Question about JVC Video Cameras
I keep getting a message, eject and re-insert tape on JVC GD-72U camcorder. And even after re-inserting tape, same message.
    Genius:
  • 1,812 Answers
This iscan be caused by an oxidized or defective Audio/Video drum. You can try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Apr 01, 2011
I can't get the tape to eject. PLEASE WAIT is the message that is displayed on the screen
Please let me know more about the message, go down further below if there is a numeric code like "03" or "02" etc. Because If it is because of condensation tape can be ejected. Please wait message also appear when you inserted a high capacity SD Card and you are switching from REC to Play and every time you switch cam on, the bigger capacity the longer you will wait, i suggest remove it when not needed. Please give as more details if none of the mention above solves your problem.
Jan 25, 2010 | JVC GR-D290 Mini DV Digital Camcorder
GR-DVL320 keep getting E03 error indication. Ejecting and reinsertion of the tape does not seem to be fixing the problem, also says unit in safeguard mode. What do I do to remedy this?
1. The idler gear does not engage with the reel disk well.
2. Though the idler gear and reel disk are engaged with
each other, the tape is not wound because of overload
to the mechanism.
3. No FG pulse is output from the reel sensor.
4. No power is supplied to the reel sensor.
5. Tape transport operation takes place with a cassette
having no tape inside.
6. The tape slackens and no pulse is produced until the
slack is taken up and the tape comes into the normal
Sep 02, 2009 | JVC GR-DVL320 Mini DV Digital Camcorder
CAMCORDER WILL NOT PUSH IN A TAPE, STUCK HERE
Posted by delmas263 on Jan 02, 2009 I have the same problem, The camcorder will not take in the tape, stuck the tape holder will not go back in, notify me when you have a solution. Thanks
Dec 19, 2008 | JVC GR-D244US Camcorder
Mini dv
mam try to check the tape if its correctly inserted to the camcorder. it must the tape itself or the tape compartment has the problem. insert the tape and see if its feed to the tape head and be sure that it will close with no problems. if the problem still occuring or persisting then try another dv tape and see if you got the same problem. otherwise go to the nearest repair shop to be able to fix with the use of their tools. hope that helps you ma'm!
thank you for using fixya
CHARCOIS
Dec 10, 2008 | Samsung SC-D103 Mini DV Digital Camcorder
Tape stuck in cam corder
take a screw driver and open it up.
Dec 04, 2008 | JVC GR-D30U Camcorder
E04 Error
Eject tape leaving cover open and remove battery. Re-insert battery and re-insert tape also leaving cover open. Keep repeating this process until eo4 message disappears. This worked for my GR-DVL100e after about four repeats. After getting your camcorder operational, they say it is good practice not to leave tape in camcorder when not in use.
Jun 26, 2008 | JVC GR-DVF21 Mini DV Digital Camcorder
Door to open and close to insert blank tape
If you take it off of battery and plug it into the wall, does it do the same thing?
Jun 09, 2008 | JVC GR-SXM58 Camcorder
E04 Error Message
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. Good Luck, i'm off to buy a tape head cleaning cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
Oct 17, 2007 | JVC GR-DVF21 Mini DV Digital Camcorder
Blank screen during playback
your camcorder video head is dirty, use a brand new tape and playback for around 5 minutes or more, this will serve as your video head cleaner. you may try at least five times doing this: insert, play, eject,play, eject again. your camcorder has a built in videohead cleaner and activates only during insert, play or rec, and eject mode. If the problem is still there, manual videohead cleaning is needed, use clean bond paper and lighter fluid, damp the bond paper (Size about 1" by 3") with fluid and rub with care the videohead (not the bond paper!The vhead should be the one turning not the paper)by slowly turning the videohead against the paper. Be careful cause this is dangerous that you might brake the videohead permanently. apply only a slight force to the head.
Aug 29, 2007 | JVC GR-D370 Mini DV Digital Camcorder
Video Cameras Logo
23 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
