Question about Kenmore Washing Machines
My kenmore washing machine is having problems with water pressure
  • 94 Answers
  • Kenmore Master
  • 2,699 Answers
Shut off the house water feed to the washer,mark the hoses so you know where they go when you reconnect them,remove the hoses from the back of washer,you can stick the hoses into the washer or in a backet,turn the water back on and make sure you have good pressure coming out of the hoses,if it's good now you know it's deffinetly the washer,most likely sediment clogged the screens in the valve and the valve on the washer needs to be replaced,you can try pulling the screens out of the valve while you have the hoses off and clean them out with a steel brush or tooth brush and put them back in to see if it helps,if you do this keep an eye on the washer,if the sediment gets through the screens it can keep the valve from closing all the way and the washer could fill with water with the washer off,,you'll know after running it if it's ok or just change the valve out
Posted on Mar 27, 2011
futureloginn
  • 734 Answers
SOURCE: Kenmore Top loading washing machne F4 error. (110.20052994)
It spins, but doesn't pumpIf your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns
If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Dec 12, 2008
jsrock516
  • 5911 Answers
SOURCE: Broken Machine-Kenmore 70 series Washing Machine
This is commonly caused by a lid switch malfunction. If your model number is correct, the lid switch for your washer is located under the right hand side of the washer casing along the wash tub rim. The switch is activated by a small plastic piece on the washer lid (called a "lid strike") through a small hole. The switch contacts close when you shut the lid. In many cases, the lid switch either comes loose, or the lid strike breaks off. In both cases, the washer will exhibit the symptoms you describe. Open and close the washer lid and listen for a distinctive "clicking" sound as the switch contacts close. If you cannot hear the switch, make sure the lid strike is intact and the mounting screws for the lid switch (located around the wash tub opening on the casing) are tight. Sometimes, all it takes is to tighten the lid switch screws to realign it with the lid strike. If the switch is defective, or the strike is missing, parts can be ordered on line at searspartsdirect.com. Just type in your COMPLETE model number, which can be found on a nameplate under the washer lid. The lid switch and lid strike will be listed under the "Top and Cabinet" heading. Other sites that offer competitive pricing are repairclinic.com and appliancepartspros.com. If you require instructions on how to replace the switch, you may use the following link:
http://www.fixya.com/support/r385198-replacing_lid_switch
If you have questions, or if the diagnosis is incorrect, please let me know. I hope you find this information helpful.
Posted on Jan 14, 2009
Maanita
  • 1142 Answers
SOURCE: kenmore washing machine washes but does not release the water.
Posted on Mar 24, 2009
  • 97 Answers
SOURCE: water is not draining out of kenmore 11020802990 washing machine
http://repair2000.com/demo_pump.htm
This will redirect you to a site to check and see if your drain pump is not functioning correctly. I would be willing to bet that therein lies your problem. Quite usually the pump itself runs fine however there is debris inside that will cause the pump not to function correctly. I. E. Dirt, Lint, heck I've even found a diamond necklace that had been lost that way.
Other things you can check without tearing the case off is to make sure that the hose is not kinked or clogged. I've seen sometimes where hair will get caught up in there as well.
Posted on Jul 29, 2009
SOURCE: Top loading kenmore washing machine frozen water loaded
Could it be that it has overheated? My mom's washing machine isn't a kenmore, but it has a mechanism that causes it to stall when it is overheated from constant use. After about 15 minutes it cools off and starts again.
Posted on Aug 07, 2009
I have Kenmore washing machine showing F1
The F1 fault code on this washer indicates that the water level pressure transducer signal is out of range. The pressure transducer air hose tubing being pinched or crimped can cause this. A failed pressure transducer on the machine control board can also cause it.
