Is there a way to remove the wash basket from a Maytag Centennial washer to get a sock out?
Maytag317
  • 1136 Answers
SOURCE: Top loading maytag washer leaking water during wash cycle
Hi, There are two spring clips located in the gap between the top and front panel. They are the edges.
If the pump and hoses aare ok, fill the washer with water and look up toward the center of the tub abd transmission area. It migth have a seal going bad.
I hope this helps.
Vic
Posted on May 30, 2009
beltronic205
  • 1474 Answers
SOURCE: Overfilling maytag centennial - brand new?
Sounds like a hose off pressure switch or faulty switch/ however make sure drain connected ok 1st....
Posted on Oct 02, 2009
wiringlunati
  • 576 Answers
SOURCE: how can I make the Maytag Centennial 3.2 agitate
You really can't without redesigning the washing machine.
Posted on Mar 07, 2010
My Maytag has a load size sensor that automatically fills the tub with the appropriate amount of water. This sensor gets over-ridden if the lid is opened while filling. In other words, don't open the lid during the cycle. If you do, the machine will fill to the top as if there is a huge load in the tub.
Posted on Jun 21, 2010
TheMobilian
  • 8220 Answers
SOURCE: How do I remove the agitator on a Maytag
Here is a nice video:
My Tip How it works: Direct drive washer
Posted on Jul 23, 2010
How do you clean out the drain pump maytag centennial washer
Maytag & Whirlpool & Kenmore Washer Pump Repair ...
? 3:44
https://www.youtube.com/watch?v=97rBObh_3mQ
Sep 12, 2013 - Uploaded by ApplianceVideo.com
Repair your own Maytag Top Load Washer which has the following ... Took me awhile to unclog as an entire ...
Washer Won't Drain - Pump Clogged with Sock - Repair ...
? 1:53
https://www.youtube.com/watch?v=tHT7PmmFc9w
Dec 2, 2011 - Uploaded by Tomahawk DIY
Washing machine pump clogged with a sock. ... I searched hi and low trying to figure out why my washing ...
HE Maytag Centennial Washer Fix - YouTube
? 31:43
https://www.youtube.com/watch?v=CoTlOr3Gxuk
Nov 15, 2013 - Uploaded by mike3000ace1
So how do you open the washer to pull out the Manual? .... +mike3000ace1 Hi, I have a 2011 Maytag ...
Maytag Centennial Washer Drain, Transmission ...
Jan 05, 2016 | Maytag Washing Machines
Specs for model#MVWC400XW0 Maytag Centennial Washer
It definitely could be a clogged or bad pump. However, it's always a good idea to check for error codes before replacing a part...Especially expensive ones...
http://applianceassistant.com/Washer-Repair/Maytag-Centennial/Maytag-Centennial-Washer-Error-Fault-Codes.php
Hope it helps! Good luck!
Mar 02, 2015 | Maytag Centennial 3.2 cu. ft. SuperSize...
How do i fing out if my washer is still under Warr.? I have a Maytag centennial washer
The standard warranty is 1 year from date of purchase for all parts and labor. I believe the Centennial Series has a 10 year warranty on the wash tub (basket) and motor, parts only. So if your washer is over 1 year old, the pump would not be covered. If I may ask, why do you think the pump is defective? Can you provide the model number of your washer?
Dec 23, 2014 | Maytag Centennial Top Load Washer
Repair manual Where I can download the repair manual for the maytag centennial washer
This is a manual. Since there are so many versions, you might need to search for the appropriate one. I searched for "Maytag centennial top load washer repair manual". There was a Maytag site, but download was very slow. http://applianceassistant.com/ServiceManuals/8178628_ml-3_maytag_centennial_top-load_washer.pdf#zoom=100#scrollbar=1#toolbar=1 http://applianceassistant.com/ServiceManuals/8178628_ml-3_maytag_centennial_top-load_washer.pdf
Jul 30, 2014 | Maytag Centennial Top Load Washer
Have necklace stuck between tub and basket of Maytag Centennial low water washer
Visit http://www.maytag.com/manuals/ and type in the model number to find documentation for your washer. Maytag also has a help line at 1-800-253-1301.
Apr 19, 2014 | Maytag Washing Machines
Hello there and welcome to fixya
Here is the specifications on this washer
and this should explain why it dosent take much water to get clothes clean
This high-efficiency Centennial Top Load Washer features the IntelliFill automatic water level sensor and 11 automatic wash cycles to give you plenty of options. Low Water Wash with EcoConserve helps you save energy, while its spacious capacity means plenty of room for your largest loads. Inside, the stainless steel wash basket resists chips, scratches, and odors, as well as maintaining a smooth surface so it won't snag or pill fabrics. You get all that and still use 70 percent less water and energy in a model that pays for itself in four years. This no-nonsense machine does what you want.
  • CLICK HERE to learn more about Maytag Appliances
  • 3.6 cu. ft. capacity easily handles large loads and bulky items such as comforters
  • Rear panel controls provide convenient access to all cycle and option selections
  • IntelliClean impeller continuously moves clothes through the water for a thorough cleaning
  • 11 automatic wash cycles including heavy duty, casual, bulky and delicate to provide washing options to handle a variety of fabrics
  • ENERGY STAR qualified with a CEE Tier III rating: this washer is among the most efficient washers in the industry
  • Stainless steel wash basket resists chips and scratches and helps to protect fabrics from snags and pilling
  • Automatic Temperature Control monitors and adjusts incoming water flow to maintain the selected temperature for more consistent cleaning results
  • Low water wash with EcoConserve: use less water and get better cleaning performance through concentrated wash action, Low Water Wash technology enables the detergent to penetrate better and pre-treat soils with a concentrated mix
  • The IntelliFill sensor regulates the amount of water being used, making automatic adjustments based on the size of the load and type of fabric
  • MaxExtract Extended Spin option accelerates the load's final spin to remove moisture and reduce drying time
  • Deep Clean option uses a additional cleaning action and a deep rinse to ensure load is clean the first time
  • Click Here for details on the services included with Delivery & Basic Hook-up and Installation options for Major Appliances
  • MFG Model # : MVWC400XW
  • MFG Part # : MVWC400XW
May 25, 2013 | Maytag Centennial 7.0 Cu. Ft. Super...
Water on inside of washer walls and on floor. drain is not plugged and all hoses are ok.
you have a blockage some where possible sock in the sump hose to the pump have a look and let me know
Nov 25, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
I'm getting small orange spots/stains on my clothing after washing them in my Maytag washing machine. it is a 2010 machine too. Any thoughts as to what could be causing the stains?
Unless there is a child's crayon or something similar causing it, then suspect that the agitator shaft seal, or the drum seal is leaking oil into the drum. Hopefully, there is still warranty on the machine. Good luck!
Jan 10, 2011 | Maytag Centennial MTW5800TW Top Load...
Washing Machines Logo
Top Washing Machines Experts
