Question about Tally T2245 Matrix Printer
Printer problem Printer is powering on & initilaiing then display this messages hardware alarm-000lne -973 000 0000000002 +0180 pleas send solution with warm regards Rajesh Chandra Mishra E-mail mishra_rcm@rediffmail.com
  • Anonymous May 12, 2009
    Where is the FAW sensor?
    New Friend:
  • 114 Answers
The problem comming from FAW sensor. your FAW sensor may damaged or it is not in proper place.
Posted on Jan 30, 2009
What is the problem when a Tally T2265+ printer show the error message? How to clear this error message?
it sounds as if this will be a problem with a board and you will need to have it replaced
Jun 20, 2014 | Tally Office Equipment & Supplies
My HP Photosmart C6280 asks me to replace the light blue ink cartridge and says it is unable to print until we replace the ink cartridge. We have replaced it three times and the same message appears. The...
Follow the below steps on the front panel of the All-in-One printer:
A. - Press and Hold the "Print Photos" & "Red Eye Removal" buttons. Release both buttons.
Display should say "Enter Special Key Combo"
B. - Press and release in sequence "Red Eye Removal", "Print Photos", "Red Eye Removal"
(try both and see which one will get you to system config menu )
display says "enter special key combo"
1. Press and release in sequence "Red Eye Removal", "Print Photos", "Red Eye Removal"
2. Press and release the right arrow button until the display says "System Configuration
Menu".
3. Press and release the "OK" button.
4. Display should say "Hardware failure status". If not there already, Arrow Key over to
5. Press and release the "OK" button
6. Display should say "Hardware failure status: Clear. Press OK to clear".
7. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared.
Press Cancel to continue".
8. Press and release the "CANCEL" button as many times as necessary, so that, either the
"Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears.
PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the
printer and wall outlet.
it is now powered down and unplugged.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the
wall outlet first and then into the back of the printer
11. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
12. If the printer has already initialized, then go to the next step. If not, the printer
will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do
not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
13. To verify printer functionality print a SELF TEST PAGE.
Aug 31, 2011 | HP Photosmart C6280 Printer
Printer hp c6280: error message "oxc18a0401" what
Please perform the following steps SWITCH ON THe PRINTER.ONCE THEERROR COMES in the display screen DO THE FOLLOWING Press and hold the * key.
Press the # key and release both keys.
Display should say Enter Special KeyCombo
Press and release the button one by one in sequence the 1, 2 and 3 buttons.
display screen says "support" R0631M.
Press and release the right arrow button until the display says System Configuration Menu.
then Press and release the OK button.
Display should say Hardware failurestatus. If not there already, ArrowKey over to Hardware failure status
Press and release the OK button..Display should say Hardware failure status: Clear. Press OK to clear.
Press and release the OK Button. Message changes to Hardware failure statusCleared. Press Cancel to continue.
Press and release the CANCEL button as many times as necessary, so that, eitherthe Welcome to Photosmart Express screen appears, or, the Ink System Failurescreen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable fromback of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cableinto the wall outlet first and then into the back of the printerTurn the unit on. The printer may display message USEPOWER BUTTON TO SHUTDOWN THE PRINTER followed by PRESS OK TO CONTINUE. PressOK. The Printer will start the ONE TIME INK INITIALIZATION PROCESS. Allow thisprocess to complete and do not interrupt. Once the initialization process iscomplete, the printer will print out a Diagnostic Page.
Aug 01, 2011 | HP Photosmart C6280 Printer
HOW DO YOU RESET THE ERROR MESSAGE 0xc18a0207 on an HP 6100 series all in one ?
A. - Press and hold the “*” key.
B. - Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
C. - Press and release in sequence the “1”, “2” and “3” buttons.
1. Press and release the “OK” button.
2. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
3. Press and release the “OK” button.
4. Display should say “Hardware failure status: Clear. Press OK to clear”.
5. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
6. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
7. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
8. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
9. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
10. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
11. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
If the error is still there, or reoccurs replace the unit
Jul 26, 2010 | HP Photosmart C6180 All-In-One InkJet...
I have a printer ?HP c7280 All-in-one?a message, ?Ink system failure, error: 0xc18a0201.?
The ink system failure message has a chance to be fixed or it may be a permanent issue. It can be pointing toward a firmware failure in the printer and if that is the case the following steps should fix it. Press and hold the ?*? key. Press the ?#? key and release both keys. Display should say ?Enter Special Key Combo? Press and release in sequence the "1?, ?2? and ?3? buttons. Display should say ?Support? and display the FW rev (something like R0631R) Mine reads R0631M . Press and release the right arrow button until the display says ?System Configuration Menu?. Press and release the ?OK? button. Display should say ?Hardware failure status?. If not there already, Arrow Key over to ?Hardware failure status?, Press and release the ?OK? button. Display should say ?Hardware failure status: Clear. Press OK to clear?. Press and release the ?OK? Button. Message changes to ?Hardware failure status Cleared. Press Cancel to continue?. Press and release the ?CANCEL? button as many times as necessary, so that, either the ?Welcome to Photosmart Express? screen appears, or, the ?Ink System Failure? screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer. Turn the unit on. The printer may display message ?USE POWER BUTTON TO SHUTDOWN THE PRINTER? followed by ?PRESS OK TO CONTINUE?. Press OK. The Printer will start the ?ONE TIME INK INITIALIZATION PROCESS?. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. Good Luck!
Jan 11, 2010 | HP Photosmart C7280 Printer
Message on printer screen "ink system failure" Message on computer screen "print head failure"
Aug 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
Tally printer hardware alarm home postion
There is a broken gear(s) in its mechanism that's why you are having this hardware alarm message.
Dec 07, 2008 | Tally T2250 Matrix Printer
Tally 2250 Matrix printer
tally printer give hardware alarm on every problem gear aliment is very important in tally cheak for function sensor
Jul 21, 2008 | Tally T2250 Matrix Printer
T 2250
tally t 2250 give hardware alam
code +03211 ne -007000 000000 128+0304
Jan 19, 2008 | Tally T2250 Matrix Printer
Tally T2245 Matrix Printer Logo
109 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