Jul 25, 2017 | Kenmore Washing Machines
Kenmore 110 91520100 washer stopped working just after filling up.
sounds like a bad water pressure switch but I would also check the door switch with a multi meter. the water pressure switch is what signals the machine to go into wash after filling to certain level of water? if it doesnt detect the specified level u will have no wash cycle
Feb 19, 2015 | Kenmore Washing Machines
Kenmore washing maching overflow after washing
The pressure switch, also called the water level switch, is what control the amount of water goes in the machine, If your machine is constantly filling to the overflow point, then that is your problem. Now, if water is going in and the level is staying the same then your machine drain line is lower than the pump and your siphoning out the water as it goes in. Pull the drain up a little a that should fix the problem.
May 28, 2012 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
THE WATER IS NOT STOPPING, JUST KEEPS PUTTING WATER INTO THE WASHER KENMORE 90 SERIES
There are two possible causes of the water not stopping. First is the water inlet valves stuck in the open position and second is the pressure switch not tripping when the correct water level is reached. Turn off or unplug the machine while it is filling and if the water doesn't stop, the water inlet valve/s is/are indeed stuck in the open position. Replacing the water inlet valve assembly should solve the problem.
But if the water stops, the problem is the pressure switch stuck in the empty position. Disconnect power then raise the console up and hinge it at the rear of the machine to access the pressure switch. It is the part with the small clear hose attached to it. Detach the hose and blow air down into it including the pressure switch itself. Replace the pressure switch if the problem persists.
Click on the link below for the detailed procedure in raising the console and removing the cabinet to access and replace the water inlet valve assembly.
Removing the Cabinet on a Whirlpool or Kenmore Top-Load Washing Machine
Dec 31, 2010 | Kenmore 15864/15862 Top Load Washer
My Kenmore washer will not shut off the hot water at the end of the fill cycle
Water valves work on a hydraulic principle, the surface area of the valve where the water comes to the valve is more than the opening that it passes into the machine.. The pressure of the water shuts off the valve. The electric solenoid opens the valve when power is applied to fill the machine.
If you unplug the washing machine while it is filling and it keeps filling you have a bad water valve.
If you unplug the machine while filling and it stops filling you have a electrical problem or a bad pressure switch.
Jan 09, 2010 | Kenmore Washing Machines
I have a Kenmore Elite cloths washing machine Model #110.24962300. in the last month there was a noise when the washer was finishing its spin cycle. today it will not spin if there are cloths in the...
First open the filter door and remove the water from the machine and the "garbage".
Second the problem sometimes is the water pressure, you have to control the amount of water.
Kenmore Elite is a sensitive machine level the machine.
IT´S NOT A ELECTRONIC PROBLEM
Regards, Pedro from Portugal..
Nov 19, 2009 | Kenmore Washing Machines
Will stop agitating, unless it is on low water
1. Sounds like your problem comes from a drain hose not having enough air flow at the stand pipe - this causes water from your washer to drain ahead of time and washer stops.
2. Your pressure switch is defective and needs to be replaced.
Pressure swiches control your water levels.
Aug 15, 2009 | Kenmore Washing Machines
Kenmore washer overflows during rinse cycle.
SOME OF THESE MACHINES HAVE TWO PRESSURE SWITCHES IN THEM, ONE FOR THE MAIN WASH WATER LEVEL AND ONE FOR THE RINSE WATER LEVEL. CHECK FOR A PLUGGED AIR PRESSURE HOSE FIRST AND THEN CHECK THE PRESSURE SWITCHES.
Jan 27, 2009 | Kenmore 22422 Top Load Washer
Kenmore 90 model 110.20912991 wont stop filling with water
If it continues to fill turned off or even unpluged, It needs to have the water valve replaced it is sticking open.
Jan 27, 2009 | Kenmore 15864/15862 Top Load Washer
Kenmore wash macine
its in your cold water line valve to the washer if it works good with hot water the valve are incoming line being blocked when you turn it on the pressure comes in fast then when pressure is gone water slows down so when its off the pressure builds back up it runs fast then slow
Feb 27, 2008 | Washing Machines
Washing Machines Logo
48 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
