Question about Vacuums
Need power cord for corning ware warming tray model p-54
A percolator cord, available at any hardware store, works just fine.
Posted on Oct 04, 2012
Replace power cord on Hoover windtunnel vacumm
There are many different models of Hoover Windtunnel so I can't be specific to your model, you will need to determine where the cord enters the unit and how to gain access to the internal wiring. Disconnect the old cord and attach the new cord using the proper connectors.
Apr 02, 2017 | Hoover Vacuums
How to replace a power cord for a hoover vacuum?
Please add the specific model number, for example, Hoover vacuum, ECOVAC 497A.
Is this a wrap up power cord where you wrap it around two lugs on the vacuum, or is it a rewind type where the cord is wound inside the body of the vacuum?
Cheers.
Aug 15, 2014 | Vacuums
S5830 canister vacuum
Do you mean S5380?
Phone local vacuum repairers and ask for estimates. The power cord is only fairly cheap. I would have thought that even with expensive labour it should cost less than 100$. He's probably trying to cover himself in case its something else. Have you contacted Miele? it is worth asking for a price if they'll give you one
Miele Inc Anything Else is Compromise
As far as replacing the cord yourself, it's not as simple as just connecting it, i think it has to be put on a tensioned drum.
Heres some more info
How to Access the Motor and Cord Retract on Miele S326
Miele vacuum cleaner repair
May 20, 2014 | Miele Vacuums
Power cord warms up
They do get warm and that is normal. You will see it melt before it catches fire. The amount of electricty that is being used is close to the amount the cord can take.
Feb 15, 2014 | Hoover Vacuums
My cord gets VERY warm when using my Dyson. Not HOT, but very very warm, warmer when closer to the electrical outlet. Should I be worried?
Hi Teresa, it's Jack at Dyson.
I'm sorry to hear you're concerned about the power cord of your Dyson vacuum becoming warm in use. To confirm your machine is working correctly we'd like to take you through some quick troubleshooting checks over the phone.
You can reach our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA). Please have your machine to hand when you call.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Jul 30, 2013 | Dyson DC07 Animal Bagless Upright Cyclonic...
I have a Supremer Ice Creamer by Nordic Ware Model 71024 but cannot locate the instructions. Do you have instructions for this old model? thanks.
Nordic Ware apparently does not have downloadable instrucion manuals but their customer support webpage says that they will mail instructions to you. Call:
1-877-466-7342 8:00am to 4:00 pm CST
An online step-by-step instruction is here:
http://www.ehow.com/how_7323266_nordic-ware-ice-creamer-instructions.html
Good luck from Detroit, MI.
Jul 20, 2011 | Vacuums
How to put a switch in or do i need new one
By the question you asked I assume it wont power on. More than likely its not the switch . More likely its the power cord because it get most of the abuse. you will need a meter in any case to find out . If you don't have a meter you can pick one up for under $10 at any hardware section of most Dept store chains. A good investment. turn the meter to the omega symbol Looks like an upside down horseshoe with feet. touch the leads together meter should zero. place the probes across the end of the power cord plug. One on each tab. watch the meter and flip the switch while holding the plug and probes together. if the meter doesn't move the switch is probably ok. usually the cord plug or the strain relief going into the machine wares out but check the cord for cuts or unusual ware first. if you dont mind a few inches missing remove the bad area of cord and replace. to verify its the swich or not pull the unit apart and put the meter leads across the switch and toggle the switchthe meter should change from zero the some high number. Good luck have fun and learn !
Nov 22, 2010 | Bissell 6594 PowerForce Bagless Upright...
I have a Euro Pro Compact Performer model # EP 171 which I love. It is the best iron I have found for my quilting class. When I went to use it, I found my cats had chewed the cord to the point that it is...
HI. All appliances has warranty on it. Default would be 1 year warranty. If your device is within the one year warranty. you can have it repaired by your manufacturer withut a charge. If device is alraedy out of warranty. you can still have it repaired but you will cover for the damaged part that need to be replaced or repaired in your device. Check the store where you purchased the unit. Maybe they can do something about it.
Jul 01, 2010 | Euro-Pro Vacuums
I just purchased a rainbow D4C, after purchasing i was told i should have purchased the SE model. whats the difference?
There is only one difference between the D4 and the D4 SE, which stands for D4 (Special Edition). It is the exhaust plug screws in on an SE and snaps in on a regular D4.
Then the SE-PE came along, which stands for (Special Edition-Performance Edition) which has a more powerful motor, with larger motor brushes, for more power and runs on 9.8 amps, where the regular SE and D4 run on 8.8 amps. It also has the newer PN-2 power nozzle, which is very much like the latest E and E2 series Rainbow vacuums, instead of the earlier rectangular ones, that have the bottom metal plate, which will rust. You can upgrade your D4 to one of these, though you will need the electric hose with gas pump style handle, with the built in power corn in it.
They are all D4 models.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
Apr 02, 2010 | Rainbow 75th Anniversary Canister Vacuum
Wattage for Kirby Sentria G10D
The conversion of Amps to Watts is governed by the equation
Watts = Amps x Volts
For example 1 amp @ 110 volts = 110 watts
your case 7 amp @ 120 volts = 840 watts
unless you are running it at 230v but I don't think you can
I would look for one rated for Volt-Amps instead of watts
It's best to round up to be safe add 40 - 60 watts
Don
Apr 25, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Vacuums Logo
879 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
