We own a proton pltv-32c. the image coming in is larger than our screen (or the ratio is off). Basically the top and bottom of all images are being cut off (same for TV and video watching). What to do?
  • 718 Answers
Check the FORMAT option in the OSD (on screen display) menu. It may need to change.
It's on page 15 of the User's Manual.
Format
Controls the picture format. The options are 4:3 and Full
(16:9-widescreen).
Or you could reset the tv by using the All Reset button on the menu.
All Reset
Resets all options to factory-default settings.
See page 23 of the User's Manual.
You can get a user manual from;
http://imageuploads.googlecode.com/files/PLTV-32C-owners-manual.pdf
If you do not have Adobe Reader to read the manual you can get it from;
http://get.adobe.com/reader/
Posted on Mar 28, 2011
How do I make the picture bigger so it fills the screen and not have black bands at top and bottom
Banding of the screen usually means that the aspect ratio of the broadcast is different than the screen size ratio. Most modern TVs are 16:9 ratio. Most modern TV broadcasts and movies are as well. In those cases, when in HD mode, you will see the picture fill the entire screen. Older broadcasts and many syndicated reruns are in the old 4:3 format and will be banded. Also, some movies are in larger formats than 16:9 and will reduce in size in order to get the entire picture on the screen. That being said, most TVs DO have a stretch and.or zoom feature that will expand all images to full screen size. Be advised that this can result is image distortion, especially of the 4:3 ration broadcasts. Others will have some of the picture cut off and you may see some items such as network logos, etc. partially chopped off in this mode.
Mar 13, 2015 | Televison & Video
Youtube on my vizio 470i tv is off centered
CHANGING THE SCREEN ASPECT RATIO: ( From Manual )
The TV can display images in four different modes: Wide, Zoom, Panoramic, and Normal. Each mode displays the picture differently. To change the screen aspect ratio:
1. Press the MENU button on the remote.
2. Use the Arrow buttons to highlight the Wide icon. Press OK.
3. Use the Arrow buttons to highlight your desired screen mode and press OK:
• Normal preserves the content's original aspect ratio. Since the 4:3 aspect ratio is not large enough to fill the TV's screen, black bars are added to the left and right of the display image.
• Wide stretches a 4:3 aspect ratio picture to the edges of the screen. Since the picture is being stretched, the display image may appear distorted. If the program is already formatted for widescreen viewing (1.85:1 or 2.35:1), then black bars will appear on the top and bottom of the display image.
• Zoom expands images with black bars to fit the screen.
• Panoramic expands the display image to fill the screen.
images may appear wider than intended.
If you are watching widescreen (1.85:1 or 2.35:1) content, black bars will still appear on the top and bottom of the display image. This option is only available when the TV is displaying a 480i/480p source.
Apr 25, 2014 | Vizio Televison & Video
Where I can buy a Remote Control for Protron TV 32
Setup code to check with Proton TV is 1288. If you wish to get more detail about which brand remote control have setup codes to Proton TVs, check these sites. http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Pull up previous posts or type in the brand name and model number to of your set, to its search box, and press 'Enter'. Locate the exact model remote control, and buy than one according to availability. Many brands will have setup codes. Check all of them.
Aug 21, 2013 | Protron PLTV-32C LCD TV
Proton pltv-26 sound works but no picture
If you have PLTV-32, check to see if your AC adapter is putting out the 24vdc for the backlight inverter, you are getting the 12vdc from the adapter for the sound and for the processor to turn on the TV, otherwise you may have backlight inverter board problems.
http://www.lcdpayless.com/productpage.php?productId=6332
PLTV-32C has power supply module inside the TV: http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=pltv-32+power+supply&um=1&ie=UTF-8&ei=PWVvTOy6M5H4swOciO3DCw&sa=X&oi=product_result_group&ct=title&resnum=4&ved=0CCwQrQQwAw
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Aug 20, 2010 | Protron PLTV-32 Television
Picture is larger than display area
Check the aspect ratio settings you may have it set to 14:9 movie expand
Jan 30, 2010 | Samsung HL-P6163W 61" TV
How can I make the picture size fit the screen? I loose picture around the edges. Seems like it is displaying at a larger size
The issue your having is aspect ratio. Some programs and commercials are broadcasting in a higher resolution so some fill the screen and some have black bars top and bottom. I suggest searching "aspect ratio for video". It would take me all night to type it out. But you need to know how the different resolutions change the size of your image. Also in the TV's menu you should see an aspect ratio option. Try the different settings to see if you can find the best.
Aug 19, 2009 | Zenith A25A23W 25" TV
Proton pltv 32C
1080i or itll do 720p
Oct 05, 2008 | Protron PLTV-32 Television
Screen border
You are probably in the "3:2" ratio print setting. This is accessed through the "F" button, under image quality. The 3:2 is a ratio of height to width which corresponds to a 4x6 inch print. The other settings are approx. 4x5.33 inches in h to w ratio. Just change the quality setting to the larger megapixel settings and the bars will disappear.
Sep 21, 2008 | Fuji FinePix S700 Digital Camera
Shadow on screen
your vertical ciruit is malfunctioning
May 26, 2008 | Protron PLTV-32 Television
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
