Question about LG Dryers
LG electric dryer DLEo442W taking longer to dry also has a loud vibration when drying
SOURCE: LG Tromm dryer now takes two cycles to dry a load
Rob, sounds like you're on the right track. The other things that could be bad is part of the heater coil is out or, less likely, that you have thermostat or high limit switch issues. These will likely require a service person to resolve. Good luck, sir.
Posted on Dec 24, 2007
SOURCE: Dryer takes too long to dry my clothes
My dryer has been taking longer and longer to dry my clothes. Sometimes it takes multiple cycles before the clothes become dry. They seem to be getting warm, but are not drying as quickly as they use to.
Posted on Oct 05, 2008
jumptrout51
  • 3361 Answers
SOURCE: MY GE PROFILE DRYER IS MAKING A LOUD NOISE WHEN DRYING. ANY SUGG
Replace the rear drum bearing and the tension roller wheel.
Posted on Mar 13, 2009
  • 77 Answers
SOURCE: My LG electric dryer DLE3777W takes forever to dry
Check to see if your vent is not kinked or clogged. Also, check if your lint screen is clean. If you don't clean it each time you loose 10% efficiency. Good Luck
Posted on Apr 13, 2009
MNTECH
  • 1543 Answers
SOURCE: LG DLE2516W Dryer suddenly making loud vibrating noise
Until you know how serious a problem you have, I'd advise against continued use. If you are in the USA, go to http://www.lge.com/us/support/repair/support-repair-provider-lookup.jsp
to find a service provider for in warranty service, or call LG USA at 800-243-0000.
Posted on Aug 18, 2009
Loud dryer noise when drying
sounds like bearing take off back and see if and black markes around the bearings only other thing it could be is the felt ring around the drum
Apr 05, 2014 | LG DLE5977 Electric Dryer
LG DLE 2514W DRYER MAKES RUMBLING NOISE WHILE RUNNING
Hi Willie Bolden
Sounds like your problem is drum rollers are in need of lubrication or replacement.
Go to the following webpage for a schematic of your dryer and parts.
Please take time to rate me
Bud
http://www.appliancepartspros.com/parts-for-lg-dle2514w-abweeus.html
Oct 11, 2012 | LG DLE2514 Electric Dryer
I was looking at a LG DLEO442W Dryer, but when it was turned on, it was really loud. What might cause this?
drum rollers/glides, belt, motor, and or idler arm Hope this helped Tim:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
May 29, 2011 | LG Dryers
Have a Maytag Dependable Care dryer. Model MDG9606AWW. The glow bar comes on, gas lights and stays on about 30 seconds, go off for about 30-60 sec. then comes back on for about 10-18 seconds. Then goes off...
Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 01, 2010 | LG DLG5932W Gas Dryer
Aug 18, 2009 | LG DLE2516 Electric Dryer
It takes at least 2 60 minute cycles to dry clothes. Not even 2 years old yet. Not a new problem has always been this way. What is the deal.
Check the blower fan which is mounted underneath the drum on my DLE2514W front loading LG dryer. I experienced poor drying along with a loud thump at the start of each cycle. At first I thought it was a bad roller but later found that the blower fan had separated from its bracket so it was not turning with each turn of the moter but rather spinning freely.
Apr 14, 2009 | LG DLE3777 Electric Dryer
Takes a lot longer to dry clothes
belts MUST be ordered by model all belts are different sizes, different witdhs
Mar 04, 2008 | LG DLE5977 Electric Dryer
Dryers Logo
73 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
