Question about Bosch Washing Machines
Bosch washing machine error code f-21 classixx
  • 3 more comments
  • Anonymous Dec 31, 2008
    I have the same issue. Does anyone know what the error means or what is the cause?
    thanks.
  • Gordian Manufor Dec 03, 2012
    can you please explain what is RPM?
  • Anonymous Mar 18, 2014
    f 21 keeps coming up on my machine
    Code F 21 shows in display window. And machine won't work
  • Anonymous Mar 26, 2014
    cannot run washingmanchine classixx 5.2 error 21 appeared
I've had the same problem, when we had a power cut I opened the door and after that I could only got F21 flashing! ,I googled for the answer and this WORKED:
Turn programme switch to 6 o clock,hold RPM button turn switch to spin, release RPM button
Posted on Apr 12, 2009
  • goldenrock Oct 04, 2010
    My machine was down for 6 months until I found this solution which worked right away. Thanks a lot my machine is working again.
5 Suggested Answers
SOURCE: error code F 21
I have a Bosch Classixx 6 1200 express washing machine showing error code F21 on the display, what is it?
Posted on Mar 10, 2010
heatman101
  • 43501 Answers
SOURCE: I have a Bosch Classixx
F21 is a motor or control board fault.
This also can be caused by voltage spikes or surges...
To reset it.
Turn the appliance knob to the off or reset position, 12 o'clock.
Turn the knob to the 6 o'clock position.
Press and hold the spin button.
While holding it, turn the knob to the 7 o'clock position.
Continue holding the spin button for about 5 seconds.
Release the button.
Turn the knob to off.
When your turn it back on it should have cleared the error code
If the problem continues then check the motor...
heatman101
Posted on Nov 29, 2010
SOURCE: Bosch Washing Machine - Model Classixx 1200
test test test test test
Posted on Apr 27, 2010
  • 662 Answers
SOURCE: I have a Bosch washing machine /classixx 6 12 Expr...
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently.
Pl rate me 'very helpful' for the free help, thanks
Posted on Jun 14, 2010
Hi Washing machine BOSCH Maxx 7. Displays error F 21. What's wrong - and what can we do ? sincerely,Jette
The F21 error code indicates that you have a problem with the washing machine's motor.
Have it checked out by competent electrician.
Feb 22, 2015 | Bosch Washing Machines
How can i open the door of a bosch washing machine with F:21
Hey there, welcome to Fixya! The above answers were pretty helpful, did you fix your problem with them? Did you check the manual for further instructions? You can find a PDF copy here: Bosch Classixx 5 Manual
Jul 13, 2014 | Bosch Classixx WFO 2866 Front Load Washer
Hi, How Can I Reset error in my wash machine Bosch
You can reset the error code by the follow steps.
Turn the knob to the off or reset position, 12 o'clock.
Press and hold the spin button and while holding the spin button turn the knob to the 7 o'clock position.
Continue holding the spin button for about 5 seconds then release the spin button and now turn the knob to off
When your turn it back on it should have cleared the error code.
Sep 26, 2013 | Bosch Washing Machines
F:21 any ideas?
Hi
Check out the brushes in the motor because thats what F:21 is related too .Change the brushes of the motor that will clear the error code.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 02, 2011 | Bosch Classixx WFL 2066 Front Load Washer
What does f21 error mean and can i fix it
From the user manual in English:
F:21 - Motor fault. Call customer service
Nov 28, 2010 | Bosch Classixx WFO 2866 Front Load Washer
Got the Bosch Classixx 6 1400 Expresswashing
I have the same problem - Did you mange to sort it out?
Mar 23, 2010 | Bosch Classixx WFO 2466 Front Load Washer
Keep getting error f17 on my bosch classixx 6 washing machine
My old Bosch only had a filter in the machine (where the hose attaches. My Exxcel has a filter IN THE HOSE at the tap end too. I removed that one and it made a big difference !
Dec 17, 2009 | Bosch Classixx WFO 2866 Front Load Washer
Error code F 21
Apr 05, 2009 | Bosch Classixx WFO 2866 Front Load Washer
Washing Machines Logo
1,469 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
