Question about Microwave Ovens
Kitchenaid Trash Compactor Model KCCC 151 DBL0 I need the wiring diagram that indicates where to attach the switch panel wires to the respective switches. The wires have connectors to simply attach to the switch blades. I cannot find this diagram. At Kitchenaid and Sears it is "not available" and no image is shown. Thanks for your help.
SOURCE: Whirlpool Control Panel Repair
model # MH6150XLQ
LOST POWER. I CHECKED WALL RECEPTACLE. IT'S GOT POWER.
MICROWAVE IS DEAD. NO LIGHT..........NOTHING.
WHAT'S HAPPENED?
Posted on Jun 16, 2008
SOURCE: wiring diagram Problem - Maytag MMV5207A 1100 Watts Microwave Oven
I have a micro wave national nn-v688w. now the high voltage control bc board which is gos to magnatron is useless i want to use a simple transfomer to oprate. the problem is it works for about 15-30 sec and stop the display say H87. i know i need to bild a new circut to oprate the oven so do hahe an idea.my email; raju karki05@gmail.com. thahk you
Posted on Nov 12, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Wiring Diagram for Microwave Door Switches
It took me a while, but I was finally able to get the FULL service manual that covers these models:
NN-S252BF
NN-S252WF
NN-S262BF
NN-S262SF
NN-S262WF
The wiring of the door interlock switches is shown on page 10.
The best place to order parts for this brand is Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Posted on Feb 05, 2009
  • 2926 Answers
SOURCE: My Jenn Aire Trash Compactor
Try reviewing the info on this site. I was only able to find this model number but it should be close to what you have. There is also customer support lines available for contact Mon - Fri.
http://www.jennair.com/assets/product/TC707S_Use%20and%20Care_EN.pdf
Posted on Jan 24, 2010
  • 506 Answers
Sounds like the motor that turns the reduction gears which ultimately pushes the ram could be seized up. If an object was jammed inside which was to much for the motor to handle it could cause it to draw too much current seize up the motor.
Wiring diagram Kitchenaid KCMS145
There should be a technical sheet hidden behind the controls of the unit, and it will contain a wiring diagram.
You didn't mention your full model with suffix, so I don't know if I have your exact model's but the one for KCMS1145JSS1 is here at my Web site.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Feel free to contact me directly if you need further troubleshooting help.
Nov 02, 2012 | KitchenAid KCMS145J Microwave Oven
Nov 02, 2012 | KitchenAid KHMS2050SSS Microwave Oven
Need a wiring diagram for the kitchenaid downdraft-/motor control switches
We have many of these schematics, but we would need the full model number with any suffix in order to provide you with free assistance.
It is usually found on a tag located inside the cooking cavity or around the door frame or controller frame.
Since FixYa is still not notifying us when you respond to clarification requests, you will have to post a new help request with your model number and symptoms / questions.
Or feel free to contact us directly here for free help.
Sep 16, 2011 | KitchenAid Microwave Ovens
Kitchenaid trash compactor bought in 2000; no model/serial number found. Compactor was stuck in partial down position; worked the drawer out and found cotton fibers wadded/stuck at top of the up/down...
at the top, above the ram, there are two switches. One is the reversing switch (should have 4 wires), the other is the stop switch (2 wires). I suspect that the switch arm is bent, due to what you just described, and fails to activate the switch to stop the motor when the ram is at the top position.
May 24, 2011 | KitchenAid Microwave Ovens
My Jenn Aire Trash Compactor Model TC507B1 does not turn. When I turn the start knob to on position, the compactor makes humming sound, but it does not seem that the ram is moving. I have checked the...
Jan 24, 2010 | Microwave Ovens
My Jenn Aire Trash Compactor Model TC507B1 does not turn. When I turn the start knob to on position, the compactor makes humming sound, but it does not seem that the ram is moving. Now, I can't even open...
We had the very same problem. Pull the compactor out and unplug the unit. Lay it on its side and remove the bottom. This will expose the chain and gears. On our unit, the plastic sprocket was broken. This part turns the chain to make the ram go up and down. When I called about a local location to buy a new part, I was given 1-800-688-9900 to phone for help. Tell the automated service you want "parts" and you will get an operator. I described the part and she said that is was no longer made in plastic -- it's now metal. The part number she gave me was #675370. I could've ordered the part through them and would receive it in 3 business days. With our zip code, she was able to give me two locations in our area to get the part. One place had the plastic part -- no thanks. The other place was able to get the part in the next day. Hope this helps more than solutions 1-3.
Jan 23, 2010 | Microwave Ovens
Need to remove kitchenaid microwave model kemc308ksso door to replace spring
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Aug 19, 2008 | KitchenAid Microwave Ovens
Need to Replace Door Handle for KitchenAid Over Range Microwave Hood Combo KHMS147KSS
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
May 07, 2008 | Microwave Ovens
Door indicator prevents microwave from starting
This is usually an indication of a bad door interlock. Take resistance readings with the power turned off on the primary and secondary interlocks. You will need to remove the control panel to access them. There should be a wiring diagram somewhere inside the control panel to assist you in determining if the interlock is normally OPEN, or normally CLOSED. As you open and close the door the interlock should change states. Additionally, double all your connectors to make sure they are plugged in correctly. I had a similar problem once and it turned out to be a loose connection on one of the interlocks. I hope this helps you.
Aug 04, 2007 | KitchenAid KBMC140HSS Convection/Microwave...
Microwave Ovens Logo
49 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
