Question about Alps MD 1000 Thermal Printer
Alps MD1000 printer.
Where in Australia do I get a power supply no.M73045 for this printer
    Sniper:
  • 58 Answers
MD-1000s hit end of support almost 10 years ago. Chances of getting spares are nil.
Best bet is to get a junker of eBay for spares, or you can get a new MD-5500 from http://www.alps-supplies.com
Posted on Sep 02, 2008
I need an alps MD1000 9 pin head part
I have a hardly used MD 1000 with about 60 foil/b&w cartridges....
contact me at pioneer_junk@yahoo.com if you would like to buy it all.
Jan 17, 2013 | Alps MD 1000 Thermal Printer
No color
I don't have an Alps printer, nor have I ever used one, but have you checked the ink to make sure that the colour hasn't run out?
Also, check your word processing program to make sure that the settings aren't set to print in grey only. Every word processing program allows you to change that, and to set the defaults to either grey or colour.
If none of those things work, check your Alps manual. You may have to change the default by hand on the printer.
If you haven't used your printer, especially some tubes of ink for some time, they could be clogged and you might have to run some test files to unclog them. Your printer manual should also tell you how to do that.
Aug 05, 2009 | Alps MD 1000 Thermal Printer
Alps MD1000 printer won't do anything.
Do you get the green ready light when you first turn on the printer?
Nov 05, 2012 | Alps MD 1000 Thermal Printer
Alps md 1000 printer wont print
Make sure that you have the dark grey cartridges and not the blue cartridges. The blue ones will not work in the MD1000. Can you tell us more about the problem? Have you tried an internal self test print?
Jun 17, 2012 | Office Equipment & Supplies
Just bought an alps md1000 from ebay, the driver loaded ok but i need to know if the printer will function with just one cartridge there are some used cartridges with it that look kind of rough, the...
hello, no the machine will not function with just one cartridge, it must have all 4 colors, black, cyan, magenta, yellow. once the machine fully detects these cartridges, it will then go online, ready for printing. at this time send just windows test page only, to test for communication. if this does not work then there is problem.
Sep 30, 2010 | Alps MD 1000 Thermal Printer
MD 1000 Thermal Printer: I need a driver for ALPS MD1000 printer that will ...
Go to the ALPS Yahoo Group. They have an extensive file section with drivers. Windows will use the default plug and play driver for the printer. The MS version is very limited. You should rename the MS driver to something else like "MS Alps Driver" and then install the ALPS driver you find at the Yahoo Group. These will give you full functionality.
good luck
May 16, 2010 | Alps MD 1000 Thermal Printer
Power Supply part no M73045
These printers were discontinued years ago.
There is also a very specific setup, the head voltages supplies by the PSU need to be matched to the head using a specified scanner and software that was only supplied to Alps/Oki service agents.
If you have a faulty PSU, you may as well list it on eBay as a spares machine.
May 01, 2009 | Alps MD 1000 Thermal Printer
Driver and software disc lost for Alps MD1000
Join the Alps mailing list at YahooGroups. The drivers are in the files section.
http://tech.groups.yahoo.com/group/Alps/
No Vista, 95/98/Me/NT/2000/XP only
Apr 29, 2008 | Alps MD 1000 Thermal Printer
ALPS MD1000 Won't print
Please ignore courtdate & creamgetmonE. Here's why:
creamgetmonE - If you're using the XP driver, you are using something so crippled, it should have been aborted. USE THE ALPS DRIVER!!!!!!!!
courtdate, oiling the carriage rail will not change a thing, apart from gunking up the printer, and ENSURING it will fail sometime in the future.
TO FIX YOUR PROBLEM:
There is a sensor under the anti-curl veil. Clean it.
Jan 18, 2008 | Alps MD 1000 Thermal Printer
ALPS Printer MD1000 Driver
Several things about these printers.......
1. Do NOT use the MS XP driver for these - it has limited functionality. Download the Alps driver, which you can find in the files section at the Alps YahooGroup (http://tech.groups.yahoo.com/group/Alps/files/)
2. The printer requires bi-directional comms in order to feed back the printer status to the computer. While this is not an absolute requirement, it means that without bi-dir comms, the error light will flash, and you won't know what the problem is.
3. The driver is hardcoded to only communicate bi-directionaly with Alps virtual LPT ports - run this with a non-Alps cable (And all of the cables on FleaBay are non-Alps), and you will not be able to monitor the printer status.
Now, how to install.....
1. Plug in the USB cable to the computer (But not the printer), and let it install. Reboot if required (Unlikely)
2. Install the Alps driver you downloaded fron the Alps YahooGroup. Reboot if required. If you now look at Printers in Control Panel, you will see a nice Alps printer there, waiting to be used. Make a note of what it named.
3. Plug in the printer and turn it on. XP will now tell you it has found new hardware, and install the MS driver. Reboot if required
4. Go back to Printers in Control Panel. You will now see you have TWO Alps printers! The MS driver will be called something like "Alps MD-1000 (MS)". Rename (DON'T delete!) this driver to something like "Alps MD-1000 (DO NOT USE)". If you delete it, it will come back to haunt you every time you switch on the printer, and screw up your settings.
5. Open the properties page of the driver you made a note of in step 2 (Control Panel -> Printers and Faxes -> right click on printer, and select "Properties"), and click on the "Ports" tab.
6. Check the checkbox next to the port created for your USB-// cable, and uncheck the other box that will be checked.
7. Uncheck "Enable bidirectional support"
8. Click on the "Advanced" tab
9. Select the "Print directly to the printer" radio button
10. Click on the "Print Processor" button
11. Select ALMD224S as the Print processor and select RAW(FF AUTO) as the Default data type
12. Click Apply.
Sep 23, 2007 | Alps MD 1000 Thermal Printer
Alps MD 1000 Thermal Printer Logo
187 people viewed this question
Top Alps Office Equipment & Supplies Experts
Jesse Walters
Jesse Walters
Samuel Konger
Samuel Konger
Are you an Alps Office Equipment and Supply Expert? Answer questions, earn points and help others
