Question about Car Audio & Video
I am get fault code from porsche cayenne. the fault code is p1025 fuel high pressure adaption. when you acceleration a few time, the fault code will appear after delete the fault. before this i get the fault code p1025 and p1026(fuel high pressure implausible) and car underpower), after change the fuel high pressure pump, the car is full power but the fault code(p1025)still appear. can anyone help me to solve this problem???
  • Anonymous Mar 17, 2014
    Porsche Cayenne Fault Code P0846
    Porsche Cayenne fault code p0846 - HOW TO FIX THIS PROBLEM ?
Try to use one of the extra key to start it, sometime the security code from the main key might not function.
Posted on Oct 11, 2012
  • 3 Answers
Perform throttle adaptation and engine torque loss adaptation. You will find this function under DME using PIWIS tester.
lagos porsche
Posted on Apr 01, 2011
1986 porsche 944 dont pass ca smog running too lean
Probably Nox too high. Can also be engine too hot. Last time cooling system serviced? Also can be carbon in the combustion chamber ignites fuel too soon. Fuel delivery system and all sensors may be a problem. Bad or corroded connections can contribute to bad behavior of the ECU.
Apr 08, 2015 | 1986 Porsche 944
2003 porsche cayenne acceleration when I put foot on gas b paddle it stalls like it sont want to go then takes off really fast car has did this to me several times but this time it went up to 100mph a
You need to take it to a Porsche dealer to have the computer software updated. The sooner, the better! Until then, turn off your PSM (Porsche Stability Management), to see if that helps.
Nov 29, 2014 | 2003 Porsche Cayenne
My cayenne s
This could actually be a fault in the quite a few different modules.
It could be the centre console buttons, or even the main module.
Unfortunately you need to get VAG-COM or VCDS to see the error codes.
I used a Ross-Tech cable and determined the issue was a failed module.
Any VW, Audi or Porsche service place can connect in and see what the car is reporting.
But this may be best to let Porsche run diagnostics.
Also if it is a module, dealerships tend to have to replace them.
As second hand modules have a CP protection lock on them.
May 12, 2014 | 2008 Porsche Cayenne
2004 Porsche cayenne 3.2L trouble codes po261,po264,po267.
I'm not 100% certain as these codes are for a V8 (DME 7.1.1 - Cayenne (955) MY03-04) but these may be in the ball park.
P0261 Fuel Injector, Cylinder 1 - Below Limit
P0264 Fuel Injector, Cylinder 2 - Below Limit
P0267 Fuel Injector, Cylinder 3 - Below Limit
One other option, there is a company who make a specific-for-Porsche OBDII reader - here for your car: Durametric
Good Luck!
Sep 16, 2013 | Porsche Cayenne Cars & Trucks
Engine management malfunction
Hello
When the service engine soon light (Also called the check engine light or engine management light) is turned on this is to alert you to the fact that Powertrain Control Module (computer) has detected a failure somewhere in the systems it controls you may not feel any difference in the way the engine runs, this can be the transmission or the engine or emission system, there are fault codes set in the modules memory for these faults. What needs to happen now is to have the powertrain control module scanned with a special tool called an OBD2 electronic engine control scanner or a OBD2 code reader. Once the code(s) are read then you must perform the diagnostics for each code and make the appropriate repairs based on the findings of the diagnosis that was performed, this is called doing "Pinpoint" testing.
Aug 29, 2012 | 2011 Porsche Cayenne
2004 porsche cayenne.. when I start the my vehicle, it will run for 15 seconds, and then shut off... What could it be ??
it sounds like fuel pump only start prime is working or computer fault or air lock maybe
Jan 18, 2011 | 2004 Porsche Cayenne
Radio/nav system dead
I have 2010 Porsche Cayenne and Nav screen just goes black and turns back on - sometimes it does it few times a day sometimes its working fine ..any idea?
Jul 13, 2010 | 2006 Porsche Cayenne
Starts but stops in about 10 seconds
The fuel pump relay is at fault
The fuel pump works off the oil pressure switch when the engine is 1st started
When the oil pressure reaches its normal range the computer shuts it off and lets the fuel pump relay take over which yours does not work no longer
May 25, 2010 | 2004 Porsche Cayenne
Car Audio & Video Logo
1,426 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
