Question about Baumatic B100 Electric Single Oven
Baumatic B100SS-B Single Oven takes a very long time to heat up and won't get above 175c. Grill working fine.
barkencoa
  • 3463 Answers
SOURCE: Baumatic B501SS Built In Stainless steel electric single oven
If the fan is working in the main oven and there is no heat, then it will be a faulty element.
Remove the cover at rear of oven
and you will see the round element. remove it and replace with new one.
Plz rate my solution .
Thanks.
Posted on Jan 17, 2009
SOURCE: baumatic oven not heating up. Grill and fan fine.
if it is the b180, the answer (having just fixed this) is really simple.
The coily bit is the oven element - it will have gone. A new one from eBay cost me about 6 quid.
[WHEN IT ARRIVES !]
Turn the power off.
Inside the oven use a philips screwdriver to remove the 4 screws (KEEP THEM !)
You will see a coily thing and a fan.
You unscrew 3 more screws (2 on the left and 1 on the right).
(KEEP THESE TOO!)
now ... bit tricky, have the new one inside the oven and take each wire off one at a time and put it on the new element.
Screw it back on but DONT put the last panel back in.
Turn the oven on maximum for about 2 minutes and see it glow red.
Turn the oven off. Make a cup of tea and have a couple of biscuits while admiring how good you are and waiting for the element to cool down!!!
Put the final panel back in place. Whole thing (including a cup of tea) takes about half an hour.
Posted on Apr 02, 2010
catriver
  • 878 Answers
SOURCE: Single oven not heating
diydoris, you would have to have someone ohm out the lower element to make sure it is good. If the element is good, then your problem probably is in the TCO. This is a thermostat that sits on the back of the oven that can go bad. You can test this with a meter, if it shows open (no continuity) its bad. Part number for the TC0 is 4450934. Part number for the element is 4448696. Catriver...post back.
Posted on Sep 28, 2006
SOURCE: baumatic 1870ss steel electric oven
sounds like your element is not wired in properly or its faulty get someone to look at it
Posted on Dec 13, 2007
barkencoa
  • 3463 Answers
SOURCE: Baumatic fan assisted oven not heating up
The oven element has failed, you need to fit a new element.
It is a straight forward repair to do.
Remove inner rear panel of oven, you will see the round element at rear.
Unfasten element, detach wires, and fit new element.
Refit rear panel, and test.
Plz rate my solution.
Thanks.
Posted on Jan 24, 2009
Hello, I have a Baumatic B180SS (B600) oven which no longer heats up when i choose the fan oven option. The fan still works and if i change it to Grill it heats up still. Can you please advise me of...
we can not guess at any cost to repair . that is many times a local thing by your location in the world .could be a bad controller but only a repair tech can really tell for sure
Jan 14, 2018 | Baumatic B180 Electric Single Oven
Grill and fan works but no heat to oven
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
May 15, 2011 | Baumatic B180 Electric Single Oven
My grill works but the oven doesn't heat up
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
heatman101
Mar 31, 2011 | Baumatic B187 Stainless Steel Electric...
My Baumatic B180W-B oven does not heat up. The
If the oven is electrically heated, then more than likely, the oven element has failed.
This is located behind a removeable cover at the rear of the oven.
Feb 21, 2010 | Baumatic B187 Electric Single Oven
Baumatic oven not heating up. Grill and fan fine.
[WHEN IT ARRIVES !]
Turn the power off.
(KEEP THESE TOO!)
Jan 27, 2010 | Baumatic B180 Electric Single Oven
Oven does not heat up.
You will probably find that it is the oven element that has failed.
This is to be found at the rear of the oven compartment behind a removeable cover.
Hope this helps.
Jan 01, 2010 | Baumatic B187 Stainless Steel Electric...
The fan still circulate on fan bake but no heat
IT SOUNDS LIKE YOUR HEATING ELEMENT HAS BURNT OUT ,FIRST TURN OFF THE POWER THEN LOCATE THE SCREWS HOLDING THE BACK PANEL ON REMOVE ALL THEM AND THE PANEL YOU THEN SHOULD SEE THE ELEMENTS REMOVE THEM BY PULLING OUT THE PULG HOLDING THE ELEMENT IN THEN TAKE IT TO A ELECTRICAL SUPPLY STORE FOR REPLACEMENT REFIT ELEMENT AND YOUR OVEN SHOULD WORK FINE.
Dec 04, 2009 | Baumatic B185 Stainless Steel Electric...
No manual
The light bulb is the oven light.
The snowflake with 3 raindrops is Defrost Mode (fan runs with no heat to reduce defrost time)
The 2 lines up top & down bottom is Traditional Cooking (heat from top & bottom elements)
The big circle with a fan is the Fan forced Oven
The small line at top only is the Grill Mode
The larger line at top only is the Double Grill Mode
The line up top with the fan underneath is Double Grill with Fan mode
The line on the bottom with fan on top uses the lower element with the fan for delicate dishes
The manual can be found on the Baumatic website - www.baumatic.com.au - select your product which takes you into another page & you will see on the left hand side a link to "View User Manual"
Nov 11, 2008 | Baumatic B187 Stainless Steel Electric...
Baumatic 1870ss steel electric oven
Aug 28, 2007 | Baumatic B187 Stainless Steel Electric...
Baumatic B100 Electric Single Oven Logo
99 people viewed this question
Top Baumatic Ovens Experts
ashburton
Starnley Johnwells
Starnley Johnwells
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
