JVC Sub-Woofer I have this JVC sub woofer that I bought at a yard sale for a few bucks. It has no place to plug in power, no lights on it and, its about the size of your average computer tower. Someone has apparently ripped the sticker off so I really dont know the model # sorry. On the inside of the box there are two maybe 6-8 inch woofers and wiring stuck inside on the back panel. Im sure that its part of some system. There are 4 speaker connects on the back and, each has its own + and - two on top are grey and blue..two on bottom are red and black. Are these ins..outs..can I even use this sub or no?any info at all would be greatly appreciated. Thanx
  • 752 Answers
Well, sort of. It's part of a typical JVC shelf system. The gray and blue are for the left woofer and the red and black are for the right woofer. It's basically just two small "woofers" in a box. So unless you have a small amplifier that has 2 subwoofer outputs with a built in crossover, they are essentially useless.
Posted on Aug 05, 2008
I have a jvc seteup but reciever is broke.is there a way i can get a adapter to plug sub woofer with power amp into a a yamaha reciever?the plug that goes from sub woofer also powers other speakers, cable...
Here's a manual.
http://www.retrevo.com/support/JVC-TH-M505J-Home-Theater-Systems-manual/id/318dj491/t/2/
That cable not only carries audio but it also powers the sub and other channel amplifers. Even if we could supply the pin-outs for the channels I'm not sure what we could do to provide subwoofer power. We're talking about a major rework.
This is a highly proprietary design, meaning it's really not very adaptable to normal spec audio equipment.
There's a flat-fee repair service for the receiver ($99.95, free return shipping):
http://cgi.ebay.com/JVC-TH-C50-TH-C5-TH-M505-Repair-Service-/360178567658?pt=LH_DefaultDomain_0&hash=item53dc50c9ea
Maybe they could fix your receiver.
You COULD try to reach the manufacturer for other options.
http://www.jvc.com
800-252-5722
Jan 12, 2011 | JVC TH-M505 System
The cord /with the pin on both ends that plug in the back of sub woofer & dvd player, i need the female ,plug that on the back of sub woofer
The part is called a Din connector. You may be able to find it at www.jvcservice.com You will probably need to use the sub-woofer or the system model #, it is not listed under th-c30
FYI replacing it is not very easy.
Mar 26, 2010 | JVC TH-C30 System
AV receiver single line output to two line input on sub woofer
You are trying to connect the powered sub output of the receiver to a standard (unpowered) subwoofer. Can't be done.
May 05, 2017 | JVC Audio Players & Recorders
JVC KD-PDR30 overheating
think the sub woofer my be drawing to much power try disconnecting the sub for a few days and see how it goes
May 21, 2009 | JVC KD-PDR30 CD Player
Hi I own a Technics Hi-Fi system (Model SC-EH780) and would like to attach a subwoofer to it. I cannot find the subwoofer unit that is supposed to go with this system. Can you help?
Any powered sub-woofer will work with it. Check the back of the Technics, make sure there is an RCA output labeled "Sub-woofer" or "Woofer" or "Sub". If so, you can get any brand of powered sub woofer and it will work. A powered sub-woofer is one with an amplifier for the sub built into the box and you will need to plug it into an A/C outlet as well. The only exceptions to what will work with this unit is to make sure you are not buying a sub-woofer that is made to only work with the companion unit it is originally sold with. Many Panasonic and JVC sub woofers are like this. Just look for a sub-woofer that is not part of any system. Velodyne makes some really great sub-woofers that would work nice with yours, but they can be a little expensive, but they are very good.
If your Technics has no RCA output for the sub-woofer, you will need to make sure that whatever powered sub-woofer you buy has a speaker level input for it. Most powered sub-woofers have this feature, so that you may just run the front speaker outputs of the receiver into the subwoofer and then the sub-woofer will have a set of speaker outputs right below the speaker inputs so you can still have your front speakers connected to that and not loose anything from your system.
I hope I have explained this in a manner you will understand easy, if not just post whatever questions you may have right on this thread and I will get back to you as soon as possible.
It would also be appreciated if you could rate this solution if you no longer need any help from me. If you do require more help, please wait to rate this until we are finished. That way I do not get an undeserved bad rating when we have not even finished our communications.
By the way, A "Thanks for trying" and "Helpful" rating are really not good, they always end up lowering my overall score.
Dave
Nov 09, 2008 | Audio Players & Recorders
Sub
Most amplified sub woofers need to be grounded to the output source.If you plug the sub woofer in to the receiver you would use a ground wire from the receiver to the sub woofer there should be a ground terminal on the sub woofer and receiver.
Feb 17, 2008 | JVC RX-778V
SONY STR-DG510 Sub woofer does not work
You will need a powered sub because your receiver does not amplify in the sub output.
Jan 21, 2008 | JVC RX-554V Receiver
198 people viewed this question
 Grubhead
Grubhead
