Question about GE WBVH6240F Front Load Washer
I Have Ge Hydro Heater WCVH6400JIWN front laoding washing Machine. It will not Spinn, the washing machine seems to do a wash cycle the drum/motor turns but does'nt spinn. I purchased a new invertor and fitted it, I went through the fault programs and on the fault memory it came up with code E46/48. The travel bolts are out and it sits on a solid floor. Any ideas Brett
  • Brett Williams Mar 27, 2011
    Thanks,
    Is it usaul that the motor works in the wash mode but won't spin. Is this a common fault?
    Brett
    Guru:
  • 262 Answers
I do not have the exact model number/service manual but the error codes will be the same along with the possible/cause and action
There should be a tech sheet located on the back panel,inside the back panel or inside of the control panel.
  • E46--Drive motor--Over temperature, Inverter over temperature
  • Check Motor - t10 tumble, t11 spin, T14 spin.
    Power down (unplug) washer, wait 30 seconds and
    retry - use whites cycle sanitize temperature - if
    reoccurs, replace drive motor. (Note: Cannot occur
    with open winding.)
  • E48--Drive motor--Open motor phase
    Check motor for open winding - if OK, replace
    inverter. (Note: Occurs with open winding.)
  • The tech sheet will tell you what pins to check on the motor or maybe the t10-t11-t14 is correct. Since you have already changes out the inverter then I guess the only thing left would be the motor according to the manual.
    Posted on Mar 27, 2011
    • Keith Drake
      Keith Drake Mar 27, 2011
      Not unusual....but it does raise a red flag.
      Why don't you give me over night....I want to see if I can come up with the motor schematic.
      When you wake up in the morning you should have a answer or more info from me.
      Keith
    • Keith Drake
      Keith Drake Mar 28, 2011
      Let's try this....checking motor windings
      The motor assembly consists of a reversible,variable speed, 3-phase induction DC motor, and sensor. The motor drives the tub drive pulley with a 7-rib belt. The sensor monitors motor rpm and is connected to the control board. The motor assembly is checked from the front of the washer and removed from the rear.
      There are 2 methods to check the motor assembly.
      Method A:
      Remove the service panel. (See Service Panel.)
      Disconnect the motor wire harness.
      On the motor plug, check for an approximate
      resistance value of 6 ohms between any two of the
      three wires:
      Blue to white - 6 ω
      Blue to red - 6 ω
      White to red - 6 ω
      The sensor has a resistance value of
      approximately 118 ω between the two orange
      wires.
      Specific failures associated with the motor assembly
      can initiate error codes E42, E48, and E49
      Method B:
      Remove the single Phillips-head screw that holds the right front leg of the inverter to the base pan.Slide the inverter rearward to clear the guides that hold the rear of the inverter to the base pan.Position the inverter to access the inverter
      board.
      On the inverter board, check for an approximate
      the three terminals:
      A to B (Blue to white) - 6 ω
      A to C (Blue to red) - 6 ω
      B to C (White to red) - 6
      ω
      Note: The sensor and sensor wiring can be checked
      at the control board. Check for a resistance value
      of approximately 118 ω resistance between the 2
      yellow wires located on the wire harness located at
      P9.
      Method A:
      three wires:
      Blue to white - 6 ω
      Blue to red - 6 ω
      White to red - 6 ω
      wires.
      Method B:
      board.
      B to C (White to red) - 6 ω
      P9.
    The drum seems loose. When it spins to let the water out it will spin good then all of a sudden it will bump loudly
    Search Results
      How to Diagnose Drum Problems in a Washing Machine ...
      ? 7:48
      https://www.youtube.com/watch?v=wUL5Wb1T71c
      Nov 19, 2013 - Uploaded by eSpares
      For all your washing machine spare parts go to http://bit.ly/1DumBrv The most common fault in a washing ...
      GE Washer Top Loader Out of Balance Shaking Repair ...
      ? 14:19
      https://www.youtube.com/watch?v=GA98ZmnzEfc
      Jul 12, 2014 - Uploaded by Mike Davies
      GE Washer that Shakes and is Load during Spin Cycle. step by step ... Washer Tub Seal Replacement - GE Top Load Washing Machine ...
