My WXGA 15.4" LCD laptop screen for DELL Inspiron 6000 is temperamental. Works most of the time, but when I start up computer the bottom 1/2 of screen looks like color streaks down it (all blury/fuzzy color mish /ash). I fixed problem for a while by putting pressure on LHS of screen about 1/2 way down (seems like a loose connection). But now it's getting worse. Any ideas of how to fix this? Ivan.
  • 3,940 Answers
The issue could be one of 2 things. The image inverter or the LCD. From the description it could be either.
Both can be found here:
http://search.ebay.com/search/search.dll?from=R40&_trksid=m37&satitle=inspiron+6000+LCD&category0=
The inverter is fairly cheap ($20 to $50) the LCD around $150.
Service documents are here:
http://support.dell.com/support/edocs/systems/ins6000/en/sm/display0.htm#wp1006390
Posted on Aug 04, 2008
SOURCE:
I installed two new 1 gigabyte memory sticks into a Dell Inspiron 6000, which previously only had 2 256 megabyte memory sticks installed. When I first installed the 2 gigs of new memory, the laptop turned...
Once you installed the memory, did you enter into the System BIOS Setup screen? Do this and verify that the system recognizes the newly installed 2GB RAM. This should let the system access the new memory once you boot.
Jan 01, 2011 | Dell Inspiron 6000 Notebook
LCD Screen Repalcement
thats the screen problem u should change the screen than it gonna be alright,
Oct 10, 2009 | Dell Inspiron 1521 Laptop
Dropped my laptop- screen cracked
I would recommend locating a local computer repair shop that doesn't have a well known name around your town.
They tend to keep many extra parts of laptops lying around and it's as simple as finding a match and replacing the LCD panel.
The smaller shops may have better deals than the larger, but it might be smart to contact Dell as well on the same matter.
Jul 23, 2009 | Dell Inspiron 1525 Notebook
Can I use WXGA 15.4" lcd panel instead of WXGA+ 15.4" for E1505?
Seeing that the upgraded version was your previous version, go ahead with the screen change' it should be fine.
Hope I helped
- donman92
Jun 10, 2009 | Dell Inspiron E1505 Notebook
The monitor in my computer turns dark when i turn the laptop on
That sounds like you have something loose ..
Here is an on-line service manual for that
I would look specifically @ the LCD/monitor lead and its connections
Jan 01, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron 6000 visual going bad
restart your computer and go to settings and test your color maybe that should do the trick
Dec 18, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Laptop LCD Problem
This is most likely going to be a loose connection. You will need to take the the plastic bezel that surrounds the screen off, the screws are hidden under the small rubber bumpers. Then take the screen loose, you will see he four screws holding the screen at the sides. Tilt the screen forward and you will see the connection on the back. Make sure this connection is seated properly, you may need to apply some new tape on it if it has any. Then check any other connections while you're there. If the problem persists, then the cable may need replacing.
Jul 31, 2008 | Dell Inspiron 6000 Notebook
Problems with Dell Inspiron 6000 Battery ? DELL Inspiron 6000 laptop battery is popular, why ?
You can also pick up the batteries less expensive than most computer places at batteries plus. And yes it sounds as though it is the batteries charge is getting low, especially if it runs fine when the battery is out and you have it plugged in.
Mar 13, 2008 | Dell Inspiron 6000 Notebook
Dell inspiron 1150 laptop black screen
Can you hear the Windows startup noises but can't hear it?
Does it work plugged into an external monitor? (Any good CRT or flat screen should work.
Be sure to plug in the screen before you turn it on.
If it doesnt output to the LCD automatically you may have to hit FN-F8 to switch to external.
If it works on external monitor you are just dealing with a screen problem of some sort - either a bad inverter or backlight in the LCD most commonly...
Let us know.
Dec 17, 2007 | Dell INSPIRON 6000 CENTRINO...
Open Questions:
Computers & Internet Logo
52 people viewed this question
Ekse
Alun Cox
