Question about Acer Aspire One Netbook 8.9" Notebook
No bootable device on my acer net book - Acer Aspire One Netbook 8.9" Notebook
    Master:
  • 525 Answers
Hi there. So you are having some trouble with your netbook? Well theres something you can do to try and get it running. The first thing to do is flip your netbook over and lay it on a flat surface. Get a philips head screwdriver. Look for the cover that has a symbol that looks like 3 cds in a row. This is your hard drive cover. Remove the cover and carefully take out the hard drive. Put the hard drive back in and make sure it is secure. Put the cover back on and screw it back down. turn over your netbook and power it back on. Hopefully it boots up. If the same message appears then you will have to replace the hard drive. Good luck...
Posted on Mar 27, 2011
  • 734 Answers
HI There,
I recommend you find a friend with an external CD/DVD drive. You'll need to have an XP Installation disc and boot from the disc from the external drive. Let the disc run through Setup until you reach the point where you can choose the R key for Repair.
At this point you'll be shifted to a DOS Prompt Command Cursor. Type (all in capitals) FIXMBR. Shut down the computer, disconnect the external drive. Start the computer and if your hard drive is not dead you'll have fixed your Master Boot Record and you should start normally.
Regards,
Selk
4 Suggested Answers
SOURCE: my acer aspire one says no bootable device
This sounds awful, but a friend just had the same problem - no bootable device. He had dropped it, hitting keyboard first. Now he thumped it on the opposite side and IT WORKED! Must have been a loose connector
Posted on Jan 16, 2010
  • 45 Answers
SOURCE: my acer aspire 4810t says no bootable device
enter BIOS - you will see a mesage when you first turn on laptop tellign you to press a key to enter setup. Do this and make sure HDD is listed. if it is, you might have todo a recovery.
Turn on laptop, then immediatly press ALT + F10 keep finger on ALT and press F10 a few times, this will start the recovery process. some ask if you want to re-install windows or full factory reset. Windows install will only repair it - full factory reset will delete any data you have! so be careful
Posted on Feb 14, 2010
pappapumpdaf
  • 635 Answers
SOURCE: for Acer Aspire One Net
Your netbook is trying to boot from your Lan/Ethernet connection since It can find no working hard drive to boot from. This usually means that your hard drive has failed.
Also remember that your netbook will try to boot from other drive types including your SD card, USB Memory Stick and even a Magic Jack if you have one inserted in the flash memory slot or USB slot while rebooting the PC.
Many people have mistakenly assumed that their Netbook is messed up because they forget to remove all flash and memory sticks before rebooting.
Posted on Oct 31, 2010
My acer aspire says no bootable device how do i fix it
Hello there.
No bootable device can, if really bad mean your hard drive is kaput and you will not be abler to recover. Thankfully this is REALLY rare.
If the machine has not had the operating system replaced since new, then you can restore from the recovery partition. Instructions for Acer all over the net but try here http://www.pctechbytes.com/acer/acer-aspire-system-recovery-partition/
On the other hand, if the Operating system HAS been replaced, then you need the installation CD for the Operating System which you have on the machine (XP or Win 7 ?) and use the REPAIR facilty
Sep 08, 2014 | Acer Aspire Computers & Internet
My net book
Try re-installing the WEBcam driver.
Download the WEBcam and device drivers from the Acer WEB site. Make sure you select the model of your laptop the drivers you that require that matches the Windows version that is installed on your laptop. Use this link to get to the Acer support: -
http://www.acersupport.com/drivers_download.aspx
Jan 24, 2013 | Acer Aspire One Netbook
I have acer net book and it keeps saying no bootable device insert boot disk and press any key
Try a "Cold-Start", Remove AC plug, Remove Battery, Hold down on/off button for 10 seconds, Replace battery, Plug inti AC outlet,Push on/off button and Start normally. If that fails, Re boot while tapping F-8 to view options. At boot try esc or F-2. I don't know your Make ,Model, or OS? You didn't give much info so it's hard to make a informed suggestion. Did you do a install or upgrade your OS?
Nov 05, 2012 | Computers & Internet
Pxe e63 error while initializing nic no bootable
here we go >
power on your netbook press delete to go to bios setting goto boot or boot device priority then set it to harddisk(your current setting is pxe or network boot) then press f10 to save enjoy
thanks for using Fixya
Jun 01, 2011 | Acer Aspire One Netbook
My acer one net book just says no bootable device insert boot disc press any key
if ur OS is good, i mean not formatted or u just formatted the system. check ur bios, boot devices, put ur cd/dvd drive on top then save and exit and restart.
Dec 06, 2010 | Acer Aspire One Netbook 8.9" Notebook
My acer aspire 4810t says no bootable device
Feb 14, 2010 | Acer Computers & Internet
How do i resrore my acer aspire laptop without the dvd drive working?
youe have to have any bootable device either usb bootable drive or any other optical device that can be used as bootable device
Oct 09, 2009 | Acer Aspire 5100 Notebook
Ha man i have a problem with my acer aspire one net book
connect the power supply. Check if the battery is properly installed. Then try to boot with a bootable cd
Aug 06, 2009 | Computers & Internet
My acer aspire one says no bootable device
Jun 03, 2009 | Acer Aspire 4315 Notebook
Initial set up problem. Acer net book
this small laptop does not comes with cd rom,So you can arrange a USB Optical drive.In bios setup please check for boot sequence is to be set for usb boot device.Now insert the bootable cd or Operating system cd with boot files & it ill works
Mar 14, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire One Netbook 8.9" Notebook Logo
135 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
