Question about Husqvarna YTH21K46 (46") 21HP Lawn Tractor 960 43 0085
Seems there is no power past the safety seat switch. Can I bypass the switch? Key will not click when turned. Thought it was the selenoid, but have tried screwdriver across selenoid, and the mower will turn over.
    Novelist:
  • 111 Answers
You can put a fuse or a wire jumping across the safety switch under the seat. This is the most common fix you will find for a faulty safety switch. Do NOT do this if children will be around you while you mow or if you let a younger person drive the tractor! That could result in death or serious injury if they got off of the mower while the unit was still in motion.
Posted on Mar 30, 2011
On our Troy built we can't start it unless we use jumper cables to touch battery terminal and then the starter
check switch for corrosion make sure all post male and the female plug are clean. Check power to switch with 12 volt test light if you have power to switch check your soilinoid there is one wire that activates your selenoid to send power to starer. .i would guess bad selenoid.
Apr 05, 2017 | Troy Garden
Where is the starter safety switch on a 2006 kubota 7040 tractor?
The switch is usually under the seat. Pressure activated to start when you are seated on the machine and go off if you get off of the seat.
Mar 30, 2016 | Kubota Garden
2011 ford focus 1.8 clicking noise when start engine
Could be several problems - check the battery terminals to make sure they are clean. Next check the battery to see if it is fully charged. If both those items checked are OK then the next step is to check the starter.
Now the starter has a selenoid which engages and provides power to the starter motor when you turn the key to the start position.
If you only get a clicking noise then it could be the selenoid valve itself or the starter motor.. Some fords have the selenoid mounted on the firewall others are mounted on the starter motor itself.
So what you need to do next is bypass the selenoid valve and provide power directly to the starter - if the starter turns the engine over then the selenoid valve is the problem. If the starter motor doesn't turn the engine over then it's the starter motor and a replacement is necessary.
Hope this info helps.
Feb 22, 2015 | 2011 Ford Focus
Husqvarna yth1848xp wont turn over
Are you getting 12 volts to the starter? It sounds like one of the safety switches (seat switch) may be killing the circuit. The seat switch cannot simply be jumped. And check the 20 amp fuse.
May 30, 2014 | Husqvarna Garden
My 155c John Deere will not start! Brand new charged battery....I turn the key...nothing(no clicking either). When bypassing it to cellinoid, it starts right up. When I shut off the mower, I have to...
Usually when the key is turned to start position the starter soleniod engages thus applying power to the starter. There are three possible causes to your problem . (1) Check for 12vdc at the terminal on the soleniod when the key is turned to start position, if there is 12vdc at the terminal then the key switch is good. (2) loose or bad cable connection at the soleniod, check connections. (3) bad soleniod -- replace it. generally you will hear a click from the soleniod when the key is turned to start position. Also be sure to check that ALL safety switches are engaged. You may need someone to sit in the drivers seat so that switch will be "made" / engaged. Park Brake is set, mowing blades are "NOT " being engaged, on some mowers if the transmission is in reverse ,even tho the brake is set the mower will not start.
Nov 10, 2013 | Garden
1986 dodge van
Yes, the solenoid is mounted on the starter.
One small jumper wire from the battery cable connection on the starter to the small wire solenoid connector should cause the starter motor to work and crank the engine. If key is on, engine should start. A small screwdriver works too, besides a jumper wire.
Check for voltage on the small wire to the solenoid with the key held in crank: if voltage there, the problem is the solenoid or starter motor. If no voltage to the solenoid, power has been lost between the ignition switch and the solenoid-possibly the neutral safety switch.
Sep 15, 2013 | Ford E-350 Cars & Trucks
Try starting my 19.5 hp craftsmanriding mower and no click and cross over the solnoid and it turns over but no start
If it is equipped with a seat safety switch it won't start unless someone is on the seat or the switch is bypassed (which you shouldn't do for safety concerns). You could also have a bad ignition switch which is not uncommon.
May 18, 2012 | Craftsman Garden
TURN KEY WON'T START BYPASS SELINOID IT
There are a few things it could be. You need to do a check of the coil, safety switches and the ignition switch. You can check the starting solinoid (coil) by jumping from the hot terminal on the main contacts to the terminal that gets its power from the ignition switch (caution, do not go to the ground terminal if it is a four wire solinoid) . If it turns the engine, then you need to check the ignition switch. This is easier with an electrical multimeter. Remember to check the safeties. I have observed that the seat safety switch is the most common electrical component to fail.
I hope this helps.
Sep 02, 2011 | Craftsman Garden
I have a John Deere X300 garden tractor. When going into reverse the deck blades stop cutting unless you pull up on the switch. We have no little kids so safety is not an issue. How do you get around this?...
I have a John Deere X300 lawn tractor with an intermittent starting problem. From time to time, when you turn the key all you get is a click. Battery is connected, headlights work, but starter will not turn. Keep turning key off and on and eventually it starts. Other times, it starts just fine. What parts should I start replacing?
Nov 30, 2009 | Garden
It won't start
do you have power to the solenoid?? with the key on there should be 12 volts on one side of the solenoid then when you turn the key to start it should send 12 volts out the other side to the starter
Apr 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Husqvarna YTH21K46 (46") 21HP Lawn Tractor  960 43 0085 Logo
492 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
