Question about HP (377402-B21) CD-RW/DVD-ROM Combo Drive
Cd Group Boot Priority not installed - HP (377402-B21) CD-RW/DVD-ROM Combo Drive
  • HP Master
  • 27,725 Answers
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
Posted on Mar 27, 2011
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
May 04, 2015 | Acer Aspire Computers & Internet
Windows 8 Gateway desktop trying to load Win7. I
Hi
You can try with Free Boot Managers and Multi-Boot Loaders you can find lot of free stuff available in online. So download and follow the instructions.
OSL2000 is an advanced multi boot manager you can install multiple OS in a Single PC.
Hope this will be helpful
Have a good day.
Regards
NANDU
Aug 28, 2013 | Gateway SX2865-UR11P Desktop Black
How to boot from an external cd rom on a dell optiplex sx260 because it does not have an option to boot from an external cd rom..
Maybe it's not installed into windows, or whatever system, with a "driver." That is a program you can get off the internet that tells your computer how to operate that device.
Once installed, a restart and going into bios setup, you should find it in boot priority under the boot tab. If installed it should be there and you set it to top priority and save with f10 and exit. It will reboot and look first in the cd rom for an operating system.
Jan 10, 2012 | Dell Computers & Internet
My computer ( compaq 6220 ) is showing me rom based setup and cant starting ... i want a selution for this problem
it seems that your windows has crashed.insert new window installation disc and chage the boot device priority and give the 1st boot priority to cd rom and 2nd boot priority to hard disk and then disable all other boot device. then install the windows.
May 29, 2011 | Computers & Internet
I have hp compaq nx 9020 and I installed linux as my only os, but now I want to change my os to xp but bios says "no boot file name recived" how to fix this?
It seems as if you have some of your boot priorities out of skew, specifically having booting through your network connection as a higher priority. In order to fix this, you need to go into your bios settings and rearrange the boot settings so that booting from LAN is either disabled or not the top priority and making booting from CD or HDD the top priority.
May 23, 2011 | HP Computers & Internet
How do I boot up an operating system after my hard drive has been wiped
If your hard drive has been wiped then it means you will need to re-install your operating system onto it. To do so follow these simple instructions:
Step 1) Press the Delete key as your PC boots up. This will take you to the BIOS.
Step 2) In the BIOS find the boot disk priority. Set priority 1 to your CD/DVD drive and set priority 2 to your hard drive.
Step 3) Save and exit the BIOS.
Step 4) Insert your operating system install disk into your CD/DVD drive.
Step 5) The installation should now start.
Mar 05, 2011 | HP Computers & Internet
Unable to install XP OS to MSI lap top
Insert your installer to the lap top then try to change the boot up priority by entering the bios. Try to press del key while your lap top boot. If these deosn't wok try F1 or F2 thesame process. If you have enter the BIOS, look for the boot priority which includes the First Boot, 2nd Boot and 3rd boot. Change the 1st boot to CDROM and the 2nd boot to hardisk. Then save the changes by pressing F10. your PC will reboot and it will direct you to the OS installation.
Mar 29, 2010 | Computers & Internet
Barracuda 7200.7
Hello Sir,
While windows is booting first go to BIOS settings by pressing "Del" or "Esc" then change the boot priority that is save the first boot priority as cd-rom and second boot priority as hard drive... so that you can boot you system with bootable cd...
And then while formating the system just delete the partion that is only "c:/" and install the windows in to that and don't even do anything to your "d:/" drive then you can get all your data back... Abd the cd should be bootable format...
Aug 22, 2009 | Seagate Barracuda 7200.7 Hard Drive
Bios bbot device proirity is missing
Try pressing F12 while booting or DEL etc. as some PC's have a seperate boot priority menu from the BIOS.  Once you can boot from the install cd you can use it to fix your master boot record by entering the recovery console and using the command fixmbr.  Hope this helps :)
Apr 29, 2009 | Microsoft Windows XP Home Edition
Laptop won't boot from external CD drive yet internal one is unresponsive
if you want to boot a cd e.g windows xp os disk then you have to go to the bios by pressing del or f2 or f8 ot f10 depending on the motherboard you use. try to find boot option -> boot priority or first boot device.if you find boot priority then select cdrom as first priority . if you find first boot option then also select cd rom. sometime if your disk is not bootable then it won't boot.
Jun 20, 2008 | Computers & Internet
HP (377402-B21) CD-RW/DVD-ROM Combo Drive Logo
313 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