      GE Front Load Washer Inside Drum Loose - YouTube
      ? 0:46
      https://www.youtube.com/watch?v=P8EcTTL2lcI
      Apr 4, 2013 - Uploaded by Wayne Meador
      I need help with my GE Front Load Washing Machine!!!! If you or anybody that you know can help me fix this, I ...
      Kenmore top-load clothes washer drum/tub is loose and bangin
    Jan 08, 2016 | Washing Machines
    GE Washer stuck in wash cycle and not draining.
    humming is usually the result of bad motor windings , are u saying it washes for 20 minutes or just stays on that cycle without doing any washing? a non moving drum can be a bad motor coupler or belt if belt driven.
    Mar 30, 2015 | GE Washing Machines
    Telmann TEL6TL washing machine doesnt spinn properly, brake motor not activated
    replace whole mechanism if cheeper than replacing unit and dont want to pay a pro
    Jun 19, 2012 | Washing Machines
    I have a siemens waching machine model no wd11640hkbu. few days back when we were running a wash + dry cycle, while it was on the last 5 minutes of the dry cycle, there were loud banging noises and some...
    Front laod washers have a heater element The siemens is mounted at the front of the drum Most likely the heater is burnt out and will need to be replaced. not a difficult problem. The heater has probably burnt itself into an open circuit situation and so the machine now still works. it may not work right through a cycle if temperature is selected other than cold.
    You should not have to repalce the machine for the sake of a heater if tis is the case. Why not call knowlegable technician to ascertain this problem. For someone to assume the motor is burnt without looking is not thorough. The banging noise may have been the drum hitting against the burnt out heater element. Good luck
    Aug 01, 2010 | Washing Machines
    The drum will not spinn?
    If you are having a problem with your top load washer then check out this tip...
    Washing Machine2_bing.gif does not Pump or Spin
    http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
    If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
    Front Load Washing Machine2_bing.gif not draining and or not spinning
    http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
    heatman101
    May 20, 2010 | LG WM1814CW Front Load Washer
    Ge hydro heater washing machine rocks wildly when
    my hydro heater is not wor4kin correctly its not spin/draining or washing properly
    Jan 04, 2010 | GE Washing Machines
    Water still in machine
    Depending on how high your drain hose is some of the water after the final spin can drain back into the outer tube of the machine. This wont hurt anything but when not using the maching, not a bad idea to leave the door ajared to prevent the washer from giving off a bad odour,
    Dec 30, 2009 | Maytag Neptune MAH5500B Front Load Washer
    WMA54 Hotpoint Aquarius drum does not turn during wash or spin
    If the machine pumps water inside but does not start :
    Start checking the lid switch, if this is stuck the machine wont start.
    If the drum does not move at all, the motor, the motor control unit, the motor coupler, the control board may be faulty.
    For more details , see: It doesn't spin
    See also a general diagram here: redarrow.gif Front Load Frigidaire/GE/Kenmore Style
    Jan 06, 2009 | Hotpoint WMA30 Front Load Washer
    Noisey during wash cycle
    sounds as if your brake pads have broken, try removing the lower acess panel you should see the broken pads lying somewhere under the machine(at least pieces of them), i bet if you spinn the machine the drum doesnt come to a complete sudden stop after lifting the top( it should if the brakes are engaging
    Sep 26, 2008 | Amana 3.2 cu. ft. Top-Load Washer
    Aquarius 1300 spin trips residual circiur breaker
    Hello
    There can be two possible reasons for it triping..
    Firstly what im pretty sure it is, the motor... either your motor is faulty or your carbon brushes are worn... Im saying this because when the motor has to work at its hardest during the sping cylce it just cannot cope..
    The other thing could be is that the drum has play within it and when spining quickly it is cathing the heating element probably already damaged it and therefore triping.
    There your most likely faults
    hope this helps.
    The motor is located at the at the back on the bottom of the drum.
    the heater is located at the back on the bottom of the drum .
    Most likely is will not be the heater as it is more common on the older hotpoints.. But i thought id mention it
    Hope this helps......
    Jan 14, 2008 | Hotpoint Aquarius WMA56 Front Load Washer
    GE WBVH6240F Front Load Washer Logo
    400 people viewed this question
    Top GE Washing Machines Experts
    Tim Whalen
    Are you a GE Washing Machine Expert? Answer questions, earn points and help others
