# TB123A.
You can also use a coal chissle and a hammer. Be careful that part of the spanner nut doesn't break off and hit you with the chissel. It takes a preety solid hit to losen the nut.
Hope this helps. If it does, please rate my comments and how I did in helping you. You can order the wrench as well as any other parts on my web site
http://www.whirlpoolpartssurplus.com/cart/
Posted on May 09, 2009
Any solution to fix my old alternators pulley to the new alternator
As long as the shaft size of the alternators is the same it doesn't matter what size nut that holds it on is.
Aug 16, 2016 | Cars & Trucks
How and what tools do I need to remove my front shock on my 1977 elcamino. I've tried a vice grip to hold the shock as I turn the nut at the top just to have the shock turn to no luck
most shockies have two flats machined above the nut and thread
you use these flats with a shifter ( adjuster spanner or an open ended spanner that is a neat fi This stops the shaft from turning as you undo the nut
if your particular has what looks like a spline end then use the appropriate socket
Jul 26, 2015 | Cars & Trucks
How do i change angle grinder blade
Some units have a button you push to lock the shaft. Then you turn the lock nut with the spanner. If yours will not lock the shaft wrap a rag around the blade so you can hold it tight and not hurt your hand and turn the lock nut. It also may have a left hand thread so you could be tightening a tight nut.
Aug 21, 2014 | Saws
The impeller is damaged the local store has 1 in stock but how do i get the nut off the motor shaft
hold the inpeller tight and turn the nut with spanner, you might find it's a lefthanded thread ,so unscrew anticlockwise,
Nov 07, 2012 | Eureka Sanitaire S663 Upright Vacuum
How do I remove the spanner not from the shaft on my kenmore 110.9228110
Right hand threaded nut holds tub in place is direct drive, top loading washing machines. To remove the spanner nut you will need a spanner wrench
May 31, 2011 | Kenmore Washing Machines
How do you fit a inner shaft on a rear wheel push bike ive put in the bearings but everytime i spin the wheel the knuts come undone HELP!!!!!
you must have two spanners, on each side of the shaft you need 2 (two) nuts thyats four in all as one locks against the other. start by putting on the two inners and hand tighten them against each other, next put on the two lock nuts and when hand tight, use spanners to lock them in (only tighten them down, do not use force. now spin the wheel? is it too tight, loosen off slightly on one side, repeat until happy.also try shimano.com they have great tutorials
Feb 22, 2010 | Cycling
Trying to remove spin basket (inner tub) from Washing Machine
See the Sears parts site for washer 82372110.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.82372110
The following may also help.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=146
Jan 25, 2010 | Kenmore 22422 Top Load Washer
Hello! my tub seems to be very loose and makes loud noise when spin cycle turns on....what might that be?
you will need to remove your agitator. There should be a bolt on the top center of the agitator. you will need to remove the top of agitator or the cap to get to this bolt. once you loosen this bolt the hole agitator shold pull straight up.
Now you should see the long shaft in the center. Follow that shaft from the top down to the area where the shaft disappers and ther is a big round nut with 4 notches spaced evenly. This is call the spanner nut and you should use a spanner rench to tighten it with a small sleg or hammer ( a couple of good wacks should do. ) I know you probably do not have this tool, but at least you can verify that this is your problem. your spanner nut may be loose. this nut holds your inner tub down to the block. here is the break down
Jan 08, 2010 | Kenmore 24032\24036 Top Load Washer
I can't get the wheel to my grinder loose. The locking nut barely locks. Is there any tricks to loosening it up and getting the wheel off so I can put a new and better one on. I don't know if I shouold put...
You should have a pin spanner wrench that fits into the holes on the lock down nut. Hold the shaft with a open end wrench that fits the flats on the shaft.
If you dont have the spanner wrench, use a drift punch to tap the lock down nut to loosen.
Jun 03, 2009 | Black & Decker 7750 4 1/2'' Small Angle...
Whirlpool GCAM2792LQ Top Load Washer Logo
19 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
