While in the spin cycle we could smell rubber heating up...probably a belt. I recently replaced the coupler and its been working fine for 3 months or so.
  • Washing Mach... Master
  • 2,699 Answers
If you replaced the motor coupling it doesn't have a belt.is it a whirlpool washer?
Posted on Mar 27, 2011
I have a 2012 top loading frigidaire gallery washer. It recently started making a loud thumping noise during the wash cycle. When it spins out it smells like burnt rubber. Any ideas? Thanks
There is a rubber belt between the motor and the rotating cylinder.
If it is frayed, then part of the belt is hitting something during the "wash" cycle, and rubbing much faster during the "spin" cycle.
Replace the belt.
Aug 27, 2015 | Frigidaire Washing Machines
I've got an old Kenmore Stylemaster 902202B. I overloaded it once, it buzzed, I faintly smelled burning rubber, then I took things out and it kept going just fine. The washer does work perfectly on small...
the old kenmore (whirlpool made) washers had the hardest belt to replace. you can do it if you take your time. belts can be matched at a napa auto parts store if you don't want to order online. www.appliancepartspros.com or www.repairclinic.com should have them. part is #95405
Jan 19, 2015 | Kenmore Washing Machines
Burned rubber smell after replacing motor coupler, otherwise runs
The most common cause for the coupler failing is a bad gearcase. The machine should go through a neutral drain before the spin if it doesn't drain the water first it over works the motor trying to spin a full tub. No belt on this one, odor could be from the motor or the coupler starting to shred again.
Mar 01, 2010 | GE Spacemaker Washer and Dryer Electric...
Noisey and recently smells like rubber. maybe a/c
You may have a frozen bearing on the tensioner or belt idler. This will cause the belt to burn and smell. I think you are on the right track. I would remove the belt and spin the idler and adjuster by hand to see that they are free and don't have excessive play in them. Replace as necessary.
Nov 05, 2009 | 1999 Chevrolet Silverado 1500
Crown series 12 cycle washer will not agitate and smells like something is burning like a for instance a vacumme belt kinda smell in that cycle it spins fine fills fine drains fine but just makes a so
It doesn't agitate If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
May 07, 2009 | Frigidaire FWSB5700DS Top Load Washer
GE Top Load Washer WLSR2000G3WW~smells like burning and wont drain
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Nov 06, 2008 | GE WBSR3140DW Top Load Washer
Kenmore Series 70 Washer does NOT spin (coupler is fine).
oil around the inner wall of asing sounds like a transmission assy( ck your manual should have a 5 yr part warr on gearcase)
Mar 06, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag Model # LAT9635AAE
Check to see if it is a pump problem or a transmission problem. First remove both belts see if all the pullys turn freely. if the pump has a tight feel check inside pump for a item jammed in it.look for transmission oil on floor or belts if oil is present transmmision if probably going.ALSO check at the top of the tubs for anything stuk in between tubs.
Oct 10, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Loud noise and smell
It would help to know the brand and model number of the washer. If it has a belt that also runs the pump, something may have gotten into the pump during drain and locked the pump causing the belt to slip.
Oct 07, 2007 | Washing Machines
Open Questions:
Maytag Bravos MVWX700XL2 won't spin the clothes and is making a weird whining/whirling noise when attempting to do so. Hi, I have a Maytag Bravos MVWX700XL2. It's about five years old. For about a year now, it would occaisinally make a weird noise while washing that seemed to come from the agitator working. I know this sounds funny, but the noise sounded like a chittering squirrel. It didn't do it all of the time, just mostly when I would wash smaller loads. Today I noticed while doing the weekly laundry, that the agitator wasn't fully agitating. It was turning back and forth, but very slowly and not "mixing" the clothes like it usually does. I went though two loads like that, and on the third load, when it was time for the washer to rinse and spin, it started to make a whining/whirling noise and it would not spin out the clothes (but it did drain). The control panel is not giving an error code. I removed the wet clothes and tried to have it just rinse and spin or drain and spin empty and the strange noise continued w/o any success. I have a video of it making that noise that I can post/send if someone can tell me how. I paid over $500 for the washer, and I really don't want to have to replace it this soon, nor do I want a $300 repair bill. My husband is very handy and could fix it if we knew how to properly diagnose the problem so we get the correct part. Based on what I've read, could it be the shift actuator or a broken motor coupler?
Jul 16, 2018 | Maytag Washing Machines
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
