Question about GE 51583 24Hour Digital Indoor Timer
Does this timer go one and off everyday or just one time/' untill you reset it again
I do not have a manual for GE 51583 timer.
http://waterheatertimer.org/GE-timers-and-manuals.html#51583
Generally speaking, programmable timers are set one time, and then they repeat that program day after day until timer malfunctions or you reset programming.
If your timer is resetting itself, then electricity might be going off, for example a loose wire?
Try timer on another outlet.
Test outlet with cheap circuit analyzer from home center.
It is hard to answer question without guessing until I can read the manual.
If you have instruction manual, I would enjoy getting a copy.
Scan manual page(s) into jpeg/jpg format to your computer and then add a comment with those photos so I can see instructions.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 28, 2011
Woods timer 50029
For the WOODS Model 50029 Indoor 7 day digital timers with Astronomic features.
125Vac 60Hz
1/2 HP
8A / 1,000W Tungsten
15A / 1,875W General purpose
15A Resistive
500 VA Electronic ballast
120Vac 60Hz 8.3A Ballast
Instructions:
Charge the Battery:
Plug the timer into wall outlet for 30 minutes to charge internal battery. Note: You can then unplug the timer from the wall outlet and comfortably hold it in your hand to program the timer.
Clear the Memory:
Press the RESET button with a tooth pick to erase any previous settings.
Note: Inactivity for approximately 30 seconds and the timer will return to clock mode.
To Set the Clock:
1. Press the TIME button to set the current year: Then press the "+" or "-" button to adjust the number from 2012 to 2099.
2. Press the TIME button again to set the month: Press the "+" or "-" button to adjust the number from 01 to 12.
3. Press the TIME button again to set the date: Then press the "+" or "-" button to adjust the number. The maximum date will depend on which month you choose.
4. Press the TIME button again to set the daylight savings time feature. DST will appear on the bottom of the display screen. Then press the "+" or "-" button to set DST AUTO mode or DST OFF mode.
5. Press the TIME button again to set the hour: Then press the "+" or "-" button to adjust the number from 00 to 59.
6. Press the TIME button again to set the minute: Then press the "+" or "-" button to adjust the number from 00 to 59.
7. Press the TIME button again to set the Astronomic function: Then press the "+" or "-" button to select the zone you are in. North = "nor", Center = "cen", and South = "sou".
8. Press the TIME button again to adjust the Sunrise time. Press "+" or "-" button to adjust the time.
9. Press the TIME button again to adjust the Sunset time. Press the "+" or "-" button to adjust the time.
10. Press the TIME button again to finish the setting or press and hold the TIME button for 4 sec that will to back to standby.
To Program the Timer:
1. Press the PROGRAM button once to display the first ON setting.
2. Press "+" or "-" button to adjust the day or group of days you want for the program. Scroll to select from everyday, each individual day, weekdays, or weekends.
3. Press TIME button to set the hour. Press "+" or "-" to scroll through 12-hours AM, 12-hours PM, sunrise time or sunset time for first on setting.
4. Press TIME button to setting the minutes. Press button "+" and "-" to adjust from 00-59.
5. Press the PROGRAM button again to display the first OFF setting and repeat steps 2 through 4 to program.
6. Repeat steps 1 through 5 for additional ON/OFF settings.
7. Press the "MODE" button once, at any time exit time setting or program setting.
Sun tracking technology: the timer adjusts automatically to sunrise/sunset times. For example, program lights to turn On at sunset and Off at 10:00 pm. As daylight hours extend, the sunset time will increase. For example sunset may be at 5:41 pm on Monday, 5:42 pm on Tuesday, and 5:44 on Wednesday. The timer will adjust to this On time accordingly and will always turn off at 10:00 pm as programmed.
To Connect/Operate the Timer:
Plug device in to the timer and turn the device on. Plug timer into wall outlet.
To Operate the Timer / Use Manual Override Function:
Press MODE to choose different function between ON, ON AUTO, ON RDM, OFF, OFF AUTO, OFF RDM
1. ON - load is ON permanently in manual mode.
2. ON AUTO - AUTO mode has been selected and load has been forced ON and will stay ON until a contrary scheduled event.
3. ON RDM- RDM mode has been selected and load has been forced ON and will stay ON until a contrary scheduled RDM event.
4. OFF - load is OFF permanently in manual mode.
5. OFF AUTO - AUTO mode has been selected and load has been forced OFF and will stay OFF until a contrary scheduled event.
6. OFF RDM - RDM mode has been selected and load has been forced OFF and will stay OFF until a contrary scheduled RDM event.
Random Setting Security Feature:
When the random setting is ON, the timer will turn ON/OFF +/- 30 minutes around program on and program off times.
Daylight Savings Time Feature:
When the DST function is on "DST AUTO", the sunrise and sunset time will increase 1 hour on the Sunday of the second week in March at 02:00 am every year. It will then decrease 1 hour on the Sunday of the first week in November at 02:00 am every year. For example if sunrise is 6:12 am on March 9th, it will be 7:11 am on March 10th.
Consumer Support (800) 561-4321
www.colemancable.com
Dec 16, 2013 | Hardware & Accessories
The auto mode isn't working on my zilla digital 24-7 power center, when on auto mode no lights come on?
Copy following link to identify timer:
http://waterheatertimer.org/GE-timers-and-manuals.html#zilla
Is this a new timer??? Or old timer that stopped working?
Replace battery.
Press reset button to clear all memory traces before programming.
Check programming for overlaps and mismatched day(s) of operation.
Test outlet for correct polarity and grounding using circuit analyzer.
Make sure light bulb is turned ON. Timers do not reach out and rotate on-off switch.
Make sure outlet has at least 80% rated voltage shown on load label. For example 115 volts x 80% = 92 volts
About your specific programming needs:
Zilla selects 12 o'clock as changeover time between am-pm.
So if you want 8:02 to 7:59 operation, then that is under the 12 hours, but it crosses the 12 o'clock am-pm changeover.
Workaround: Shorten your times to less than 12 hours just like you have done.
But set current time differently so 8-8 falls under either am or pm, but does not cross am-pm. The timer does not actually know what the current time is, so simply fudge by amount needed.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 18, 2012 | RTO Zilla 24/7 Digital Timer Power Center
Instructions for Bowflex WR30M?
In time mode, hold set (bottom right button) to change date and time. The selected (flashing) item can be changed in one direction only using the up (top right) button. Press set again to cycle through each item until desired settings are chosen.
In stop watch mode, the up button starts and stops the stopwatch, the set button will take a split time while the time is running. To reset the stopwatch, press set once while the time is stopped.
In alarm mode, the up button turns the alarm on and off. There are three alarms available. To cycle though alarm times, press set. To set an alarm, press and hold set until the time flashes, then set the alarm time using the up button, cycle through hour and minutes using the set button. When finished, press set again.
Timer mode. To set the timer time, press and hold set until the time flashes. The timer goes up to 23h:59m:00s. You cannot set seconds. Once set, the timer can be started and stopped using the up button. There is no reset for the timer, to start a new timer the time must be manual changed again.
To check heart rate, press and hold mode until PUL is shown, place two fingers, one each on the top and bottom metal contacts for 6-10 seconds to get reading (This works best when not in motion).
Apr 13, 2012 | Watches
I bought a Major Tech Mtd9 programmable timer but there are no instructions included, only features. I have no idea how to set the date and the timer. Say I want the light to switch on at 6PM and switch...
First press reset (use pen or paperclip). Press MOVE button until you get OFF at right bottom of screen, then press SELECT to select mode (to set time and date, to select on/off for the 2 timers or to select rundown timer. Use OK to move to different setting, eg. hour,minute, year,month day etc. Use SELECT to change up one digit at a time. Play around with buttons to change settings, for example to have timer on on a specific day of the week or everyday etc. When it is set, use move to change from OFF to AUTO, timer will then switch on and off at set times. Hope it helps
Jul 31, 2011 | Kitchen Appliances - Others
Jvc model av36f702 it jumps of evry time im trying to put it on with the remote . i tink the timer is set to 0 secones .can i reset the tv.
press display button & it shows the following
07
NOW 12:20 PM
SLEEP TIMER OFF/on
ON/OFF TIMER EVERYDAY
ON TIME 7:00 PM
OFF TIME 10:00 PM
• The current channel or AV input (Channel 07)
• The current time (12:20 pm)
• Sleep Timer status/minutes remaining (The Sleep Timer is off)
• On/Off Timer status (Set to turn on everyday at 7:00 PM, off at 10:00 PM)
• Each Press of the DISPLAY button changes the display mode:
Press the SLEEP TIMER button & set it to OFF
Dec 22, 2010 | JVC AV-36F702 36" TV
How do I program a Noma N1506 timer?
All Woods timers and manuals
ttp://waterheatertimer.org/Woods-timers-and-manuals.html
N1506 manual:
http://waterheatertimer.org/pdf/Woods-49122-N1506-manual.pdf
N1506 is heavy duty outdoor timer with display screen.
Plug timer in and display flashes C.
Set current time: press Time button once and display shows 1 am
Keep pressing time button until current time with am pm displays.
Dot in lower right corner corresponds to pm hours.
To set timer program:
Press Mode button, display flashes P
Press Time button until desired ON time displays.
Press Mode button again and display flashes E
Press Time button until desired OFF time displays
When programming is finished, press Mode button and display shows current time.
To reset timer, unplug timer for 10 seconds and re-program timer.
Timer must be reset after power outage. Display will warn by flashing C.
Plug lights into timer.
If lights have a switch, switch must be on.
For manual override, press Mode button, and display shows O and lights will be ON until next program change.
To use timer function, press Mode button until current hour displays.
Dec 12, 2010 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
How do I set the Woods N1506 timer?
N1505 timer manual:
Dec 01, 2010 | Woods Outdoor Lighting Timer
Model N1506, I need Operation instructions for this Woods Light Timer?
N1505 timer manual:
Dec 01, 2010 | Hardware & Accessories
Clock is set properly. I want to turn on outdoor lights at 5PM everyday. In addition I want to turn off the lights each night at 11PM. Problem - When I go thru the process of turning on the lights it...
I answer questions for free.
I know timers and electrical devices, and have tested most of the brands.
You posted under the Woods 7-day timer 59018 or 59028.
Here is the manual:
http://waterheatertimer.org/pdf/Woods-59018-59028.pdf
There are several programmable timers today that look like Woods, and each brand has different programming.
If you do not have Woods, add a comment and I will walk through programming your brand
1) You have the clock set correctly which implies the wiring is correct. Good job!
2) Programming review:
Each program requires ON time to be set, and then OFF time to be set
For example you set Program1 ON 5:00PM for ALL days.
And then you set Program1 OFF 11PM for ALL days.
3) Programming steps:
Press PROG button until Timer 1 ON appears on display
Use Hour button to set 5 PM
Use MIN button to set :00
Default selects ALL days
(If you want other days, press DAY button until display shows correct block of days)
Press PROG button again to save Program1 ON
4) Now for Program1 OFF
5) To set Program1 Off
Press PROG button until Timer 1 OFF shows in display.
Use Hour button to set 11 PM
Press PROG button again to save Program1 OFF
6) Program 1ON and Program1 OFF have been set ... so press the CLOCK button to return to current time.
If you want to set another program, press PROG button until Timer 2 ON displays
7) After setting programs, press Clock button so current time shows.
8) The manual shows one more thing ... if you program the timer during the hours 5-11pm, and the timer should be ON during those hours, you have to 'tell' the timer to turn ON by pressing the manual override ... after that the timer will operate normally.
If you need more assistance, add a comment.
If instructions help, give it a 4-thumb
Nov 10, 2010 | Woods InWall 7 Day Digital Programmable...
Stereo Turns On By Itself
You must have the timer set. Press CLOCK/TIMER button repeatedly until the clock symbol or the word REC with the clock symbol disappears.
Nov 04, 2007 | Aiwa NSX-MTD9 Shelf System
GE 51583 24Hour Digital Indoor Timer Logo
88 people viewed this question
Top GE Hardware & Accessories Experts
George Nalley
Level 1 Expert
Paul Bade
Gene Haynes
Are you a GE Hardware and Accessory Expert? Answer questions, earn points and help others
